  1. gaz4410
    gaz4410 Member
    57
    JUST PURCHASED A 201O TTS FLAT BOTTOM WHEEL
    COULD ANYBODY TELL ME HOW TO REMOVE THE STANDARD MFSW. AND REPLACE WITH THE NEW ONE.
    CHEERS
    GARY
  2. mike foster
    3,967
    If you do a search using mfsw you will find a thread on fitting one. Flat bottom will be the same.
    Presumably you have the airbag with the new wheel and it is suitable for the airbag ecu on your car?
  3. hades-
    9,482
    646
    it cant be done
    sell it me :racer:
    theres 2 torx screws that holds the bag on forgot the size
    look behind wheel at 3 and 9 oclock
    then theres a big torx in the middle
    prety easy
  4. jungleman
    jungleman Well-Known Member
    2,035
    42
    and that your car is an an 8P2 and not and 8P1
