Feed cables behind climate control
MikeSel^ Aug 18, 2010
  1. MikeSel^
    MikeSel^ Moderator Staff Member Moderator Team Navarra TFSI Owners Group Gold Supporter Audi S3 quattro Manual
    1,153
    614
    Hello I am trying to feed some cables from the back of my stereo to come out from the back of the 'coin tray' under neath the climate control unit.
    I have my Parrot mounted there, but currently I have the cables feed through the side towards my steering column and then back in through the grab handle hole.
    Ideally I would like this to come straight down the back.
    I have remove the plastic cover from the back of the tray and I can see two bolts. Surely it can't be that simple..?
  2. mike foster
    3,967
    If you remove the radio unit then the climate control panel just hinges forward and pops out.
    This should give you easy access down the back to feed the wires through.
    Hope this helps
  3. MikeSel^
    1,153
    614
    Cheers Mike
    I will give that a go at the weekend. I now have an xcarlink to fit as well :)
  4. NHN
    29,577
    1,779
    Do you have ashtray or the storage cubby hole fitted?
    If ashtray, then there is a trim that kinda blocks of that area & needs removing to get to the back
    If its the cubby hole then you may also need to remove a trim that kinda covers the bottom of the climate control to gain access to that area.
    Radio out of course, but no need to remove the climate at all.
  5. VWAddict
    VWAddict Member VCDS Map User
    656
    9
    Also... Different for single-DIN and double-DIN setups.
    Worth mentioning.
  6. aristides
    aristides Member
    550
    My climate unit wont pop forward if i dont loosen the knee-triangles around the center console
  7. MikeSel^
    1,153
    614
    I dont have an ashtray I have a cubby whole. I can remove the trim, but it doesn't give much room to work\feed cables.
    It's a single DIN unit.
    I'll have another go today hopefully and see what I can do.
  8. NHN
    29,577
    1,779
    Its very advisable when trying to remove climate, to push the top silver climate slips downward, cause if they ping of they can become lodged in the center console & that means either you risk leaving it there & a rattle when driving or you have to remove the whole lot to get it out.
  9. aristides
    aristides Member
    550
    When i did the cubby hole retrofit i had to remove the knee triangles or the trim wouldn`t fit.
    After i put everything back together i wanted to do a quick job behind cause i had some rattle, but the AC unit wouldnt drop since i had screwed the triangles too firm :)
  10. mike foster
    3,967
    Sorry to pinch thread a minute but Aristides, does that steering ecu support mfsw ?
    Can't remember and can't find thread !!
  11. NHN
    29,577
    1,779
    Ah now I get you, knee triangles, sorry you mean the center console arms, arms shouldnt stop that coming out tbh, I was referring to those bloody climate fixing clips, real pita they are.
  12. aristides
    aristides Member
    550
    Sorry mate its off my 2008 and only supports Cruise!
    :End off topic: :)
