Fitted a cone filter and......
M44 DUB Feb 15, 2007
  1. M44 DUB
    M44 DUB Member
    166
    To my A3 1.8 T and it feels a lot more responsive but it doesn't make the charring noise like my friends one mines dumps, anyone know why this is?
  2. Olly_K
    Olly_K Administrator
    2,678
    it will by your diverter valve i reckon.
    after market filters arent good for these engines
  3. M44 DUB
    M44 DUB Member
    166
    Do you think it's knackered? As i don't think it boosts properly either. But the filter has helped.
  4. Tallpaul
    Tallpaul Member
    835
    is the cone open to the engine bay?
  5. M44 DUB
    M44 DUB Member
    166
    What do you mean? you'll need to be less technical (female) it's just where the standard air box was.
  6. Tallpaul
    Tallpaul Member
    835
    Is the filter 'exposed' to the engine bay or is it 'boxed' or surrounded by some sort of heat shield?
    If it is completely un-protected from the heat of the engine then that's bad. Much worse than the OE airbox with a paper filter (which is actually quite good).
    If it is open to the heat of the engine then it will draw in hot air and you'll be producing less power because of it.
  7. M44 DUB
    M44 DUB Member
    166
    I get what your saying now but it feels like i'm getting more power. Still to get a cold air feed made up when i do a battery to boot conversion.
    Still doesn't answer the noise question tho
  8. Tallpaul
    Tallpaul Member
    835
    Are you saying yours 'charrs' or 'dumps'?
    If it charrs, i have no idea what that sounds like...
    Are both you and your friend running the same car with the same modifications/boost?
  9. M44 DUB
    M44 DUB Member
    166
    Mines dumps like a normal DV whoosh noice and his makes a wastegate charring noise like rally cars, running the same as him.
    Heading to Dastek to get it on the rollers to see if something is wrong.
  10. Stewart
    Stewart Member
    705
    10
    Wastegate flutter or chirruping on a closed loop diverter system like ours indicates the diverter valve (DV) is knackered. If he is running the standard DV then its knackered and the diaphragm has split which is very very common.
