Fit Sony MEX-BT2700 in Audi A3 8L
taffjohn Sep 30, 2013
  1. taffjohn
    taffjohn New Member
    27
    Hi All,
    Could anybody confirm whether a Sony MEX-BT2700 stereo is suitable for an audi system and what leads do i need?
  2. Gizmo20VT
    Gizmo20VT Active Member
    294
    If you have single din then it can be replaced wtih this unit, you get a trim plate and harness to reconnect the rear sub and speakers...
    Use a normal ISO plug which will connect into the OEM connector blocks and probably a little Antenna converter depending on the Head unit.
  3. taffjohn
    taffjohn New Member
    27
    Hello Gizmo20VT,
    Thanks for your quick reply, will i be able to get all speakers including Sub-Wofer working with this Sony system, and also do you
    know part no for lead adapter to connect to Audi system.
    Thanks very much for your help.
  4. <tuffty/>
    21,954
    4,228
    What car do you have and do you have a Bose system?
  5. Gizmo20VT
    294
    I purchased my products from one of our local suppliers.
    Item codes below with link
    Audi
    Item OT11-1901 (Trim) & OT12-Audi-RCA
    If you have a double din currently you can work down the A4 Trim to convert to single din.
  6. taffjohn
    taffjohn New Member
    27
    Hi Tuffty,
    I have an Audi A3 8L 2003 1.9TDI Sport, fitted with an Audi Concert (Tape Deck).
  7. <tuffty/>
    21,954
    4,228
  8. joe_echo
    joe_echo Member
    67
