First start and faults advise
s3gazz May 10, 2013
  1. s3gazz
    s3gazz Well-Known Member
    1,376
    99
    Hi guys well started the car today after my second engine build.
    problems I'm left with 3 faults
    17956
    17795
    17748
    Followed by Exhurst rattle wish is an easy fix.
    so went for a spin after it got up to temp 90 degree boost gauge reads -12 but checked all pipe and there's no leaks after 15 mins drive water level has dropped to nowt 3 times so topped up and then engine Managment light came on deleted the fault and went not come back could this be todo with the faults above.
    Also then another fault popped up 17705 pressure drop between turbo and throttle body em all pipe connected don't get it any help would be great thanks
  2. Dani_B19
    9,103
    344
    You checked the red elbow from turbo to charge pipe? Any air locks in system for the coolant side?
  3. s3gazz
    1,376
    99
    Don't no how to check for air locks dani pal .
    engine mani light should not come on tho should it.
    Also last time Andrew said that's how I warped the head not bleeding it ryt
  4. <tuffty/>
    20,881
    3,701
    Have you actually looked any of these codes up yet Gazz as they are fairly self explanatory...
    17956/P1548/005448 - Ross-Tech Wiki
    17956/P1548/005448 - Boost Pressure Controle Valve (N75): Open Circuit
    N75 disconnected...
    17748/P1340/004928 - Ross-Tech Wiki
    17748/P1340/004928 - Camshaft Position Sensor (G40) / Engine Speed Sensor (G28): Incor. Correlation
    Cam belt or cam chain is out a tooth or link...
    Only one I can't find on the wiki is 17795 but if you are using VCDS it will give you the description which will help you (and us) understand what it means...
    P1387/17795 - Internal Contr. Module altitude sensor error... not a VCDS description I don't think but the actual description would be useful
  5. Dani_B19
    9,103
    344
    Check all pipes are warm if not then you have air lock. Open expansion lid, put heaters on full and blower on full, hold revs at 3000 for a few minutes them check all pipes and if warm you should be good.
  6. s3gazz
    1,376
    99
    Thanks guys yes tuffty I've checked them pal and came up same as what u have posted can I ask where is the speed sensor on the car could be that.
  7. <tuffty/>
    20,881
    3,701
    Speed sensor? thats at the back of the gearbox... not sure what makes you think any of these codes are related to that... the dash would be doing odd things (speedo not working for one) if the speed sensor was iffy...
    Post the 'actual' code and description ;P
  8. s3gazz
    1,376
    99
    Ill try get em up pal copy and paste em.
    Two new things I need to add sorry 1. Hardly any brake pressure s3dave thinks I might if flipped a seal in the reservoir by bleeding with the brake pedal.
    2. Is the turbo I bought was a eBay k04 so when I went to put the egt sensor in the tred that goes into the hot side won't grip so must be a different Fred it's in there now and has not popped out yet that is a boost leak if I'm right.
  9. s3gazz
    1,376
    99
    All I could find tuffty
    Possible Causes
    Timing Belt/Chain incorrectly installed
    Timing Chain probably lengthened
    Camshaft Position Sensor (G40) faulty
    Engine Speed Sensor (G28) faulty
    Possible Solutions
    Check Timing Belt/Chain installation
    Use Measuring Value Blocks (MVB) to Check Timing Chain
    Check/Replace Camshaft Position Sensor (G40)
    Check/Replace Engine Speed Sensor (G28)
    ecu fault carnt really pin point owt apart from what tuffty posted and its somate in the ecu for shore
  10. <tuffty/>
    20,881
    3,701
    Not a different thread else it wouldn't screw in at all... chinese hotsides have a deeper EGT port and the nut bottoms out before it can tighten on the probe... I also assume you have had the wastegate ported? as you will know chinese hotsides suffer from horrendous boost creep...
    Not a boost leak... its not boost on the exhaust side, its exhaust gas... its an exhaust leak... this will potentially take energy away from the turbine and could also potentially introduce air into the exhaust flow causing issues with AFR readings
  11. s3gazz
    1,376
    99
    How would I get around fixing my prob in then tuffty this is my main issue if ground the brass thing off the prob would it go in enought to screw up u recon.
    going to take rocker cover off tomoz and see if there is 16 links on the chain inbetween the arrows as all the other timing bit is spot on Andrew fit cams so I didn't check derrr me
  12. <tuffty/>
    20,881
    3,701
    Cambelt will be a tooth out if Andrew built the head then as I doubt he got the 16 rollers bit wrong...
    Best check the timing belt
  13. Andrew@A.L.D
    3,873
    609
    16 roller when i did the head unless i made a mistake which is very very rare
    Timing belt i bet
  14. s3gazz
    1,376
    99
    Thanks I'm going to line trimming up tomoz and see what's out with rocker cover off.
    just been out and put liquid gauge on to find on idle my car is running 14 psi so somate a miss
  15. beachbuggy
    beachbuggy Well-Known Member
    1,931
    201
    Can I get a dictionary please? You make me chuckle Gaz, it takes me about 5 minutes to "get" your messages! I'm obviously far to old...
    if however it's an iPhone autocorrect then I feel your pain..
  16. s3gazz
    1,376
    99
    Lol ye dan your right iPhone **** hate it need rid of it does head in ha.
  17. s3gazz
    1,376
    99
    Just looked back at the txt god that's bad dan lol feel your pain trying to read it
  18. superkarl
    superkarl MAN OF STEEL
    9,398
    2,376
    Did you do the timing belt gazz?
    Can often be a degree or 2 out when it becomes under tension, when you have it at tdc when loose.
  19. <tuffty/>
    20,881
    3,701
    When the cam pulley is at TDC its under tension from cyl 2 exhaust springs... if not careful the exhaust cam has a habit of rotating back a tooth while trying to get the belt on...
    Its easily done and I have had this happen myself before... just need to double check and check again before pulling the pin on the tensioner damper...
  20. s3gazz
    1,376
    99
    Ye Carl pal I did it mate.
    What I did was line bottom pulley up and gear box followed by rocker cover mark and can cog mark inline turned 2 revos then checked it all again with s3dave here with me hen pulled the pin all still in line so might of move under tension but its the 14 psi on idle I'm weird about
  21. s3dave
    s3dave TFSI Hybrid Supporter
    10,110
    736
    14 in HG..
  22. superkarl
    9,398
    2,376
    So minus 14inhg. Not +14psi like gazz was saying.
    If timing is oit then vaccum will be affected. In the same way lairy cams affect it too
  23. s3dave
    10,110
    736
    His liquid gauge is saying 14psi but is obv wrong on tickover, we have sorted it now 1 tooth out....Doh..so bloody easy to get wrong when that tensioner pulls it tight..
  24. s3gazz
    1,376
    99
    Thanks Dave pal for the help and well from now on ill always keep it a tooth out so when the pin is pulled it can pull trimming into place not line it all up and the it pulls it out lol.
    took me and Dave hours so sort it one bloody tooth car drives better already and no code now great.
    just need to sort the +14.3 psi on idle out and my EGT prob now
    thanks so much for everyone's help guys
  25. badger5
    9,398
    1,943
    your egt probe..
    your siggy says> BBT new k16 7+7 blade hybrid turbo
    so whats occuring? you also say cheap chinese ebay turbo?
    I've lost track of what you are or have fitted to your car?!?!?
    eh?
    me an "well confused"
  26. s3gazz
    1,376
    99
    Soz bill the turbo I send dan was a copy eBay k04.
    now dans made me this spec
    Compressor is a 2283 sized wheel but with a 7+7 blade design. Modified compressor housing. Custom made k16 sized turbine wheel 55mm/46.5mm . a ported and modified turbine housing. Upgraded bearing kit. 15psi uprated actuator.
  27. badger5
    9,398
    1,943
    hmm. there's a reason I trust nothing CN/copy wise and always dry build stuff off the car to confirm everything fits, check threads are clean and correct depth, etc...
    you have to be one of the most unlucky dudes around with all this always happening to you
  28. beachbuggy
    1,931
    201
    The hotside had a bolt and washers in it when I got it, I left them in there. Maybe the previous owner just put any old bolt in there thus screwing up the threads inside.
  29. badger5
    9,398
    1,943
    ewww..
  30. s3gazz
    1,376
    99
    Ye that could be the problem with that nut in there damaged thread.
    well decided ill give it ago tomoz and if nothing work bung it back up and drill a hole in the down pipe and weld a boss on and put my EGT prob there.
    Car has a boost leak now and then says my liquid gauge but nothing apart from EGT prob open
  31. Dani_B19
    9,103
    344
    Wouldnt the fact that nothings in the egt probe hole cause a boost leak / vacuum leak.
  32. s3gazz
    1,376
    99
    been told this is not a boost leak pal so god nose why it's coming up with the fault pressure drop between turbo and throttle body
  33. <tuffty/>
    20,881
    3,701
    Its not a boost leak in the true sense no but as its a pre-turbine then boost will suffer as a result... this is subjective to whatever the boost request is of course...
    17705 code is also attributed to a software fault and can be coded out... chances are this is the cause and tends to happen on tuned maps more often than std maps as a rule
  34. Dani_B19
    9,103
    344
    So surely itll affect boost and vacu then paul?
  35. <tuffty/>
    20,881
    3,701
    Exhaust leak? depends... if a little exhaust gas is being leaked out of a small hole then it 'could' prevent the turbine from spinning as fast as it could if sealed and thus 'lose' a little boost capability across the rev range... with vacuum its possible that the extra air drawn in will dilute the lambda reading and confuse the ECU causing the throttle plate to open more than normal dropping vacuum...
    Either way its subjective but still should be fixed... I would only start worrying about lack of boost or iffy vacuum once the hardware issues have been resolved...
  36. s3gazz
    1,376
    99
    This morning I had a mess about with the probe nut and hey presto it screwed in. But then I did ten mile and checked it and its worked loose so what I'm thinking is crew it in again and try weld the nut to the hotside so it don't come loose. Job done if I can get to it ha .
    next thing is do I need a map update or a new map to sort the 17705 fault out and it does say on vag com check DV but its a new revised OE one so carnt be that.
    had it on my mate dyno this morning to See what's happening with fuel and its hitting 13.2 with the prob in the Exhurst bit rich I think could be the course of the white on the spark plugs.
  37. <tuffty/>
    20,881
    3,701
    13.2 is lean on power... white deposits on plugs suggests lean..
  38. s3gazz
    1,376
    99
    Sorry ye my bad lean then confused for some reason.
    That too lean tuffty or ok for now till I've done my 1000 mile and got I mapped
  39. <tuffty/>
    20,881
    3,701
    Are you running with the N75 unplugged? why 1000 miles? Bill is running Stacey's in on the dyno IIRC...
  40. s3gazz
    1,376
    99
    New engine build tuffty new rings but same bearings and arp bolts.
    would u say run in till the pal and yes n75 unplugged.
    my mate said if I go up tomoz he will put few hundred mile on it for me on the dyno what u recon won't take it above 4000 rpm
