Hi all I'm new to the group and am very happy to join you, to share our knowledge.
I have a problem though I have found a place that can provide a convertor for the Sat Nav + older version (not RNS-E) the cdrom based. I found out need a vag-02VID conversion If you want to add an external AV source. I have also found out that you can cut the GALA wire if you have a multi function steering as this does not use the GALA so therefore I will go and cut this off as the Sat Nav does already take a long time to update. The only problem that I'm faced with is to find an ignition 12V source, I do also know that the Audi S3 or even A3 for that mtter uses the Can-Bus system. Can anyone help here as I'm new to Audi's but good with In-car systems, I'm glad to be part of this group as I've come from the BMW world, and Audi's are much better.
