First Time VCDS User - List of Faults - HELP !!
areeb1 Jul 28, 2012
  1. areeb1
    areeb1 Member
    35
    Hi,
    I have just acquired a VCDS of a friend and I have plugged it into my 2004 A3 3 door.
    I cleared the errors but after a 20 min drive and good proportion of them came back.
    A couple of months ago, I retrofitted a RNS-E with Bluetooth and had it coded by a Audi Sport member.
    Below is the log from VCDS
    Chassis Type: 1K0
    Scan: 01 03 08 09 15 16 17 19 25 37 42 44 46 47 52 56 77
    VIN: WAUZZZ8P24A040919 Mileage: 188090km/116873miles
    00-Steering Angle Sensor -- Status: OK 0000
    01-Engine -- Status: Malfunction 0010
    03-ABS Brakes -- Status: OK 0000
    08-Auto HVAC -- Status: Malfunction 0010
    09-Cent. Elect. -- Status: Malfunction 0010
    15-Airbags -- Status: OK 0000
    16-Steering wheel -- Status: OK 0000
    17-Instruments -- Status: OK 0000
    19-CAN Gateway -- Status: OK 0000
    25-Immobilizer -- Status: OK 0000
    37-Navigation -- Status: Malfunction 0010
    42-Door Elect, Driver -- Status: OK 0000
    44-Steering Assist -- Status: Malfunction 0010
    46-Central Conv. -- Status: Malfunction 0010
    47-Sound System -- Status: OK 0000
    52-Door Elect, Pass. -- Status: OK 0000
    56-Radio -- Status: Malfunction 0010
    77-Telephone -- Status: OK 0000
    Address 01: Engine Labels: 06A-906-033-BGU.lbl
    Part No: 06A 906 033 BB
    Component: SIMOS71 1.6l 2V 5312
    Revision: 00000003 Serial number: AUX7Z0C6FN4020
    Coding: 0000071
    Shop #: WSC 06435 000 00000
    VCID: 60CBA4B3CAD3
    3 Faults Found:
    17698 - Coolant Temp Sensor at Radiator Outlet (G83): Signal too Small
    P1290 - 006 - Short to Plus - Intermittent
    Freeze Frame:
    Temperature: 57.0∞C
    Temperature: 57.0∞C
    Temperature: 25.5∞C
    RPM: 1504 /min
    Temperature: 58.5∞C
    Temperature: 58.5∞C
    Temperature: 25.5∞C
    RPM: 2080 /min
    18359 - Radiator Fan 2 (V177): Movement Restricted / Jammed
    P1951 - 007 - Short to Ground - Intermittent
    Freeze Frame:
    RPM: 1792 /min
    Temperature: 64.5∞C
    Temperature: 28.5∞C
    Speed: 48.0 km/h
    RPM: 1856 /min
    Temperature: 72.0∞C
    Temperature: 36.0∞C
    Speed: 38.0 km/h
    16555 - Fuel Trim; Bank 1: System Too Lean
    P0171 - 006 - Short to Plus
    Freeze Frame:
    Voltage: 2.000 V
    Voltage: 0.160 V
    Lambda: 10.5 %
    Bin. Bits: 00001000
    Voltage: 1.980 V
    Voltage: 0.900 V
    Lambda: 13.7 %
    Bin. Bits: 00001000
    Readiness: 0010 1001
    Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
    Part No: 1K0 907 379 D
    Component: ESP FRONT MK60 0102
    Coding: 0051846
    VCID: 33611BFF2BA5
    No fault code found.
    Address 08: Auto HVAC Labels: 8P0-820-043.lbl
    Part No SW: 8P0 820 043 B HW: 8P0 820 043 B
    Component: KlimavollautomatH11 0130
    Shop #: WSC 00000 000 00000
    VCID: 2B51039FF395
    1 Fault Found:
    00716 - Air recirculation Flap Positioning Motor (V113)
    003 - Mechanical Failure
    Freeze Frame:
    Fault Status: 01100011
    Fault Priority: 3
    Fault Frequency: 52
    Reset counter: 107
    Mileage: 186876 km
    Time Indication: 0
    Date: 2012.07.16
    Time: 15:46:39
    Freeze Frame:
    Voltage: 11.90 V
    Temperature: 21.5∞C
    (no units): 208.0
    (no units): 169.0
    Temperature: 14.5∞C
    Address 09: Cent. Elect. Labels: 8P0-907-279-23-H.lbl
    Part No SW: 8P0 907 279 A HW: 8P0 907 279 A*
    Component: Bordnetz-SG 1.0 H27 0401
    Revision: 00000000 Serial number: 00000000073834
    Coding: 018C4F00A0141000000000000000000000
    VCID: 3B7133DF03F5
    Part No: 8P2 955 119 A
    Component: Wischer WWS Audi350 0170
    Coding: 16711696
    Shop #: WSC 00000
    1 Fault Found:
    00526 - Brake Light Switch-F
    008 - Implausible Signal - Intermittent
    Address 15: Airbags Labels: 8P0-959-655-84.lbl
    Part No SW: 8P0 959 655 F HW: 8P0 959 655 F
    Component: Airbag 8.4ED H01 0130
    Coding: 0011602
    VCID: 458555277531
    Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
    Part No SW: 1K0 953 549 A HW: 1K0 953 549 A
    Component: Lenks‰ulenmodul 008 0030
    Coding: 0000012
    VCID: 306B14F3DAB3
    Address 17: Instruments Labels: 8P0-920-xxx-17-MY7.lbl
    Part No SW: 8P0 920 980 E HW: 8P0 920 980 E
    Component: KOMBIINSTR. VDO H25 0070
    Revision: D04 Serial number: 2246CD04001357
    Coding: 0004413
    Shop #: WSC 00196 210 06488
    VCID: 397D29D709C9
    Address 19: CAN Gateway Labels: 1K0-907-530.lbl
    Part No SW: 1K0 907 530 B HW: 1K0 907 951
    Component: Gateway H08 0070
    Revision: 08 Serial number: 17001035085505
    Coding: 3D0F03CA070101
    Shop #: WSC 06435 123 12345
    VCID: 2647F2ABE877
    Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
    Revision: D04 Serial number: AUX7Z0C6FN4020
    Shop #: WSC 00196 196 04543
    VCID: 397D29D709C9
    Address 37: Navigation Labels: 8E0-035-192-RNSE.lbl
    Part No SW: 8P0 035 192 HW: 8P0 035 192
    Component: RNS-E HIGH EU H46 X---
    Revision: 03S Serial number: AUZBZ7D0001797
    Coding: 0215711
    VCID: ECD34083B61B
    1 Fault Found:
    01044 - Control Module Incorrectly Coded
    000 - -
    Freeze Frame:
    Fault Status: 01100000
    Fault Priority: 7
    Fault Frequency: 1
    Reset counter: 106
    Mileage: 188034 km
    Time Indication: 0
    Date: 2012.07.28
    Time: 12:44:27
    Address 42: Door Elect, Driver Labels: 8P0-959-801-MIN1.lbl
    Part No: 8P0 959 801 A
    Component: Tuersteuerger. H09 0010
    Coding: 0000048
    VCID: 397D29D709C9
    Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
    Part No: 1K1 909 143 L
    Component: EPS_ZFLS Kl.6 0402
    VCID: 33611BFF2BA5
    1 Fault Found:
    00750 - Warning Lamp
    013 - Check DTC Memory - Intermittent
    Freeze Frame:
    Mileage: 8000 km
    Temperature: 19.0∞C
    Voltage: 11.30 V
    Voltage: 11.20 V
    Address 46: Central Conv. Labels: 8P0-959-433.lbl
    Part No: 8P0 959 433
    Component: KSG H02 0030
    Coding: 188800186D288505485AC63000
    VCID: F9FD69D7C949
    Component: Sounder No Answer
    Component: NGS No Answer
    Component: IRUE No Answer
    3 Faults Found:
    01135 - Interior Monitoring Sensors
    004 - No Signal/Communication
    00323 - Vehicle Inclination Sensor (G384)
    01134 - Alarm Horn (H12)
    Address 47: Sound System Labels: 8Px-035-382.lbl
    Part No SW: 8P3 035 382 HW: 8P3 035 382
    Component: AB2 SUBWOOFERBOXH23 0100
    Revision: 00001 Serial number: 10000001033476
    VCID: F0EB54F39A33
    Address 52: Door Elect, Pass. Labels: 8P0-959-802-MIN1.lbl
    Part No: 8P0 959 802 A
    Coding: 0000048
    VCID: 3A7F36DB0CCF
    Address 56: Radio Labels: 8E0-035-192-RNSE.lbl
    Coding: 0215711
    VCID: ECD34083B61B
    1 Fault Found:
    000 - -
    Freeze Frame:
    Fault Priority: 7
    Fault Frequency: 1
    Reset counter: 106
    Mileage: 188034 km
    Time Indication: 0
    Date: 2012.07.28
    Time: 12:44:27
    Address 77: Telephone Labels: 8P0-862-335.lbl
    Part No SW: 8P0 862 335 M HW: 8P0 862 335 M
    Component: FSE_255x BT H21 0200
    Revision: 00000001 Serial number: 00000000376393
    Coding: 0010322
    Shop #: WSC 06325 000 00000
    VCID: 408B44336A13
    End ---------------------------------------------------------------------
    Any help would be much appreciated as there does is not alot of information about specific errors on either Ross-Tech or ASN.
