First oil change after a rebuild
s3dave Apr 27, 2012
  1. s3dave
    s3dave TFSI Hybrid Supporter
    10,110
    736
    Just done 550 miles since my full rebuild, dropped the oil and it reeks of fuel is this normal? and when i take the oil cap off it seems to be blowing heavier than it used to...i think?
    im guessing some fuel would have got passed during the bedding in process??
    any advice welcome...
  2. S3featesV9
    S3featesV9 Active Member
    1,032
    12
    I'd just advise repeating you process and see if it still smells of fuel in another 500 miles.
    I'd take a guess at it blowing more due to the fact that the engine is fresh and oil pressure is alot better etc. This may be complete and utter bulls**t. But it's my thoughts.
  3. <tuffty/>
    21,688
    4,119
    Did you log it all while running in? are you running bigger injectors now and has the map been tweaked to take this into account?
  4. s3dave
    10,110
    736
    I've kept the standard ones in for running in, took the plugs out and there all white showing lean conditions
    no logging done yet what blocks, I assume 31 and ?
  5. s3dave
    10,110
    736
    I've had a fully rebuilt agu head put on but no transitional gasket as yet if that helps?
    Also when coming on boost there is what can only be described as fuel starvation, like just bogs
    down I have a d21 external pump to go on and may mock this up tomoz and test
  6. Prawn
    11,608
    3,584
    potentially air/fuel mix getting past the Rings during the very early stages of running in?
  7. <tuffty/>
    21,688
    4,119
    Yeah, 31... N75 disconnected etc? lean is not a good day out... what engine code is yours (can't remember)? APY is narrow band so really need to get it on a dyno with a wideband probe for that... AMK/BAM are wideband so block 31 is ok to use...
    If AMK/BAM is the EGT probe connected? shouldn't run lean unless you have been spanking it on all the boost etc... wideband will do its best to pull it to requested AFR... as long as requested AFR is right of course...
  8. Prawn
    11,608
    3,584
    has it been mapped at all Dave? If you've fitted a hybrid and high flow manifold and large port head, and you're still on the old APR map from the stock ko4, it'll be running REALLY dangerous!
  9. s3dave
    10,110
    736
    It's an apy , agu top..... I'm getting a bit worried of what it can be now
    prawn that's what I was thinking. But 500 + miles should it be blowing heavy, I can hear it from the filter on the catch can...
  10. s3dave
    10,110
    736
    No still the stage 2 apr I needed to wait for the run in for the final custom map
  11. s3dave
    10,110
    736
    Do you think I should buy my 550s in to help with the fuelling
  12. <tuffty/>
    21,688
    4,119
    N75 disconnected and std injectors should be ok... not running the boost you had previously is key... running a hybrid on K04 boost will outpace fuelling potentially...
    As its an APY logging 031 under boost will be pointless but as long as you are on actuator pressure you shouldn't outpace the std injectors...
    I had white fluffy deposits on my plugs recently and put it down to using Tesco Momentum... I know mine wasn't running lean...
  13. StaceyS3
    StaceyS3 Well-Known Member
    2,505
    502
    Oh dear I hope momentum is ok as shell left my area 5 or so years ago and then lost my local bp a month ago and generally always run mine on momentum :(
  14. s3dave
    10,110
    736
    V power tuffty not deposits glazed so obv running lean
  15. s3dave
    10,110
    736
    Any blocks usefull on apy to log ?
  16. bargi
    bargi New Member
    17
    worst case possibly blow by and bore wash. Overfueling -> Bore Wash -> Blow By -> Crankcase Pressurisati - 205GTIDrivers Forum
    I'm assuming you got new pistons? How did you break them in?
    The pistons will break in within 50-100miles and it's important to not take it too easy on them or the bores can glaze and also get bore wash Untitled Document
    500miles and fresh oil should be fine now to go run it on the dyno and get your AFR checked as well.
    Not sure of your setup, but if you've gone big power with a std fuel pump be a good idea to get the upgraded in before the dyno runs.
  17. <tuffty/>
    21,688
    4,119
    I still do mate... only garage on my way to work and the shell garages never have any v-power anyway
  18. s3dave
    10,110
    736
    I whipped the ***** from the off ..... N75 unplugged turbo trying to out spool the engine all the time
  19. s3dave
    10,110
    736
    Stop spamming tuffty ........:)
  20. s3dave
    10,110
    736
    Interesting article ... I hope mines not bore wash......would the plugs be white with bore wash?
  21. s3dave
    10,110
    736
    fuel trims are -2.4 and -3.9...
    Looking at a few cars over the weekend...(non vag) they breathe the same so i may have been a bit paranoid....:think:
  22. Westy
    Westy Well-Known Member
    17,443
    1,105
    Dave I'm at the exact stage as you now. Done 550 miles since rebuild an I dropped the oil on Thursday at around 470 miles. Oil was fine, and no smell of fuel at all. I think the sooner you can get yours mapped the better.
  23. s3dave
    10,110
    736
    Yes im going to fit the inline fuel pump and book it in today...just got a spare MAF just in case too, im going to leave my WMI kit off it for now, and just get it running fine, i dont want that fkn upsetting things...;)
