Finally! booked in for AMD Stage 1
dik Jan 26, 2006
  1. dik
    dik Member
    127
    To say I am excited is an understatement... am booked in for saturday morning at 9.30 for a stage 1 RR Remap..
    Heres looking for 265+!! and all that torque 350nm+ hopefully
    Anyone else from here up there on the 4th Feb (a saturday).?
    A BIG BIG thank you to WAK for organising the map for me.
    /ubbthreads/images/graemlins/beerchug.gif
  2. marctwo
    marctwo Member
    410
    Well done. I am sure you will love it!
  3. Ryanc
    Ryanc Active Member
    1,321
    What about revo?
    If i was starting again it would be either jabba remap or revo with sps3
    or apr
  4. dik
    dik Member
    127
    I`m not sure about revo, I wanted a smoother delivery out of the extra power, alot of people have said that the revo chip is too harsh early on so that put me off first.
    Also I wanted a rolling road session to get the chip 'tuned in' so to speak.
  5. Ryanc
    Ryanc Active Member
    1,321
    how about apr then?Amd would be last on my list,well next to those one-man guys.How about mrc(minhea) also meant to be good.
  6. simonelman
    simonelman Member
    78
    He is not good
    but very very good.
    SimonS3
    MRCtuned
  7. dickys3
    2,963
    23
    Nothing wrong with the AmD map Ryan...
    Very smooth imo.
  8. Ryanc
    Ryanc Active Member
    1,321
    what boost are you running dicky?
  9. dickys3
    2,963
    23
    [ QUOTE ]
    [/ QUOTE ]
    Cant remember exactly but approx 1.45 bar peak.
    Why do you ask?
  10. Ryanc
    Ryanc Active Member
    1,321
    Just Interested.
  11. jojo
    28,942
    3,597
    Ryan, what we call an AmD remap is in actual fact a Sportec remap AFAIK. I've not had any problems with my stage1 remap, peaks at 1.4-15, then drops to just over 1bar. You can possibly question their service of late, though I've not had a bad experience from them myself, but their Stage1 remap is tried and tested by many, including myself.
  12. Ryanc
    Ryanc Active Member
    1,321
    What about imola's 1.1bar remap and i believe there was a few others.
    Anyway if your happy thats good most of the remaps are 1.4/1.5 to 1/1.1 .
  13. S3Steve
    S3Steve Active Member
    1,621
    20
    Now I see where the extra power on a Jabba remap comes from. After i had mine done Mike told me its peaking at 1.6bar and holding 1.4bar. Still well pleased with the results. /ubbthreads/images/graemlins/groovy.gif
  14. Ryanc
    Ryanc Active Member
    1,321
    hi steve,
    Not totally sure but i don't think a k04 can hold 1.4 till redline.Glens probably better to ask on this sort of thing .
  15. dickys3
    2,963
    23
    [ QUOTE ]
    hi steve,
    [/ QUOTE ]
    I thought that too Ryan...
  16. Ryanc
    Ryanc Active Member
    1,321
    Yeah i'm sure it's 1.1bar or something,it just runs out of steam.
    I would have thought mike meant 1.6 overboost to 1.4 then tappered to 1.1 at 6200.
    If you ever want to meet up steve i'l plug my vag-com in and log your boost for you.
  17. Ess_Three
    Ess_Three Active Member
    5,383
    [ QUOTE ]
    hi steve,
    [/ QUOTE ]
    It can't...
    I had mine basically flat out...way off the top of the ECU boost control and MAP sensor reading range...and although it could possibly have produced more than 1.85 bar peak...the decline in pressure was soon back on the compressor curve, with the compressor spinning flat out...and I couldn't get mine to hold more than 1.2 ish bar at the redline.
    Bearing in mind that at 1.0 bar at the redline, my standard IC'd car was seeing inlet temperatures of 78 degrees AFTER the ICs...there is no way a car on standard ICs could even run at 1.4+ bar boost from a K04. The inlet temperatures - assuming the hoses hadn't melted - would ment the engine internally.
    To run at much over 1.0 bar boost with aggressive timing needs either a big turbo, or some very special (efficient) ICs on a K04.
    With 2 x bespoke ICs (one a front mount), re-jigged IC pipework, de-restricted turbo outlet pipe, N75 and an aggressive map I could make over 1.2 bar sustained at the redline...but the turbo was spinning faster than it should have...and to be honest had become a hot air pump long before that. Hence the need for very special ICs..
  18. Ess_Three
    5,383
    [ QUOTE ]
    [/ QUOTE ]
    I would think so too...
  19. Ess_Three
    5,383
    [ QUOTE ]
    [/ QUOTE ]
    One quick look at your boost curve will reveal all...
    Or alternatively, the peak boost value and revs...and the peak power at the wheels value and RPM...
    If you are making 1.6 bar boost...you are getting 310-315 lb-ft of torque from a K04...assuming the ignition timing hasn't retarded so far it's shut the engine down...or the engine let go from massive inlet temperatures!
  20. Ess_Three
    5,383
    [ QUOTE ]
    [/ QUOTE ]
    This was the same re-map that had a torque graph showing 299 lb-ft of torque?
    From 1.1 bar peak...
    I think not.
    Imola S3 and I drove my S3 and his back to back...with mine in 305 lb-ft mode....and it was night and day in terms of performance.
    His was making 1.1 peak...mine 1.5+...
  21. S3Steve
    1,621
    20
    [/ QUOTE ]If you are making 1.6 bar boost...you are getting 310-315 lb-ft of torque from a K04...assuming the ignition timing hasn't retarded so far it's shut the engine down...or the engine let go from massive inlet temperatures!
    [/ QUOTE ]
    Just going off what Mike told me when I picked the car up. He definately said it was peaking at 1.6bar. The torque figures from the rolling road was 416.6nm which if my calculations are correct is 307lbft,
  22. S3Steve
    1,621
    20
    [ QUOTE ]
    [/ QUOTE ]
    Maybe your right mate, still the main thing is how it drives on the road and I'm well happy with the way it performs. /ubbthreads/images/graemlins/groovy.gif
  23. Ryanc
    Ryanc Active Member
    1,321
    Yep,Sounds like the most that can be squeezed out of a standard s3.
    What is the limiter on the s3 as mine has been raised to 7200 i believe.
