Fiat Punto gt conversion setup
Munch Jan 12, 2013
  1. Munch
    Munch Member
    256
    23
    Hey all,
    I know its not audi, but thought someone maybe able to find a use for it.
    I have for sale a complete conversion setup for any mk1 Punto (or any other car if your feeling brave enough)
    It was removed from the last Punto gt project that I broke due to dreaded chassis rot. The engine itself has only covered 55k miles, so very low. When it was fitted into my car, it ran perfect, idled fine and pulled like a train.
    Turbo is immaculate also, no movement in spindle and no cracks in the hot side.
    For the money you will get:
    1.4 8v turbo engine 55k miles (turbo is rock solid and pulls hard)
    Brand new cv joints
    Brand new ngk plugs
    Front mount intercooler with custom silicone hoses
    Baileys dv26 dump valve
    Driveshafts
    Ecu / wiring loom
    Fuel pump
    Engine will come complete and ready to bolt up. The engine has also had the power steering pump removed, so if you are fitting it into a sporting or just replacing the broken engine in your gt, you will either have get a replacement pump and belt, or I can supply a non power rack and column shaft
    I will also include all the custom water lines, brand new header tank, Powerflow custom exhaust, dr evil decat and any other pgt parts I have
    Looking for £400 for everything but will accept sensible offers.
    I'm needing this gone asap as its currently taking up space on the girlfriends mums drive
    Engine is located in Braintree, Essex
    Many thanks
    Ben
  2. Munch
    Munch Member
    256
    23
    Will accept swaps for a3 performance parts, coilovers, agu engine
