First use of VAG.COM and now remote locking not working!!
slydog18 Nov 25, 2012
  1. slydog18
    slydog18 N88GGY S3
    139
    I had my first tinker with VAG.COM today to check/clear all fault codes and turn on beep with alarm. I cleared all codes and think I cleared something that I shouldn't have as I have got to my mums and found the remote alarm/locking is not working! I did have a control module memory fault in instrument cluster and got click happy when clearing codes!
    Also I could not access 46-central conv. to turn on alarm beep. Probably not related as this was before clearing all codes.
    Any ideas what to do?
    Thx
  2. AR-rkon
    AR-rkon Mod back in a "B" Staff Member Moderator Regional Rep Team V6 Team Silver Audi A6 Audi A4 Audi Avant Owner Group
    1,912
    164
    8L doesn't have central convenience, the alarm beep is controlled by the central locking pump iirc.
    Read the "coding" from the central locking and post it up and I'm sure someone can point you in the right direction.
  3. slydog18
    slydog18 N88GGY S3
    139
    Right, I had sussed that I had to use the Central locking option not convenience and have followed the instructions to pair keys including clearing all old onmes on channel '00'. My problem is that I change the value to 2 and test then save but cannot get either of my keys to pair. I have done it using lock then tried unlock buttons on both remotes that I know were working before I messed it up. Both keys start the car no problem but I have also noticed that when I lock the car via the door lock the alarm does not arm either. Is that because I am not using the remote? I did have a fault in the cluster that I think I should not have cleared. Here are 2 logs, one from before clearing fault codes and one after I got home from after realising they werent working when I went out:-
    1:-
    Sunday,25,November,2012,10:53:37:31506
    VCDS Version: Release 11.11.4 (x64)
    Data version: 20120807
    Chassis Type: 8L - Audi A3/S3
    Scan: 01 02 03 08 15 16 17 22 35 37 45 55 56 57 75 76
    VIN: WAUZZZ8LX31204543
    Address 01: Engine Labels: 06A-906-032-BAM.lbl
    Part No: 8N0 906 018 BH
    Component: 1.8L R4/5VT 0001
    Coding: 10710
    Shop #: WSC 02629
    VCID: 78F469C358A859D8195
    WAUZZZ8LX31204543 AUZ7Z0B2120937
    No fault code found.
    Readiness: 0000 0000
    Address 03: ABS Brakes Labels: 8N0-907-379-MK20-E.lbl
    Part No: 8N0 907 379 E
    Component: ESP 20 CAN V005
    Coding: 18448
    Shop #: WSC 01236
    VCID: 3E78BFDB3A0CA7E8139
    Address 08: Auto HVAC Labels: Redir Fail!
    Part No: 8L0 820 043 L
    Component: A3 KLIMAAUTOMAT 0105
    Coding: 00041
    Shop #: WSC 01236
    VCID: 316294E7FB5248909EB
    Address 15: Airbags Labels: 8L0-959-655-AI8.lbl
    Part No: 8L0 959 655 L
    Component: Airbag Front+Seite 7008
    Coding: 01104
    Shop #: WSC 01236
    VCID: 4796DA3F65D6E620A0F
    Address 16: Steering wheel Labels: 4B0-907-487.lbl
    Part No: 4B0 907 487 F
    Component: Lenkradelektronik D01
    Coding: 01002
    Shop #: WSC 01236
    VCID: 2F66929FED665E6088F
    Address 17: Instruments Labels: 8L0-920-xxx-17.lbl
    Part No: 8L0 920 980 R
    Component: KOMBI+WEGFAHRS. VDO D10
    Coding: 01444
    Shop #: WSC 00402
    VCID: 4280CB2B4EF4C308771
    1 Fault Found:
    65535 - Internal Control Module Memory Error
    00-00 - -
    Address 22: AWD Labels: 02D-900-554.lbl
    Part No: 02D 900 554 C
    Component: HALDEX LSC ECC 0010
    VCID: 204461A3A0B8F118015
    Address 35: Centr. Locks Labels: 8D0-862-257.lbl
    Part No: 8D0 862 257 E
    Component: CV-Pump, Alarm, RC D17
    Coding: 00033
    Shop #: WSC 00652
    Address 45: Inter. Monitor Labels: 4B0-951-173.lbl
    Part No: 4B0 951 173
    Component: Innenraumueberw. D03
    Coding: 00001
    Shop #: WSC 00953
    VCID: E0C4A1A360383118C15
    Address 55: Xenon Range Labels: 4B0-907-357-AUT.lbl
    Part No: 4B0 907 357
    Component: LEUCHTWEITEREGLER D004
    Coding: 00014
    Shop #: WSC 01236
    VCID: E5CAB0B77F1A5430323
    Address 56: Radio Labels: 8E0-035-1xx-56.lbl
    Part No: 8L0 035 195 H
    Component: symphony II NP2 0151
    Coding: 00205
    Shop #: WSC 00757
    VCID: 336E9EEF014E7A80EC7
    Address 76: Park Assist Labels: 4B0-919-283.lbl
    Part No: 4B0 919 283
    Component: Parkingsystem A3 RDW D18
    Coding: 00103
    Shop #: WSC 01236
    VCID: E6C8B7BB821C5F283B9
    End ---------------------------------------------------------------------
    2:-
    Sunday,25,November,2012,18:58:30:31506
    Coding: 10710
    Shop #: WSC 02629
    Coding: 18448
    Shop #: WSC 01236
    Coding: 00041
    Shop #: WSC 01236
    Coding: 01104
    Shop #: WSC 01236
    1 Fault Found:
    01211 - Belt Tensioner Igniter; Rear Driver Side (N196)
    32-10 - Resistance too High - Intermittent
    Coding: 01002
    Shop #: WSC 01236
    Coding: 01444
    Shop #: WSC 00402
    Coding: 00032
    Shop #: WSC 00652
    Coding: 00001
    Shop #: WSC 00953
    Coding: 00014
    Shop #: WSC 01236
    Coding: 00205
    Shop #: WSC 00757
    Coding: 00103
    Shop #: WSC 01236
