First attempt at Wet Sanding
Dubbers1 Oct 27, 2012
  1. Dubbers1
    Dubbers1 Top Gear VCDS Map User
    260
    66
    First of all I am far from a pro at this and I would recommend having a Paint Depth Gauge before attempting this
    So heres the orange peel I had on my front arches
    First I took paint depth measurements, then started off with 1200 grit then 2000 grit and finishing off with 3000 grit
    Once I was happy most of the peel was gone I polished it back up with my DA
    Once I was happy the gloss had all been restored I sealed the paint and whacked some water on it for an arty shot
    Obviously far from perfect as it was my first go ever but I am more than pleased with it, makes such a difference just looking at the car
    Comments welcome
  2. scotty76
    scotty76 Well-Known Member Team Phantom Audi S4
    2,809
    1,463
    Nice work. :) What polish did you use with the DA to bring the gloss back?
  3. Dubbers1
    260
    66
    Thanks, I tried quite a few but I think i ended up with Meguiars 105 on a wool pad and then some Menzerna PO85RE to refine
    Threw in some 3M Fast-Cut Plus at some point too
    Would of been a whole lot easier with a Rotary but I've not stepped up to the big leagues yet
  4. Greeny233
    Greeny233 It's all about the V8. Team V8 Team Silver Audi S4 Audi Avant Owner Group
    1,094
    383
    Very very brave! Well worth it though, looks so much better.
  5. Wax Attack
    Wax Attack Member
    57
    Nice work, looks much better.
    Simon
  6. Acheron
    Acheron Active Member
    271
    30
    Nicely done! Very brave indeed. I still get scared everytime I use my DA...wetsanding would just push me over the edge :p
  7. Dubbers1
    260
    66
    Thanks guys, was a bit of a squeaky bum exercise but now I've done it it wasnt all that bad
    Very time consuming but I was taking paint measurements and wiping it down every 2 seconds to make sure I didnt go too far
  8. DeanG
    DeanG New Member
    Great results, just bought some 2500 grade sand paper for our s4 as well. Where did you paint depth gauge from?
  9. Dubbers1
    260
    66
    Where did I get it from or where did I measure?
    If you're using 2500 grit I hope you have a Rotary because it took a long time getting the gloss back from 3000 grit with my DA, could have just been me though
  10. willowsdad
    willowsdad Sideways
    1,027
    32
    Nice work mate. Had that wing been resprayed? Normally only see orange peel like that on bmw's! Cracking results though.
  11. Dubbers1
    260
    66
    Yer I think both of them have seen paint, must have been an all round **** job though cos I think they both have rust bubling up from the wheel well
  12. scotty76
    2,809
    1,463
    That's why I asked what polish you'd used. I always assumed it would be impossible to get sanding marks out with a DA on Audi paint. :) Very nice work. I wouldn't have the bottle for it!
  13. Dubbers1
    260
    66
    Just go for it mate, results speak for themselves, just go careful near the lines and edges, use lots of water and clay lube (I also added some ONR)
    Worst comes to worst and you cant get the marks out, someone will be able to, for a few bob
  14. Neilb1
    Neilb1 Member
    178
    no iy is no impossible with a DA as long as you work up to 2500 or 3000 wet sand you will be ok, I use a varaity of Menzerna cut and various polishes and top it of with Zano z3
  15. DeanG
    DeanG New Member
    I'll be using my rotary with 3m fast cut and then go onto using their finer compounds. Any recommendations on measuring the thickness of paint?
  16. Neilb1
    Neilb1 Member
    178
    you need a paint depth gauge fella not cheap as well, this is one of the cheap versions
  17. Dubbers1
    260
    66
  18. 666markyboy
    666markyboy Well-Known Member
    1,200
    49
    Does a paint guage not just tell you the thickness down to metal ??? whats to stop you cutting into the base coat or worse still the primer ??? or can they measure individual paint coats ??
  19. Dubbers1
    260
    66
    You are right, the ones like mine only measure to the metal but you can get ones that measure each coat and they are MEGA money
    The sort of rule of thumb is that you measure the exterior paint surface then take a measurement from inside the door shut or engine bay and subtract it, therefore you have a rough guide of how much clearcoat that you can remove safely as doorshuts receive less clear coat than the exterior
    Obviously this is not a sure fire method especially with resprayed panels, just a rough limit than you can try to stay above
  20. 666markyboy
    1,200
    49
    I guess if it's only orange peel your doing then as long as you don't go much lower than the lowest points of the peel effect then you should be fine... if that makes sense lol
  21. Juicy Jen
    Juicy Jen Jen @ Juicy Detailing Site Sponsor
    828
    121
    The other thing to point out is if the panels have been resprayed the thickness is more than OE paint so you do have more to play with.....do you have any closer pictures like the original ones to show that the sanding marks are gone? Glossing up the paint and fully removing the sanding marks are two different things tbh.
    Just concerned others jumping at this and thinking its easy
  22. johnnythepie
    johnnythepie Well-Known Member
    2,242
    75
    Wouldnt have to go through all this if audi didnt have shyyte paint.Mine looks like a fecking greengrocers window!
  23. johnnythepie
    2,242
    75
    Quite.Need proper lights to show everything up I guess.I hate my paintwork as its very peely, but im dangerous with a da let alone a sander!
  24. Juicy Jen
    828
    121
    I know what you mean I've wet sanded the front driver wing on mine and I personally think it looks the best bit on the car now lol...its just having the time to do it all!
