Squirrelofdoom
Hi guys,
I'm sorting myself a full version of vag-com, but before that comes in I ran a scan with the trial version. These are the codes that came up. The car was scanned and cleared a while ago by a garage, so these should be "real" faults I guess, not just logs. I will run a full scan when I get the full version of vag-com up and running, but for now
18010 - Power Supply Terminal 30: Voltage too Low
P1602 - 35-10 - - - Intermittent
16955 - Believe this is brake switch related
P0571 - 35-10 - - - Intermittent
16795 - Believe this is SAI related
P0411 - 35-10 - - - Intermittent
1) I changed the battery maybe a month ago, would this trigger this? Also, when i'm low on fuel (maybe half a tank) the car doesn't always start first time, i've heard this can cause this fault?
2) I guess I need a new switch? Any way to see the part number I've got without removing the old one? I stuck my head down there and couldn't see where the number was stamped on the part
3) Related again to my fuel pump issues?
Thanks for the help guys. Will be doing some 3rd gear logs etc once I get the full version.
Cheers,
Aran
Cheers,
Aran
