Few pointers please, is everything in the right place?
Lavis89 Jul 7, 2012
  1. Lavis89
    Lavis89 Well-Known Member Regional Rep Team Sprint Audi S4 Audi A3
    1,757
    598
    Basicly im getting a 007/8p to replace the stupid VTA D/V i got on there, problem is i brought this car premodded so not really sure if everything is in the right place, my best guess at the mo is i need to connect a hose between the 2 red circles, or is it easier to move the D/V somewhere else?
  2. <tuffty/>
    20,847
    3,687
    No mate... the outlet at the back of the engine is essentially the same as the coldside relocation the previous owner did... the outlet of the DV needs to go to the TIP... that will have been blocked off too but can't see it as your engine cover is on... remove that and it should be obvious...
  3. Lavis89
    1,757
    598
    ideal i'll have a looksy tomorrow, cheers
  4. <tuffty/>
    20,847
    3,687
    As std it should look like this...
  5. Lavis89
    1,757
    598
    that confuses me a bit :/ so the outlet on the side of the forge (where the trumpet is on my current D/V) gets plumbed into my TIP? does that need some sort of adaptor? it looks on your photo like it's plumbed into where the blank is fitted on my car
  6. <tuffty/>
    20,847
    3,687
    The pic above is how its supposed to be... there is a blank in the metal charge pipe from the turbo as the previous owner has cobbled in what you currently have...
    You should find a blank in the TIP too...
    Your choices are... fit it back in the OEM position as per the pic above by removing the blanks in the metal charge pipe and the TIP and connecting as per above by either sourcing an OEM hose or using a suitably sized 90 deg silicon bend and a suitably sized bit of hose with joiners as needed... you then remove the valve from the alloy 'T' piece and blank that off..
    Or... replace the existing valve with the 007p (boost goes in the side of the valve not the bottom) and buy enough suitably sized hoses and joiners etc to plumb it back to the TIP leaving the blanking plug in the metal charge pipe...
  7. Lavis89
    1,757
    598
    thanks very much, knowledgeable as always, think it's going to be much much easier for me to find a oem hose and stick it back in it's proper place! that shall be my job for next weekend.
