Finally got my s3 back ... but doesnt seem as quick ?
motfree Jan 25, 2011
  1. motfree
    motfree Member
    464
    Hi peeps ..
    Finally got my s3 back today after getting a new engine put in ..
    I bought an AGU block and put all my parts over from my broken APY motor ..
    Havent adjusted the actuator but just doesnt seem as quick at all .. but showing that its only boosting 10psi ( didnt have a gauge previously )
    just seems wierd that nothing has been adjusted that it feels that different
    anyone got any ideas ?
  2. S3KO4
    S3KO4 Member
    850
    is it mapped? agu has big port right! so the map you had would vary slightly to your small port.
  3. motfree
    motfree Member
    464
    Oh right so the only way really is to put the apy head on the agu engine ??
    I was told wouldn't make any difference .. So will it be ok if I just turn the boost up ?? Or do I need a new map ?
  4. aragorn
    17,872
    686
    The engine should have turned the boost up by itself.
    You should at the very least have it checked on a dyno to ensure the fuelling is correct for the large port head though
  5. Blackcupraa
    Blackcupraa Member VCDS Map User
    183
    13
    Are you using the same ECU or the ECU from the donor engine?
  6. motfree
    motfree Member
    464
    Well previously was boosting at 18psi so must be something up .. So I need to put it on a dyno ?? Or just turn the boost up on actuator ?
  7. motfree
    motfree Member
    464
    Old ecu .. Been doing alot of research about this before I've done this and been told that engines are identical apart from injectors , turbo , and map :-S
  8. aragorn
    17,872
    686
    You need to find out whats broken. Actuator doesnt need touched at all, ever.
    AGU has a large port head, your old engine has a small port one. AGU also has a higher 9.5:1 compression ratio compared with 9:1 in the S3.
    None of these things would take the boost pressure down from 18psi to 10 though, theres something else going on.
  9. motfree
    motfree Member
    464
    ok so vag-com best way ?
    didnt previously have boost gauge by the way just felt like it had abit more umph haha if that makes sence
  10. badger5
    9,305
    1,885
    n75 valve on the right way round?
  11. motfree
    motfree Member
    464
    ill try that now .. just looked at the gauge and seems to be sticking to 6 / 7 psi which ive been told is standard psi ?
  12. motfree
    motfree Member
    464
    just been out can only fit on 1 way ... put checked connectors and theyre fine .. but thread on actuator is literally only about 1" threaded any idea how much should be for 20psi as this is what the car was mapped to ??
  13. Broken Byzan
    13,235
    464
    Sounds like limp mode to me, Have you checked for codes?
  14. motfree
    motfree Member
    464
    nope not yet but dash doesnt have any lighs on :-S !!
  15. Broken Byzan
    13,235
    464
    that is not a given for limp mode. Have a look when you get a second, i am sure it will shed some light on the subject
  16. motfree
    motfree Member
    464
    oh thought a light came on .. might just take it to get pluged in tomorrow morning ...
  17. motfree
    motfree Member
    464
    by the way does it matter that ive put the apy engine n75 valve on ? or should it be the agu n75 valve ?
  18. aragorn
    17,872
    686
    You should be running the APY valve, but they're probably the same anyway.
  19. motfree
    motfree Member
    464
    Going to order one of those vag com things off eBay .. As I'm baffled about this one and the mass airflow meter is 2 months old so don't know ..
    My mates convinced i just need to turn the boost up ( thread actuator in more )
  20. s3dave
    s3dave TFSI Hybrid Supporter
    10,110
    736
    Try running it carefully with the actuator hose off.... dont belt it and see if your boost increases...
  21. aragorn
    17,872
    686
    The Actuator opens at 5psi.
    If you thread it in too much, you'll get boost creep.
    The ECU controls the boost using the N75 valve etc. So long as theres enough preload to hold the actuator closed it will be fine.
    No-ones touched the turbo, so why are you convinced it needs adjusted?
  22. motfree
    motfree Member
    464
    That means that the boost will just go really high though won't it ?? Or will it only go as high as the actuator is threaded ??
    Is this to see if it's the turbo stopping it from boosting over 9psi or if there's a fault on a sensor eg n75 valve or something ?? As if it boosts Upto like 20psi like it did must be sensor must it ?? I'll try that tomorrow
  23. Welly
    Welly VX220 SC Driver :)
    10,696
    126
    Bolting an AGU engine is, and having it setup the same way, with the same boost, should make the car feel exactly the same, if not a little quicker. That was what I experienced with mine.
    If you were running 18 PSI, and are now running 10, that would certainly explain why it doesn't feel as fast - less torque simply.
    The engine is simply the engine, it bolts in and works. Thats not to say that a sensor somewhere has been damaged in the transfer process - easily done.
    You need to go out and log it with VAG COM really to investigate what the requested vs actual boost is.
  24. badger5
    9,305
    1,885
    confirm which pipe goes where on your n75..
    long tail goes into tip, boost goes into middle off charge pipe, and the other one goes to wastegate actuator
    your boost pressure appears to be wastegate pressure only, which if plumbed wrong could be your issue.
    std boost is 9-12psi on S3's
    check electrically it works in vagcom, output tests
