first start of the morning
tdi-man Aug 22, 2011
  1. tdi-man
    tdi-man Well-Known Member
    1,783
    64
    some times but not every time when starting first time in morning the first few seconds are are little lumpy then runs fine
    after that it's fine all day long first turn the key starts no probs.
    ANY IDEAS ?
    was thinking changing glow plugs ?
    no fault codes in vcds
  2. warren_S5
    warren_S5 Moderator Staff Member Moderator VCDS Map User
    7,210
    2,486
    Hard to say with the specific maps / egr delete.
    Obvious guess is air / fuel mix, so as you say, if glow plugs are old will it be as a result of map over fuelling slightly at cold start and drenching the glow plugs? Dirt in the fuel system???? When was it last serviced?
  3. tdi-man
    1,783
    64
    did it before the map glow plugs are 3 years old from gsf
  4. NHN
    29,345
    1,719
    Have you had any cold mornings to warrant plug usage, as hasnt exactly been freezing & they only get used at low temps.
  5. tdi-man
    1,783
    64
    no cold mornings here have ordered a set anyway and some fuel cleaner.
  6. NHN
    29,345
    1,719
    Assume fuel supply is fine, have you detach fuel lines 1st thing before morning start, stick pipe in a jug & get someone to turn over & see if the fuel is coming through pressured straight away or stumbles as such.
