First VCDS use, each scan a new error appears.
mfractal Jan 16, 2013
  1. mfractal
    mfractal Member
    51
    Hi all.
    I just gotten my VCDS cable today and went along to play with it.
    Car is MY2010 Audi A3 8P.
    Upon first Auto scan 1 error appeared :
    Code:
    Address 01: Engine (CCZ)       Labels: 06J-907-115-CCZ.clb
       Part No SW: 8P0 907 115 AE    HW: 8P0 907 115 Q
       Component: 2.0l R4/4V TFSI     0020
       Revision: AAH07---    Serial number: AUX7Z0I7FNR00R
       Coding: 0103100C1C070160
       Shop #: WSC 06314 000 00000
       VCID: 75EBFF0D1CDA171
    1 Fault Found:
    001089 - EVAP Emission Control Sys
                   P0441 - 000 - Incorrect Flow - Intermittent
                 Freeze Frame:
                        Fault Status: 00100000
                        Fault Priority: 0
                        Fault Frequency: 3
                        Mileage: 40857 km
                        Time Indication: 0
                        Date: 2013.01.09
                        Time: 18:11:11
                 Freeze Frame:
                        RPM: 840 /min
                        Load: 25.1 %
                        Speed: 0.0 km/h
                        Temperature: 99.0°C
                        Temperature: 43.0°C
                        Absolute Pres.: 930.0 mbar
                        Voltage: 13.208 V
    So this is my first question, anybody knows how to go about it ?
    So later, i kept on playing with the different modules (not changing anything, just seeing the reported values/options and getting to know the software basically.
    Then i decided to auto scan again.
    Guess what, a second error pops up :
    Code:
    1 Fault Found:
    01539 - Headlights Not Adjusted
                005 - No or Incorrect Basic Setting / Adaptation - MIL ON
                 Freeze Frame:
                        Fault Status: 11100101
                        Fault Priority: 2
                        Fault Frequency: 1
                        Reset counter: 252
                        Mileage: 41720 km
                        Time Indication: 0
                        Date: 2013.01.16
                        Time: 17:16:47
    :sorry:
    After googling about, i figured that one out with the help of the awesome Ross-Tech WIKI page
    (just to document the solution is :
    Code:
    [B]Headlight Adjustment[/B]
    [COLOR=#000000][FONT=Arial][B][Select][/B]
    [B][55 - Xenon Range][/B]
    [B][Basic Settings - 04][/B]
    Group 001
    [B][Go!][/B]
    Activate the Basic Setting.
    [B][ON/OFF/Next][/B]
    [/FONT][/COLOR]
    [LIST]
    [*]The meas. block field now shows "Wait" and should switch to "Adjust Headlights" then (this may take up to 10 seconds).
    [*]Adjust the headlights using their manual adjusting screws as referenced against a suitable aiming target.
    [/LIST][COLOR=#000000][FONT=Arial][B][ON/OFF/Next][/B]
    The adjustment should now be learned.
    [B][Done, Go Back][/B]
    Don't forget to check/clear fault codes afterwards.
    [/FONT][/COLOR][B][Close Controller, Go Back - 06][/B]
    that got rid of that error).
    So i kept on fiddling with the program, mainly trying to figure out how to turn the damn DRL Leds on (will open a thread about it, since i can't figure it out yet).
    Then i scan for the third time, and a new error appears (WTH??)
    Code:
    Address 03: ABS Brakes (-----)       Labels: 1K0-907-379-60EC1F.clb
       Part No SW: 1K0 907 379 AP    HW: 1K0 907 379 AP
       Component: ESP MK60EC1   H45 0107
       Revision: 00H45001
       Coding: 144260120A2700FC281206E9501A00413900
       VCID: 80051ED91318A29
    1 Fault Found:
    01309 - Power Steering Control Module (J500)
                008 - Implausible Signal
                 Freeze Frame:
                        Fault Status: 01101000
                        Fault Priority: 3
                        Fault Frequency: 1
                        Reset counter: 252
                        Mileage: 41715 km
                        Time Indication: 0
                        Date: 2013.01.16
                        Time: 18:52:10
                 Freeze Frame:
                        Count: 0
                        Count: 12
                        Count: 12800
                        Count: 8212
                        Count: 48640
                        Count: 0
                        Count: 0
                        Count: 0
    Tried resetting the errors but that one keeps coming back.
    So my question (2) is, why is this happening and how can i reset it since i am fairly sure that had it been a real problem it would have appeared on my first scan. I highly doubt that something physically broke during my 30 minutes of fiddling with VCDS.
    Thanks in advance guys!
    P.S Here's the full scan (the one without the last error, i forgot to save it as a log) just to show all the modules.
    Wednesday,16,January,2013,17:22:05:32264 VCDS Version: Release 11.11.3 Data ve - Pastebin.com
  2. NHN
    29,328
    1,708
    Thats a counterfeit fake cable.
  3. mfractal
    mfractal Member
    51
    Nigel, thanks for your help identifying my cable as fake, i was able to receive all my money back and get a cable directly from Bruce@Ross-Tech.
    Here's a full scan (as a proof i guess).
    Code:
    Wednesday,13,February,2013,17:02:03:52796VCDS Version: Beta 12.10.2 (x64)
    Data version: 20121222
    Chassis Type: 1K0
    Scan: 01 02 03 08 09 15 16 17 19 25 42 44 46 47 52 55 56 62 72 77
    VIN: WAUHF28P7AA052XXX   Mileage: 42710km/26538miles
    01-Engine -- Status: Malfunction 0010
    02-Auto Trans -- Status: OK 0000
    03-ABS Brakes -- Status: OK 0000
    04-Steering Angle -- Status: OK 0000
    08-Auto HVAC -- Status: OK 0000
    09-Cent. Elect. -- Status: OK 0000
    15-Airbags -- Status: OK 0000
    16-Steering wheel -- Status: OK 0000
    17-Instruments -- Status: OK 0000
    19-CAN Gateway -- Status: OK 0000
    25-Immobilizer -- Status: OK 0000
    42-Door Elect, Driver -- Status: OK 0000
    44-Steering Assist -- Status: OK 0000
    46-Central Conv. -- Status: OK 0000
    47-Sound System -- Status: OK 0000
    52-Door Elect, Pass. -- Status: OK 0000
    55-Xenon Range -- Status: OK 0000
    56-Radio -- Status: OK 0000
    62-Door, Rear Left -- Status: OK 0000
    72-Door, Rear Right -- Status: OK 0000
    77-Telephone -- Status: OK 0000
       VCID: 75E12DD31C0F0AB6ABB
    1 Fault Found:
                 Freeze Frame:
                        Fault Priority: 0
                        Fault Frequency: 2
                        Mileage: 42395 km
                        Time Indication: 0
                        Date: 2013.02.04
                        Time: 20:14:28
                 Freeze Frame:
                        RPM: 837 /min
                        Load: 30.6 %
                        Speed: 0.0 km/h
                        Temperature: 101.0°C
                        Temperature: 50.0°C
                        Absolute Pres.: 940.0 mbar
                        Voltage: 13.208 V
    Readiness: 0000 0000
    Address 02: Auto Trans        Labels: 02E-300-0xx.lbl
       Part No SW: 02E 300 051 R    HW: 02E 927 770 AJ
       Component: GSG DSG AG6     440 1926
       Revision: 04844002    Serial number: 00000908241237
       Coding: 0000020
       VCID: 224B268FFD01CD0EBE9
    No fault code found.
       Revision: 00H45001
       VCID: 800FCC0713CDBF1E08D
    Address 08: Auto HVAC        Labels: 8P0-820-043.lbl
       Part No SW: 8P0 820 043 BK    HW: 8P0 820 043 BK
       Component: KlimavollautomatH09 0140
       Revision: 000496      Serial number: 8P0820043BK
       Shop #: WSC 00000 000 00000
       VCID: 76E32ADF010901AEA21
    Address 09: Cent. Elect. (J519)       Labels: 8P0-907-063.clb
       Part No SW: 8P0 907 063 D    HW: 8P0 907 063 D
       Component: BCM PQ35  M   105 0563
       Revision: 00105 AI
       Coding: 06000A2CB005F2C0207241E000000914410E2BAA304DD929640008840040
       VCID: 3561EDD39C8F4AB66BB
       Subsystem 1 - Part No SW: 8P1 955 119 F    HW: 8P1 955 119 F  Labels: 1KX-955-119.CLB
       Component: Wischer AU350  H10 0040
       Coding: 00DD13
       Subsystem 2 - Part No: 8P0 951 177
       Component: Innenraumuebe  H04 0020
       Subsystem 3 - Part No: 1K0 951 605 C
       Component: LIN BACKUP HO  H03 1301
       Subsystem 4 - Part No: 1K0 907 719 C
       Component: Neigungssenso  005 0003
    Address 15: Airbags (J234)       Labels: 8P0-959-655-10.clb
       Part No SW: 8P0 959 655 P    HW: 8P0 959 655 P
       Component: Airbag AU1042 H06 0160
       Revision: --------    Serial number: 003FB002VAD%
       Coding: 30314238303830303131554A304C38503053
       ASAM Dataset: EV_Airba10AURB4 001001
       ROD: EV_Airba10AURB4.rod
       VCID: 4FADBF3B16131066417
       Crash sensor for side airbag; driver side:
       Serial number: 3572DRB400009625418L
       Crash sensor for side airbag; passenger side:
       Serial number: 3582DRB400009644EA8%
       Crash sensor for side airbag; rear driver side:
       Serial number: 35128RB400004FAB46D
       Crash sensor for side airbag; rear passenger side:
       Serial number: 35228RB400004FAA81AY
       Crash sensor for front airbag; driver side:
       Serial number: 35547RB40000504F6B2N
       Crash sensor for front airbag; passenger side:
       Serial number: 35647RB40000504F6ADY
    Address 16: Steering wheel        Labels: 8P0-953-549.lbl
       Part No SW: 8P0 953 549 K    HW: 8P0 953 549 K
       Component: J0527           H37 0070
       Coding: 0014142
       VCID: 46839A1F3169D12EF21
       Subsystem 1 - Part No: XXXXXXXXXXX
       Component: E0221           H02 0030
    Address 17: Instruments        Labels: 8P0-920-xxx-17-MY8.clb
       Part No SW: 8P0 920 932 F    HW: 8P0 920 932 F
       Component: KOMBIINSTR. VDO H03 0980
       Revision: D0H03003    Serial number: 2247I003001459
       Coding: 0000128
       Shop #: WSC 04576 659 119544
       VCID: 377DE7DB4683B8A6797
    Address 19: CAN Gateway        Labels: 1K0-907-530-V4.clb
       Part No SW: 1K0 907 530 AA    HW: 1K0 907 951
       Component: J533  Gateway   H16 5223
       Revision:   H16       Serial number: 4120K0990704DC
       Coding: ED817F06100602002102
       VCID: 66C37A9F51A9F12E121
    Address 25: Immobilizer        Labels: 1K0-920-xxx-25.clb
       Revision: D0H03003    Serial number: AUX7Z0I7FNR00R
       Shop #: WSC 04515 659 93121
    Address 42: Door Elect, Driver        Labels: 8P0-959-801-MIN3.lbl
       Part No SW: 8P0 959 801 N    HW: 8P0 959 801 N
       Component: Tuer-SG         H04 0100
       Coding: 0000148
    Address 44: Steering Assist        Labels: 1Kx-909-14x-44.clb
       Part No: 1K0 909 144 H
       Component: EPS_ZFLS Kl. 233    2901
       Revision: 00H17000
       Shop #: WSC 02069 000 90108
       VCID: 2F6DDFBBBED37066217
    Address 47: Sound System        Labels: 8Px-035-382.lbl
       Part No SW: 8P4 035 382 E    HW: 8P4 035 382 E
       Component: AB2 SUBWOOFERBOXH07 0180
       Revision: 00006       Serial number: 92158949357486
       VCID: 3663EADF418941AE621
    Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MIN3.lbl
       Part No SW: 8P0 959 802 N    HW: 8P0 959 802 N
       Coding: 0000148
       VCID: 479D971B3663C826097
    Address 55: Xenon Range        Labels: 8P0-907-357.lbl
       Part No: 8P3 907 357
       Component: Dynamische LWR  H01 0010
       Revision: 00000001    Serial number:
       Coding: 0000013
       VCID: FAFBBEEFB511E5CE469
    Address 56: Radio        Labels: 8J0-035-1xx-56.clb
       Part No SW: 8P0 035 186 T    HW: 8P0 035 186 T
       Component: R Concert2+     H02 0280
       Revision: 00H02000    Serial number: AUZ1Z3I5335722
       Coding: 0730012
       VCID: 4385830B025BE406D5F
    Address 62: Door, Rear Left        Labels: 8P4-959-801.lbl
       Part No SW: 8P4 959 801 F    HW: 8P4 959 801 F
       Component: Tuer-SG         H04 0050
       Coding: 0000144
       Shop #: WSC 06314 000 1012544
       VCID: 428B860F1D41ED0EDE9
    Address 72: Door, Rear Right        Labels: 8P4-959-802.lbl
       Part No SW: 8P4 959 802 F    HW: 8P4 959 802 F
       Coding: 0000144
    Address 77: Telephone        Labels: 8P0-862-335.lbl
       Part No SW: 8P0 862 335 AA    HW: 8P0 862 335 S
       Component: FSE_256x BT     H34 0600
       Revision: 00000000    Serial number: 00000005116276
       Coding: 0001295
    End   ---------------------------------------------------------------------
