The history (documents) I got with my car (1000's spent on it) and the things I need to do with it since I got it, nothing new has broken since I have got it (fingers crossed) I am just finding the things that maybe an AA inspection would have found.
This is a classic car and thus needs to be looked after in that way. I think the things that have been fixed are the common things and I reckon some of the repairs were due to bad setup and driving.
Its not that bad, but I will do the rear drop links and try and get the head light levelling sensor replaced tomorrow - and check the access to anti rollbar bushes tomorrow, if that goes relatively problem free I will try and bleed the rear brakes and measure the discs. and try and check the extent of the exhaust leaks.
depending on success and weather I have front drop links and anti roll bar bushes and then would also try and bleed the front brakes too.
Additionally, I have some codes to check for the clutch switch tomorrow and take apart the glove box to see if the ABS sensor has been disturbed before I buy a new one.
I also have a new sharkfin aerial and diversity aerial amplifer - but that's not important.
Maybe because these S3's are pushing the boundries they are prone to faults due to the strain, from the docs - loads of coil packs have been purchased, several CV joints, twice as many gaitors, a gear box rebuild, electric motor for the seats and sunroof, when it is setup with a MBC @ 30 PSI I can see how it could cause damage - the immense heat generated in the engine will melt plugs etc, the massive pressure on the pipes and the aggressive turbo boost would shred a clutch.
I tried to manually move the rear headlight leveller whose bar was broken and that did nothing to the actual lights - so I reckon once I have replaced it I will discover the head light motor is shot too.
The only annoyance is there is some things I would "like" to do - nothing crazy but I cant do that if real issues keep popping up.
I love driving this car and enjoy working on it - and I have a spare car to sit in traffic with. What I don't want to do is keep it if I am not going to improve and maintain it properly.
