First Aid Kit
mhill Mar 23, 2009
  1. mhill
    mhill Member
    323
    Just found the draw under the drivers seat (perfect fit for my Road Angel Professional) but i though this was only there if you ordered the first aid kit, so im now left thinking have the dealers piked the kit? ive just tried using http://igorweb.org/equidec/Default.aspx to decipher the codes in the front of the service book but there is no mention of any of the optional extras that came factory fitted!
    E4J = "S-line"
    7A0 = Without CD changer/CD player
    4UF = Drivers and front passenger air bag with front passenger air bag deactivation
    6X0 = Without entry grab handle
    5SJ = Left exterior mirror: convex
    5RU = Right exterior mirror: convex (large viewing field)
    1KZ = Disc brakes, rear
    J1L = Battery 280 A (60 Ah)
    1LJ = Disc brakes, front
    1AT = Electronic stabilization program (ESP)
    3FA = Without roof insert (standard roof)
    UA3 = Rear shock absorption
    G34 = Front shock absorption
    5TL = Decorative inserts in piano lacquer
    7X0 = Without park distance control
    4R4 = Power windows with comfort operation andcircuit breaker
    F0A = No special purpose vehicle, standard equipment
    8GU = Alternator 140 A
    0YE = Weight range 5 installation control only, no requirement forecast
    L84 = Suspension range 84 installation control only, no requirement forecast
    TD6 = 4-cylinder gasoline engine 2.0 l unit 06J.D
    3NZ = Rear seat bench unsplit, backrest split folding
    8BP = Bi-functional headlight with gas discharge lamp
    U1B = Instrument insert with mph speedometer, clock, tachometer and trip odometer
    X2B = National sales program Great Britain
    1N3 = Speed-related variable steering assist (Servotronic)
    2PF = Leather trimmed multi-function sports steering wheel
    8Q3 = Automatic headlight-range adjustment dynamic (self-adjusting while driving)
    9Q2 = Multi-function display/on-board computerwith check control
    SZ5 = Identification of "Budget" vehicles
    D2L = 4-cyl. gasoline engine 2.0 l/147 kW 16Vturbo FSI, homogeneous Base engine is T59/T61/TQ2/TU2/TD6/TN6
    7Q0 = Without navigation device
    F18 = Alloy wheels 7.5J x 18
    7K0 = Without tire pressure warning light
    4X3 = Side air bag front with curtain air bag
    3L3 = Manual height adjustment for front seats
    VW1 = Side windows tinted green, from B-pillarto rear window gray tinted safety glass
    3Y6 = Sun screen for rear window
    4K2 = Radio remote controlled central locking "SZV"
    5D1 = Carrier frequency 433.92 MHz-434.42 Mhz
    1SA = Without additional engine guard
    UG0 = Without hill hold control / hill descentcontrol / comfort driving assist
    7MG = Emissions concept EU5
    QG1 = Service interval prolongation
    4GQ = Windshield in heat-insulating glass
  2. evapor8
    evapor8 Member
    458
    I have little drawer ... but no first aid kit in mine.
    Chris
  3. edition
    edition Active Member
    1,426
    Mine is empty also :)
  4. ianspibs
    ianspibs Member
    119
    I think its standard on the drivers seat whether you have a first aid kit or not.
  5. B17AVM
    B17AVM The Whoa
    107
    I thought Audi put their First Aid kits in the boot?
    I didnt get one any how!
  6. MarcQuinlivan
    MarcQuinlivan Active Member
    2,539
    9
    これで、ここでは、少数の歴史と語ったが必要だ 無名の英雄 この土が削除されます ある人は、継承はされています 造幣局からの輸入 人々の多くがないのにネウルエウンイ 事実、この老いたहेごみमेरे 彼は帽子にゴミ収集した これは、うわっイレオルスがズボンです そして彼は、フラットに住んで協議会
    彼は'真のनानाである 大きな皿の後に起動チクヒギル 彼はउन्हें得ることができる職業を持って 彼は根が何उन्हेंデイジー電話
  7. liam
    liam waiting, waiting, waiting
    171
    :icon_thumright:
    Although, we did have to buy the kit and warning triangle aftermarket. I bought the kit from a US retailer and the triangle was a freebie the guy I am about to order an S3 from.
  8. mhill
    mhill Member
    323
    You never know who is lurking and watching!!!!!!:salute:
  9. royjk
    royjk Member
    167
    Think you will find the draws are part of the storage pack.
  10. Nelson_R32
    Nelson_R32 Member
    305
    Indeed ;)
    The First Aid Kit is a £25.00 factory option on the A3. The First-Aid cubby hole is always there by default in case you want to retrofit it (about £40.00 iirc)
  11. mhill
    mhill Member
    323
    Is it easy enough to fit the draw the other side?
  12. Nelson_R32
    Nelson_R32 Member
    305
    The seat needs to be unbolted and the parts cost around £95.00 last time I checked which personally is money I'd put towards a Luggage net. I personally never thought my A3 was lacking in the storage space front especially with the Centre Armest etc.
  13. mhill
    mhill Member
    323
    Luggage net?
  14. B17AVM
    B17AVM The Whoa
    107
  15. Recy G
    Recy G New Member
    25
    I don't have a drawer :ermm: but then I have got buckets :moa:
    wuta3 and s3reptdi like this.
  16. edition
    1,426
    The drawer should be lined though in some soft material. Anything you put in them rattles.
    I HATE RATTLES!
  17. Silky-S3
    Silky-S3 Is loving his new 8V S3!
    1,407
    343
    Can some one post up a eBay link to the proper A3 one? Loads of different ones on eBay!
    Cheers :)
  18. s3reptdi
    s3reptdi Member
    179
    Id also like to know what they looked like that came in a3 8ps, as said loads of audi ones on ebay and i know they all do the same job but id like the one it should have, anyone know?
  19. s3reptdi
    s3reptdi Member
    179
    Anyone?
  20. phil_w
    phil_w Active Member VCDS Map User Team Brill Red Audi A4 Audi Avant Owner Group S-line owners group
    606
    58
    Like a big fat red sausage
    wuta3 likes this.
  21. s3reptdi
    s3reptdi Member
    179
    That doesn't really help to be honest
  22. ramp1990
    ramp1990 Member
    81
    13
    I only found the draw other day when i was hoovering the car out :/ had the car two months now
  23. phil_w
    606
    58
    Told you...
  24. s3reptdi
    s3reptdi Member
    179
    Thanks mate, is there a brochure on all the optional extras like that that can be bought, I don't mean like Bluetooth etc
  25. Ste_Nova
    Ste_Nova Active Member
    1,223
    47
    first aid kit is allways optional
    mine is in the rear armrest like this
  26. Ash187
    7,520
    758
    I may have a drawer for the drivers side up for sale if anyone is interested?
  27. s3reptdi
    s3reptdi Member
    179
    Is it possible to fit a drawer on the passenger side?
