- Joined
- Sep 14, 2008
- Messages
- 24,836
- Reaction score
- 6,078
- Points
- 113
- Location
- Wibbleton
- Website
- www.tuffty.co.uk
actually there was one anomerly... well twice when she's cold she wont start first try, both times ive wound her over six to seven engine turns let off then starts second attempt. once she's warm she starts great? started first time every time before... do have my oil just above maximum from a slight overfill?
also had a **** fit when my car flashed a massive red light at me repeatedly as i drove the duel carriage way today, my mate said ti was brakes, pushed my button and yes low fluid.... wondering if the heat from the mani has affected it??
cheers bill, my first go at logging when i try this... just had a flick through on ross tech, so i log block 020 then drive in third from 2k to the redline and see what i get when? at the end?
now you over boost on part throttle?? Not when flat out but when you let off gas ect,,,ive been thinking i need to adjust my actuator properly, the guy i bought the car off suggested loosening the actuator to stop the overboost..... maybe he did some and now i cant achieve requested boost.... before the turbo fix soft limp wasnt kicking in until 1.4 to 1.5bar,if i were running a std map surely limp would've kicked in much sooner???
any pointers? just wind it in on charge pipe pressure until its 9psi?
its goona be a pig withthe v3 mani on there!?
get it mapped up you will have no problem
Could disconnecting the battery wipe the map? Had to disconnect it to get it to boost at all after priming the turbo oil feed with the injectors unplugged!
no mate but I bet readiness hasn't set yet in vcds!Could disconnecting the battery wipe the map? Had to disconnect it to get it to boost at all after priming the turbo oil feed with the injectors unplugged!
readiness?no mate but I bet readiness hasn't set yet in vcds!
We dont know if its standard or not because you havent logged!! Lol
Do you have vcds lite at least??? You need that to log.
Your boost REQUEST tells us whether its standard. As does your lambda request.
Ive kinda lost track of whats going on.
So hows the car behaving? Boost? vacuum? Mods including anything like deletes.
Is the n249 delete correct?
To be honest you cant go blaming this seller, never take a guys word for it, and you shouldve checked the legitimacy of everything before handing cash over. You could do with someone off here whos in the know to check things over. Where are you again?
get a working vcds cable and all will be revealed. and if keeping with vagcars will be a tool worth investing in.
,0.40,840,22.6,1000.0,1010.0,0.80,840,78.0,3.9,11111110,0.01,840,22.6,2.05,3.36 |
,1.60,840,22.6,1000.0,1010.0,2.00,840,78.0,-1.6,11111110,1.20,840,22.6,2.05,3.44 |
,2.81,840,23.3,1000.0,1010.0,3.21,840,78.0,0.0,11111110,2.41,840,23.3,2.46,3.78 |
,4.01,1000,21.1,1000.0,1010.0,4.41,1360,78.0,2.3,11101010,3.61,960,23.3,2.05,3.89 |
,5.40,1320,39.8,1000.0,1020.0,5.80,1360,78.0,-2.3,11101010,4.91,1440,37.6,3.28,9.94 |
,6.60,1320,46.6,1000.0,1020.0,7.00,1320,78.0,1.6,11101010,6.20,1320,39.8,3.69,9.58 |
,7.91,1160,41.4,1000.0,1030.0,8.31,920,78.0,3.1,11101110,7.40,1120,43.6,4.10,9.58 |
,9.11,1760,57.1,1000.0,1020.0,9.51,1520,78.0,3.1,11101010,8.71,920,55.6,7.79,15.53 |
,10.40,1960,72.2,1080.0,1090.0,10.80,2320,78.0,3.1,11101000,10.00,1800,68.4,6.56,27.06 |
,11.60,3240,93.2,1000.0,1350.0,12.00,2880,78.0,3.1,11111100,11.20,2760,85.7,8.20,47.61 |
,12.89,2280,83.5,1290.0,1180.0,13.29,2400,79.0,5.5,11101000,12.40,2320,60.2,8.20,38.83 |
,14.09,2040,23.3,1000.0,1150.0,14.64,1720,79.0,-1.6,11101010,13.69,2440,29.3,1.64,6.64 |
,15.50,1840,82.7,1650.0,1190.0,15.90,1920,79.0,6.3,11100010,15.10,1760,81.2,7.79,28.72 |
,16.70,2080,88.7,1800.0,1270.0,17.10,2160,79.0,4.7,11100000,16.30,2000,85.7,8.61,33.44 |
,17.99,2400,105.3,1800.0,1450.0,18.39,2520,79.0,4.7,11100000,17.59,2280,99.2,9.84,44.53 |
,19.19,2800,119.5,1770.0,1670.0,19.59,2920,79.0,4.7,11100000,18.79,2640,115.8,11.89,60.86 |
,20.39,3240,124.8,1740.0,1770.0,20.79,3400,80.0,6.3,11100000,19.99,3120,125.6,12.71,74.67 |
,21.59,3720,127.8,1730.0,1770.0,21.99,3840,80.0,3.9,11100000,21.20,3520,123.3,12.30,83.58 |
,22.80,4120,126.3,1730.0,1740.0,23.20,4280,80.0,2.3,11100000,22.40,4000,127.1,12.30,97.00 |
,24.00,4600,126.3,1740.0,1720.0,24.40,4720,80.0,4.7,11100000,23.60,4440,126.3,12.71,106.89 |
,25.31,5040,129.3,1770.0,1740.0,25.81,5160,80.0,0.0,11100000,24.80,4840,128.6,13.53,118.31 |
,26.60,5480,134.6,1790.0,1770.0,27.00,5640,80.0,0.0,11100000,26.21,5320,133.1,13.94,133.86 |
,27.80,5880,136.8,1750.0,1780.0,28.20,6000,80.0,0.0,11100000,27.40,5760,136.8,15.17,143.81 |
,29.00,6080,13.5,1000.0,1660.0,29.40,5680,81.0,0.0,11110101,28.60,6120,135.3,15.17,149.89 |
,30.20,4920,6.8,1000.0,1110.0,30.60,4520,81.0,0.0,11110101,29.80,5320,7.5,0.00,4.81 |
,31.40,3920,8.3,1000.0,1060.0,31.89,3640,81.0,0.0,11110101,30.98,4240,8.3,0.00,7.08 |
,32.69,3320,9.0,1000.0,1050.0,33.19,3200,81.0,0.0,11110101,32.29,3480,9.0,0.00,6.58 |
,33.99,2960,9.8,1000.0,1040.0,34.39,2880,81.0,0.0,11110101,33.59,3080,9.8,0.00,6.03 |
,35.19,2680,9.8,1000.0,1030.0,35.58,2560,81.0,0.0,11110101,34.79,2760,9.8,0.00,5.42 |
,36.38,2320,10.5,1000.0,1030.0,36.78,2200,81.0,0.0,11100101,35.98,2440,10.5,0.00,5.08 |
,37.58,2120,72.9,1400.0,1050.0,38.09,2160,81.0,5.5,11101001,37.18,2160,46.6,6.15,24.14 |
,38.89,2280,81.2,1000.0,1340.0,39.29,2320,81.0,13.3,11101001,38.49,2200,85.0,8.61,37.92 |
,40.09,2280,24.8,1000.0,1190.0,40.59,2200,81.0,11.7,11111101,39.69,2320,40.6,3.69,12.75 |
,41.39,2160,78.9,1410.0,1130.0,41.80,2160,81.0,3.9,11101001,40.99,2160,57.9,7.38,27.47 |
,42.68,2120,27.8,990.0,1110.0,43.08,2120,81.0,8.6,11101001,42.28,2160,40.6,4.10,13.78 |
,43.88,2040,31.6,990.0,1050.0,44.39,2000,81.0,4.7,11101001,43.48,2080,22.6,2.46,8.83 |
,45.19,2000,51.1,990.0,1060.0,45.69,1960,81.0,-1.6,11101011,44.79,2000,36.8,3.69,14.53 |
Wednesday | 22 | May | 2013 | 18:34:59 | ||
8N0 | 906 | 18 | 1.8L | R4 | ||
Group | A: | 2 | ||||
RPM | Load | Inj. | On | Time | ||
TIME | TIME | |||||
Marker | STAMP | /min | % | ms | ||
1.28 | 840 | 18.8 | 2.05 | |||
2.59 | 1400 | 16.5 | 1.23 | |||
3.79 | 1960 | 32.3 | 2.87 | |||
4.99 | 1640 | 39.1 | 3.69 | |||
6.3 | 2280 | 63.2 | 6.56 | |||
7.69 | 3480 | 60.2 | 6.15 | |||
8.89 | 3000 | 65.4 | 6.56 | |||
10.18 | 2880 | 104.5 | 10.66 | |||
11.48 | 2040 | 82.7 | 8.2 | |||
12.67 | 2240 | 93.2 | 9.43 | |||
13.87 | 2520 | 133.8 | 12.71 | |||
15.07 | 2920 | 141.4 | 13.53 | |||
16.29 | 3360 | 134.6 | 13.12 | |||
17.48 | 3800 | 133.1 | 13.12 | |||
18.68 | 4200 | 133.1 | 13.12 | |||
19.88 | 4640 | 134.6 | 13.53 | |||
21.27 | 5120 | 136.1 | 13.94 | |||
22.49 | 5600 | 139.8 | 15.58 | |||
23.68 | 6040 | 139.1 | 15.99 | |||
25.09 | 6480 | 121.1 | 13.94 | |||
26.29 | 5400 | 6 | 0 | |||
27.57 | 4160 | 7.5 | 0 | |||
28.88 | 3400 | 8.3 | 0 | |||
30.08 | 3160 | 9 | 0 | |||
31.27 | 2800 | 9.8 | 0 | |||
32.57 | 2200 | 10.5 | 0 |
