Fitted my boost gauge
S3 ABV Sep 23, 2009
  1. S3 ABV
    S3 ABV Member
    As title, i fitted my boost gauge yesterday and all is working. I have a clear reading of my boost pressure which is 1.3 bar and the car seems to pull very well now after all the new parts fitted ect..
    Question is, have i fitted the boost gauge to the right pipe correctly?
    I have fitted the boost pipe to the small pipe that goes along the fuel rail to the under side of the inlet manifold. Is that the right one........also the vacum pressure is around -6 on the gauge on tickover
    Any help/advice appraicated.
    Thanks, Kev
  2. Westy
    Westy Well-Known Member
    17,443
    1,103
    :sign_pics:
  3. S3 ABV
    S3 ABV Member
    Can post pic's tomoz mate. The pipe runs along the fuel rail then into the inlet mani.....
  4. Dani_B19
    9,163
    362
    1.3 bar! Guessing its remapped. The best pipes to use are the 2 running down the block from the n249 valve and down under the inlet mani.
  5. S3 ABV
    S3 ABV Member
    Yeah it's remapped. Hits 1.5 bar when cold then goes to 1.3 bar so i'm guessing the pipe is the right one.
  6. ianysm
    ianysm Active Member
    1,002
    Got any pics of fitting and display? Where have you put it?
    I'm keen to see what mine is outputting!
  7. Essflee
    Essflee Well-Known Member
    2,142
    66
    I checked mine the other day with the liquid S3 device and had similar results, as the Turbo comes in it'll peak at 1.5bar and then drop and hold 1.3 bar through the rev range...:icon_thumright:
  8. Pinola
    Pinola Member
    89
    I was thinking of getting a liquid for my S3 are they worth it? also how have you fitted yours in a vent?
  9. Essflee
    2,142
    66
    They are quite expensive, I borrowed my mates...he hasn't Fitted it in a vent, just left it loose. It's brilliant for checking that everything is working as it should as I haven't got vag-com and don't know much about it...If you plan on keeping your car for some time it's a handy tool to have...
  10. Pinola
    Pinola Member
    89
    cool cheers
  11. Sandip
    2,440
    91
    :sign_pics:
