Few questions to ask ?
Bradderz_1988 Jul 26, 2011
  1. Bradderz_1988
    3,995
    262
    Right before I get round to fitting the FT I would like some answers on a couple of questions.
    So,
    1. I'm going to drain the coolant when I remove the front end, is there any bleed screws on the cooling system or is it a case of taking the expansion tank cap off and reving it up for 10 mins.
    2. Is there any other gaskets I need other than these gaskets ? - exh manifold, turbo to manifold, turbo to cat, oil return (is there one either end of pipe?) have I missed anything ? Also list of part numbers if pos please.
    3. Also going to change my fuel filter what washers do I need? part numbers please.
    4. When charging the turbo with oil (will be new oil with a new filter) with the ICM disconnected how long cranking ... 5 secs ?
    And anything I may need to know when replacing it with it being my first Audi.
  2. AR-rkon
    AR-rkon Mod back in a "B" Staff Member Moderator Regional Rep Team V6 Team Silver Audi A6 Audi A4 Audi Avant Owner Group
    1,913
    166
    Hope it helps some...
  3. Bradderz_1988
    3,995
    262
  4. AR-rkon
    1,913
    166
    fuel filter: 2x N 0138149 one either side of the banjo (feed Side) and 2x N 0138128 on the output. (was looking at APU engine, yours is AWT?)
    As for the exhaust, according to the diagram im looking at, it shows what looks like 4x seperate gaskets. BUT after searching the part no online it shows it to be a one piece gasket :blush:
  5. Bradderz_1988
    3,995
    262
    Mine is an AJL. So it's got fuel tank setup for quattro but maybe the same washers as an APU.
  6. B5QUAT
    B5QUAT Member
    317
    13
    Are you doing the turbo swap yourself mate?
  7. aragorn
    18,665
    880
    Rconn: His is a quattro. Different fuel tank arrangement to FWD cars. Those numbers look correct though.
    Sorry for editing your post, i meant to hit reply with quote lol.
  8. Bradderz_1988
    3,995
    262
    Yes I will be doing ive been in motor trade for 5 years as a tech for Peugeot/Citroen just I'm not used to these over engineered german tanks lol as I've rarely worked on them apart from your general oil services and brakes etc. I'm going to do it at work so If out goes pear-shaped I have the resources/equipment/other techs to help me out, but I've done full engine swaps on the likes of relay/boxer vans so can't be as bad as engine swap.
  9. aragorn
    18,665
    880
    1. Theres a drain plug on the bottom of the radiator, and a little pipe fitting you can stick a hose on.
    4. I'd do longer than that. Take the spark plugs out, so the bearings arent under any load, and disconnect the crank sensor (stops the injectors squirting), and use vagcom to watch the status of the oil pressure switch.
    Once the switch goes to "OK" i'd wind it over for another 10 seconds or so just to ensure the turbo line is purged of air.
  10. Bradderz_1988
    3,995
    262
    I don't have vagcom aragorn but with your knowledge what would you say time wise In cranking 30 secs an also where is the crank sensor located ?
  11. aragorn
    18,665
    880
    The crank sensor runs to a grey plug just underneath the coolant tank.
    You REALLY need to get yourself vagcom, especially when taking on something like fitting this turbo, as it will be invaluable in diagnosing any issues. Get yourself an ebay lead for a tenner.
  12. Bradderz_1988
    3,995
    262
    Cheers mate no where you mean now the lambda ones there aswel iirc ?
  13. Bradderz_1988
    3,995
    262
    Will this cable do ??
    Item - 270781684323
  14. aragorn
    18,665
    880
    yeh lambda and knock sensors are in the same place. Knocks are blue and green.
    Cable looks fine.
  15. B5QUAT
    B5QUAT Member
    317
    13
    Oh right no worries, was gonna say if you need a lift with anything, I'm local enough, and 2 heads are sometimes better than one, but sounds like you got it covered.
  16. Bradderz_1988
    3,995
    262
    Yeah i should be ok just if work dont let me do it they can be ***** sometimes but im guna try and do it when i have the week off at the august bank holiday so If anything goes pear shaped I have time to order anything I need and get a lift home if needs be lol But cheers for the offer anyway mate.
