Few small faults: Any info??
Y83OLK Jan 10, 2010
  1. Y83OLK
    Y83OLK Hulk Smash!
    841
    Hi All,
    Ive had a few small faults with my s3 recently, just wondering if anyone can shed some light for a DIY repair... or weather i need to take it to a specialist.
    *ESP light came on, and stayed on for my whole 2mile trip.. switch didnt effect it either, Vagcom showed brake light switch implausable signal and brake pressure solenoid valve?.
    brake lights still work and code/fault hasnt re-appeared for a week.
    *Cold start i get a squeel from the rear of the car,sounds like fuel tank area or possibly near wheel well under the car... a bit like a slipping belt noise, stops after a few seconds??
    *Cold start i get a tapping (quite loud) from under the bonnet...above the drivers wheel arch. Evap filter full?..need emptying?
    *N/S mirror glass wont demist?.. new glass required? or can it be repaired?
    Any help appreciated.
    Callum
  2. Terrier QTS
    Terrier QTS Member
    41
    Does the squeel happen when you have air con off as well? If not then this is a fairly common fault, mine sometimes does the same. Just just make sure the air-con is turned off before starting.
    The tapping sounds like the carbon filter, perfectly normal and nothing to worry about.
    Sounds like to need a new mirror glass, but it might be worth just checking the fuses I guess.
  3. Y83OLK
    Y83OLK Hulk Smash!
    841
    erm..im not sure, i i have the CC on most of the time... it sounds like the back of the vehicle though;
    backbox, boot floor, fueltank area..
    Are the mirrors fuse independantly?
    cheers
  4. Terrier QTS
    Terrier QTS Member
    41
    not sure about the fuses, check out what it says on the back of the fuse bay cover
  5. Barks
    Barks Member
    337
    I had the same problem with my n/s wing mirror, there is not a seperate fuse for seperate mirrors, so if one is working the fuse is fine.
    The mirrors & heating element are £30 from Audi I got mine from ebay for £16
    http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=260440319499&ssPageName=STRK:MEWNX:IT
    When removing I used 2 decorating knives top and bottom, with some masking tape to protect the paint, then slowly easy off.
    The heating element spade terminals may be a little corroded on, WD40 can help with this.
    I think the element had a high resistance it measured 140ohms the new one was <5ohms (check it with a multimeter)
    Hope this helps, takes around 5 mins
  6. btmotorsport
    btmotorsport Soon be christmas!!!!!!!!!!
    164
    Poss the little lock that slides over to secure the filler flap?? Open the flap then lock the car and see if it happens!!! Keep meaning to grease mine but never get round to it!
  7. Y83OLK
    Y83OLK Hulk Smash!
    841
    Hi all.
    Sorry to raise my post from the dead.
    Since i made this thread, i have renewed the n/s mirror glass and renewed the brake light switch....this cures 2 faults.
    however, i still have the squeel on startup.
    Ive eliminated the SAI (amks dont have them) its not a door lock or fuel flap.
    It squeels for 4-5 second on cold startup and im stumped for ideas?
    thought possibly:
    *Air con compressor clutch? - theres a bit of orange rust here, but does it come on during startup?
    *Cracked turbo housing? - as it warms closing the crack??
    *Air leak?
    Has anyone else had this/ know a resolution?
    Callum
  8. rusty s3
    rusty s3 Member
    64
    could it be the startermotor still engaging?
  9. Y83OLK
    Y83OLK Hulk Smash!
    841
    Thats an option too, I guess the starters pretty similar to the mk4 golfs though... but its a completely different sound to when they stay engaged.
  10. Dani_B19
    9,382
    403
    Where did you get the glass from mate? Was it easy todo? Need todo mine.
  11. jonny87
    jonny87 Active Member
    1,094
    when was your haldex last serviced?
    maybe a touch low on oil/dirty clogged oil so when the pump primes its struggling?
  12. Y83OLK
    Y83OLK Hulk Smash!
    841
    December i think.. not too long ago, shouldnt be too low, i use the whole tube of grease with only minimal spillage.
    Dani, i got the glass from TPS, around £30 trade.
  13. jonny87
    1,094
    grease? im hoping you meant oil??
    well shouldnt be that then, fuel pump, have you checked that?
  14. Dani_B19
    9,382
    403
    Ok thanks.
    Whats it like to fit, just a case of popping the glass off like said? Or is it more invloving than that? What do you do once the glass is off etc?
  15. Y83OLK
    Y83OLK Hulk Smash!
    841
    Jonny - Its more of a thin grease than an oil. Comes in a caulking gun type tube.
    Dani - yep, pop the old one off, disconnect wires then pop the new one on.
