fitted my new green temp sensor now its not even getteng up to degrees
wallace78 Apr 3, 2012
  1. wallace78
    wallace78 Member
    146
    i fitted it the other day but dosent seem 2 b working any1 any tips that could help me, cheers
  2. Broken Byzan
    13,237
    465
  3. wallace78
    wallace78 Member
    146
    soz its 2001 a4 2.5 quattro m8
  4. hades-
    9,481
    646
    what dont seem to be working ?
    are you sure it was the fault ?
    it could be your stat or if you didnt get a oem sensor it could be ****ed
  5. wallace78
    wallace78 Member
    146
    no m8 i got a dopey 1 of fleabay
  6. hades-
    9,481
    646
    well then id say thats your problem
    get 1 from audi they dont cost alot are try that
  7. wallace78
    wallace78 Member
    146
    cheers bez
  8. pauldazzle
    pauldazzle Well-Known Member
    1,136
    82
    Fitting a genuine VAG CTS is a must. Cheap aftermarket temp sensors rarely work properly. Make sure you bleed the coolant system properly. i.e Header tank cap off, heater on hottest setting, bring the engine up to normal operating temp with the rpm's held at about 3000& hold it there for at least 5 mins. Turn off top up & leave the cap off then allow the car to cool down then top up again if necessary.
  9. wallace78
    wallace78 Member
    146
    cheers paul m8 im goina get new coolant mine is gunky n yellow do u bleed it in the same way thnx
  10. pauldazzle
    1,136
    82
    Use genuine G12 antifreeze only.
  11. wallace78
    wallace78 Member
    146
    yeah thats the one i ordered m8 iv a ****load of stuff coming from ebay for the car cant wait to get it all on then get the pics up m8
