fitted my bargin but have i found a problem
pagey Feb 19, 2010
  1. pagey
    pagey Member
    41
    hi all i have a 18t sport avant and today i fitted my £5 aircon compressor that i bought off ebay bargin.
    but when i was fitting it i noticed that from under the car if i pushed up on the center engine mounting there was some play there. is this normal or do i have a worn engine mount ,by the way the car has done 114000 miles .
    if i have are they easy to change and are they expensive.
    thanks mike
  2. olds_kool
    olds_kool Active Member VCDS Map User
    1,094
    15
    the central front one? play is normal but not ideal
    if so invest some of the money you saved on a poly replacment
  3. aragorn
    18,539
    865
    my poly mount was only about 30quid.
    they come from audi pre-worn they're that crappy :p
  4. pagey
    pagey Member
    41
    thanks for that i will have to look into geting a poly bush ,when its fitted will i feel any difference at all.
