FBMFSW Question
Highwayman Jun 14, 2008
  1. Highwayman
    Highwayman Member
    141
    I have the FBMFSW fitted on my new S3 without a phone pack and the 'Mode' button on the wheel doesn't seem to do anything :mad: . According to the manual it should allow me to switch between CD/Radio/Phone, so I assume that without the phone pack it should still work for CD/Radio. Can anyone confirm that this is correct please?
    Thanks in advance!
    Phil
  2. Issac Hunt
    1,162
    The MODE button will only switch between the phone and the currently selected audio source. Changing between audio sources is not possible.
  3. MarcQuinlivan
    MarcQuinlivan Active Member
    2,539
    9
    Yeah, the MODE button doesn't work unless you have the phone prep. I was with my dealer twice because the manual says it does. I was told that the manual would be updated!
  4. Highwayman
    Highwayman Member
    141
    Thanks guys :) . Oh well, looks like it will be a bit redundant then :( .
    Phil
  5. Issac Hunt
    1,162
    It will only ever be any use if you fit the bluetooth kit. Sadly there is no known way to activate this button to do what we would like it to do!
  6. Twizzler
    Twizzler Active Member
    493
    37
    For those with the Audi Nav system the right button does have a function if you have Traffic announcements set to on when in the map screen. The TA replaces the map with a screen showing the radio station supplying the message. Pressing the button cancels the message and returns the map screen. It's a total waste of a button that could have been used to mute the sound!
  7. Marcyboy
    Marcyboy Member
    119
    Hence the name 'mostly for show wheel'
  8. Issac Hunt
    1,162
    That depends on the options your car has I guess. Mine has Bluetooth and SDS. The MFSW is excellent and I wouldnt be without it.
