Finally, I have accepted my need for bigger brakes....
Welly Sep 3, 2012
  1. Welly
    Welly VX220 SC Driver :)
    10,696
    129
    As title, many of you will now be glad to hear I have decided it's time to put some bigger anchors up front.
    I have now warped my 6th pair of discs this year....(various brands tested) which has made me decide to change them. So far that's approx £720 in discs this year. Seems daft when you look back... lol.
    Am in the process of buying some Leon Cupra Brembos.
    I thought that, before I go and whang more power through it, I may need to turn my attention to stopping a bit better.
    Peer pressure has won. Eventually.
  2. Prawn
    11,583
    3,552
    Well thank the bloody lord for that! about time Wellyboots!
    One question though: do you really think you'll be able to stop any quicker with bigger brakes? Surely the wanli sunny ling long ditch finder pros will stop you from actually pulling up any faster?
  3. Welly
    10,696
    129
    I'll have you know my Event tyres are actually impressively good to be fair.
    Also, to be honest, no I probably won't stop any faster anyway - the single piston slider OEMs actually stop me very quickly - they just eat the discs doing it sadly.
  4. superkarl
    superkarl MAN OF STEEL
    9,554
    2,453
    Budget tyres are good for the hollywood effect, squeeling, fact.
  5. Reesy
    Reesy Well-Known Member VCDS Map User
    3,640
    148
    Great news Welly, and I can now say the LCR's are a very nice upgrade.
    Next thing to peer pressure you in to is good tyres and 500+bhp.
  6. aragorn
    18,491
    855
    Warped disks are usually not warped at all, but the result of uneven pad deposits forming hard areas on the disk surface...
  7. Welly
    10,696
    129
    My straight edge on my last 3 sets says different.
  8. jojo
    28,935
    3,588
    Hang on a minute son!:superman: .... does that mean bumble is staying now then? :salute:
  9. Welly
    10,696
    129
    Until early next year, yes. The I really need to consider my options.
  10. Reesy
    3,640
    148
    You always say this.
    Not a lot of point selling it really, you won't get anything near what it has cost.
  11. Welly
    10,696
    129
    Agree, however it costs astronomical amounts to run, and maintain...
  12. Reesy
    3,640
    148
    What happened to the 106?
  13. Welly
    10,696
    129
    The 206 beast? Still have it, but it's a nail to be fair. Not sure I want 2 cars either.
    Considering changing to the dark side and buying a supercharged E46 M3.
  14. aragorn
    18,491
    855
    Your straight edge might, but the "warp" isnt usually from the metal bending, its from uneven pad deposits causing harder areas of steel to form in the disks surface, which then wears at a different rate.
    Tell tale signs are pad outlines visible on the disk surface.
    Have a read of this:
    -Warped- Brake Disc and Other Myths
  15. Welly
    10,696
    129
    Interesting....
    However, the bottom line remains the same.... they no longer work as brake discs and require replacement. :(
  16. aragorn
    18,491
    855
    Yes, but if you read the article you'll see that you can avoid it from happening by bedding the brakes in properly, and not holding the car on the brakes when they are hot.
    The fact that you've done n sets of disks over the last year suggests to me that you keep doing the same thing to them to cause the pad deposits. If you dont fix whatever it is thats causing the deposits, the issue will probably continue on the brembos.
  17. Welly
    10,696
    129
    Thank you for your input there Kev. Have you considered going on mastermind with your specialist subject being stating the obvious?
    I am well aware of the fairly simple brake bedding procedure, which I do complete with every new set of discs. Religiously.
    I also deliberately use the handbrake when stationary following any heavy stopping to traffic lights for example. Religiously.
    I feel that, rather it being my ineptitude with regard to my ability to operate brakes, it may be my driving style which causes the issue. Which is fine, and I accept. Stopping for a set of traffic lights on a private road from upwards of 140 MPH a few times a week does tend to have an adverse effect on brake discs.
    Having said that, I know that deep down you only have my best interests at heart... :wub:
  18. Welly
    10,696
    129
    Anyway, we digress.
    Reesy, you're running the LCR setup now aren't you? Thoughts?
    What brake fluid did you use?
  19. superkarl
    9,554
    2,453
    E46 M3? Yoouuuuu SCUMBAG
  20. Welly
    10,696
    129
    What can I say? I like them!! lol
    Not decided yet - so don't paint me with the Clarkson brush just yet...
  21. Reesy
    3,640
    148
    Yes I am mate. A really noticeable difference. More responsive for general driving and a massive improvement when braking down from triple figures over 2 or 3 dual carriageway to roundabout sections.
    Only used some basic fluid mate as didn't get time to order any of the rbf stuff, but seems to be fine.
    Not as snatchy as I imagined they would be, but this is a good thing. And they look good too.
  22. Reesy
    3,640
    148
    You'll be a raspberry within 2 weeks in a RWD car.
    It's a shame, but it'll happen.
  23. Welly
    10,696
    129
    Also, on the list is an 8P S3, maybe an S4 Cab, or tempted with an A5 TDI...
  24. Westy
    Westy Well-Known Member
    17,443
    1,105
    Ling Lang ditch finders make driving the S3 interesting. My braking has definitely been effected dramatically since fitting Info tyres.
  25. superkarl
    9,554
    2,453
    welly, do you reallllly think an M3, an S4 and an 8P S3 will be significantly cheaper to run to justify selling bumble??
    keep the old girl, even if she's locked in a hive most of the time, you'l have a constant semi knowing she's there and can use her on special occasions.
  26. sportquattro
    sportquattro Active Member
    845
    51
    Im probably missing the point and if I am I apologise but if you're thinking of selling the bumble early next year on the grounds that shes costing you a klondike, why spend a small one on uprated brakes?
  27. Welly
    10,696
    129
    No, thats a fair question. A few things, but mainly because otherwise she will feel unfinished to a certain degree. That may seem a bit daft, but I also want to up the power and cant justify doing so on the current brake setup.
  28. Sam_
    Sam_ Down under
    3,038
    480
    Was going to post that link haha. Many people will sit on the brakes after a long braking stint which won't help matters...
  29. Sam_
    Sam_ Down under
    3,038
    480
    Gotta love Fawlty Towers
  30. badger5
    9,543
    2,022
    or just maybe.... just maybe..... 440bhp and 312mm disks on a 1500+kg S3 driven by his "Wellyness" (welly by name, welly by nature) is simply over heating the one piece disks/pads etc etc etc
    312mm disks will never dissipate the heat well enough = damage
    Pretty obvious in this scenario
  31. marktdisport
    marktdisport Active Member
    1,195
    15
    I brad a lcr few years back running performance friction pads and I could not get brake fade...expensive but superb aswell
  32. Welly
    10,696
    129
    Good spot there mate :thumbsup:
    'The next contestant is Sybil Fawlty from Torquay, special subject, the bleeding obvious'.
  33. Sam_
    Sam_ Down under
    3,038
    480
    Quality show. Even the aussies here "get it" which is rare...
  34. s3clarke
    s3clarke Money grabbing s3!
    677
    35
    private road with traffic lights? :yes:
  35. Welly
    10,696
    129
    Yeah, a specialist racing one.... lol.
  36. s3clarke
    677
    35
    sounds interesting ;)
