Ferodo DS2500 Brake Pads
DJ-S3 Mar 12, 2013
  1. DJ-S3
    DJ-S3 Active Member
    690
    43
    Is it me or are they nearly impossible to find for a Audi S3 8P?
    I've only found one site, surely there must be more than just one site....?
    Also i am right in thinking there a direct replacement for my originals and won't throw any warnings on the dash?
    Just trying to find some new pads as mine have started sqeeling like mad now.
    Dom
  2. MrLapou
    MrLapou Well-Known Member
    1,233
    121
  3. S3AMK20VT
    S3AMK20VT Member
    170
  4. DJ-S3
    DJ-S3 Active Member
    690
    43
  5. S3Alex
    10,826
    4,820
    Just moved from DS2500s to Mintex 1155s here,and along with new rotors,much improved brake feel.
  6. MACCAA
    MACCAA New Member
    29
    Been using them for years on the front of my 2008 S3.
    Part number is FCP1765H
    Len
  7. DJ-S3
    DJ-S3 Active Member
    690
    43
    MINTEX M1155 PADS - Discount Prices at Motorsport World
    Would those be for my car? It seems that a lot of brake pads don't have a selection for my car. How weird!
  8. S3Alex
    10,826
    4,820
    The 1155s may be a bit beyond what you want,but finding the correct pads for the S3 is a bit of a pain...
  9. DJ-S3
    DJ-S3 Active Member
    690
    43
    Yeah been looking at the 1144 which seems more my car.
  10. DJ-S3
    DJ-S3 Active Member
    690
    43
    Just been to check the pads (with a tiny mirror from the other half) before i spent over a hundred pounds and the fronts look fine. Quite a lot of pad left until the groove around the pad. The rears don't look to have much, if anything left. Infact I can't see a groove. Looks like its the rears. Just going to put oem on the rears as they don't do much of the braking.
    I am a bit confused though as it sounded like the squeeling was coming from the fronts rather than the rears... Only ever made a noise when I applied the brakes. I've done loads of reversing to make sure it wasn't a pebble or grit but it was still there. Think I'll have to get someone to stand outside whilst I pull up next to them. See what they say.
  11. bigal23
    bigal23 Member
    208
    do the mintex 1155 squel much and the ds25500?
  12. S3Alex
    10,826
    4,820
    In a word....No.
    Ive used the following on my car:
    Stock pads with stock brakes....OK,but fade fairly rapidly.
    EBC Redstuff and stock brakes....awful....squeal like pigs and no improvement in braking.
    Ferodo DS2500 pads and VWR brake kit...generally much better than stock but lacking feel....no squeal though
    Mintex 1155 pads and AP rotors...much better feel,no squeal either
    KentKid likes this.
  13. Lukus87
    Lukus87 New Member
    13
    Glad ive come upon this, i've just had my service and my brakes were cooked so ive had them changed. I gave them free range just with the instruction to improve them. They've fitted EBC slotted disks and Redstuff bads and as above the squeel like a b****. Its done my head in after a weekend of driving where do i stand in asking them to replace the pads with something thats not made out of crackling?
  14. S3Alex
    10,826
    4,820
    I'm sorry you got this problem as well.
    Mine were properly fitted and adjusted and squealed from day one,even after a further attempt by AMD to shut the bloody things up.
    I was truly glad to see the back of them,but if I were you,I would go back,get them to drive it,and hear for themselves before they try to say it's acceptable.
  15. DJ-S3
    DJ-S3 Active Member
    690
    43
    Just been to buy some rear brake pads and my reg plate came up with two types of brake pads. One with a spring on the top of it, and one without... I bought the one without, hope I'm right?? I can take it back if not.
  16. KentKid
    KentKid Active Member Team Ibis TFSI Owners Group Audi S3 Manual
    179
    74
    Thanks for this Alex.
    I'm booked in with AMD next Monday to have my brake pads replaced.
    I'm getting the Mintex 1155 brake pads up front, with standard Mintex brake pads rear.
    A friend of mine with a tuned Ford Focus ST recommended getting EBC Yellowstuff brake pads all round, but after reading your comments on the Redstuff brake pads, I think I'll stick with getting the Mintex brake pads...
    S3Alex likes this.
  17. Rom
    Rom Member VCDS Map User
    443
    A little bit ot....
    But fitting my S3 brakes, I noticed the pads are the same as my standard tdi pads. In the sense they are the sane size, and fit.
    I'm assuming material conpound is different?
    Anyone ever looked into this? Do they list 2500 for tdi, same part number? Cost?
  18. MACCAA
    MACCAA New Member
    29
    S3 pads are remarkably similar in appearance to ordinary Golf/GTI pads but they're not the same.
    I've even seen catalogues that list them as being the same,or don't list them for the S3 at all.
    I've had "experts" tell me they are,but ,trust me they're just different enough to jam in the caliper......
    The correct front pad [FERODO 2500] is FCP1765H.
    The Golf/GTI pads are FCP1641H from memory.
    You should be able to cross reference other brands from this.
    Len
  19. S3Alex
    10,826
    4,820
    Hi there.
    The EBC things just did not work for me,but I know some people like them.
    The Mintexs seem just fine on the brake setup I've got,and I hope it does as well for you.
