few electrical problems anyone help
britpop95 Mar 8, 2013
  1. britpop95
    britpop95 New Member
    22
    if i take my battery of my 2002 a4 avant my radio never needs coding allso the display on the dash keeps constantly flashing that my water bottle is empty and my pads are worn but the bottle is full and new pads all round and both pluged in any help much appreciated as i am at a loss
  2. Andie0
    Andie0 Member
    490
    13
    Have you tryed taking car for a drive seeing if they dissapear? Whe. I take my battery off the abs light doesnt go out until ivebtaken it for a drive about a mintue in and it goes out!
  3. britpop95
    22
    these lights have been on for months now
  4. Andie0
    Andie0 Member
    490
    13
    Then clear the codes if they come back your sensors on the brake pads could be dirty? Give them a clean at the connections, if doesnt work replace! Same thing for the sensor to water bottle?!
  5. stu_m
    stu_m Well-Known Member VCDS Map User
    1,440
    have you had cruise retro fitted? one of the pins need to be grounded if you havent got the washer level sensor the wiring could be loose or not grounded
  6. britpop95
    22
    thanks for your replies anyone any ideas on the radio
  7. Andie0
    Andie0 Member
    490
    13
    Radio doesnt have to be coded, if theres not a problem dpnt try and fix it!
  8. Cabbyfan
    Cabbyfan Active Member
    840
    34
    Radio is coded to car so as long as same unit goes into the car you shouldn't have to enter the code.
