Finaly fitted my wideband AFR gauge...
S3 Paul Sep 30, 2011
  1. S3 Paul
    S3 Paul Well-Known Member Regional Rep
    2,823
    107
    Well, ive had it a year now, i decided the weather was good enough for me to have a crack at fitting it,
    Im about to go out for a drive, What Numbers should i be seeing?
    The car has a hybrid turbo,
    decat 3 inch down pipe and miltek system,
    FMIC
    Jetex air filter
    other bits and bobs...
    I understand Vag cars run lean when starting to make boost whats safe and what shows a possible problem??
  2. <tuffty/>
    20,873
    3,698
    Normally go a bit lean to help boost but should then plummet to mid 12's (0.85 lambda) on boost for best/safe power
  3. S3 Paul
    2,823
    107
    I think i read somewhere something about ...
    11.8 to 12 on boost?
    cruising should show around 14.7 to 15?
    high 12s on cold start??
    I think that was for a mapped TT so should aply??
    Just another gauge to make me paranoid !
  4. <tuffty/>
    20,873
    3,698
    12.5 afr on boost mate... any richer kills turbine energy and power will drop... should help keep egt's down too...
  5. <tuffty/>
    20,873
    3,698
  6. S3 Paul
    2,823
    107
    Thanks buddy
  7. S3 Paul
    2,823
    107
    Well something i didnt expect...
    When the car is on over run ( reving down in gear down hill ) the AFR reading goes to full lean. 22.4
    Im guessing the injectors shut off ? They come back on again at 1200 rpm or the slightest touch of the throttle.
    Makes sence but a little wierd the first few times it happens.
  8. DaveA3
    DaveA3 Audi A-Trizzle!
    2,370
    15
    so what were the other readings all good?
  9. S3 Paul
    2,823
    107
    Ye, I will make a note of them later, But a mate who knows a thing or two about tuning turbo cars said its all good.
    Im not sure wether the figures should be the same on all cars but... good and safe will do me !
  10. <tuffty/>
    20,873
    3,698
    Yep.... let off the throttle with the clutch engaged in gear etc and injectors switch off... the ECU does this to help fuel economy...
  11. camscockle20vT
    camscockle20vT The stigs ugly brother
    1,740
    77
    Do you know if this is on all the 1.8 20v T mate?
  12. S3 Paul
    2,823
    107
    I seem to think its only on the later drive by wire cars?
    I may be wrong though
