first Time user checking torsion value
nokia_aid Nov 2, 2011
  1. nokia_aid
    nokia_aid Member
    ok just used my ross tech cable for the first time today,my car has an overfueling issue when its cold that im trying to find the cause,
    checking my torsion value first. and when i first start the car its at about 11 then drops down to 2.5 is that normal or should it start lower
    below is a link to a log i took
    LOG-01-004-xxx-xxx.CSV - File Shared from Box.net - Free Online File Storage
    only error code i had was
    16685 - Cylinder 1: Misfire Detected
    P0301 - 000 - -
    Freeze Frame:
    RPM: 819 /min
    Torque: 100.0 Nm
    Speed: 0.0 km/h
    Load: 0.0 %
    Voltage: 14.21 V
    Inj. Quantity: 2.96 mg/str
    Temperature: 13.5°C
    (no units): 0.0
  2. ZeeSaffa
    ZeeSaffa Member
    Did you manage to correct your torsion value?
    I have a bit of a judder at certain revs and have just found out (thanks to the help of a fellow ASN member's VCDS) that my torsion value is 3.9 (advanced).
    So, I'm going to have to do fine tune the camshaft timing as described here:
    How to adjust rough idle and camshaft timing on VW and Audi TDI pumpe duse engine
    I'm interested to know if you went through the same thing and if you have any advice?
