Faulty Thermostats
Trev241 Apr 13, 2011
  1. Trev241
    Trev241 Member
    245
    After getting over the water pump issues I now find out that thermostats are failing on V6 engines (workshop campaign 19H3).
    The document suggests that potentially faulty units should be changed immediately.
    Problem is that on the S4 the supercharger has to be removed which makes me a litttle unhappy, booked in for Monday.
    Suggest everyone checks with their dealer to see if they are affected.
  2. Necroscope
    Necroscope Member
    254
    FFS.........
    Thanks Trev.
    SC off, not happy to say the least!
    I will let you know about my car after the dealer rings me back. What was the build date on yours again?
    Phil.
  3. Necroscope
    Necroscope Member
    254
    Yep i need my thermostat replacing. To say that i am p***ed off is an understatement!
    Jan 2010 build date for those interested........
  4. VRStu
    VRStu Just Looking VCDS Map User
    1,073
    That's a bit annoying on such a new car.
    Looks like the guys in the US that had Water Pump and Thermostat are getting the drivetrain warranty extended to 100k miles. I wonder if the UK owners will see that.
  5. Trev241
    Trev241 Member
    245
    My build date was September 2009.
  6. Necroscope
    Necroscope Member
    254
    My guess would be NO, but then what would that actaually cover that might fail outside of the usual 3 years?
  7. S4 Phantom
    S4 Phantom Member
    32
    WTF!! We are paying £40K plus for the car and it suffers one issue after another. It is definitely not what I expect from any Audi nevermind the S4 which is highly praised by the press. Mine was built in Aug 2010. It appears I escape from the water pump glitch. Awaiting to see how the thermostat problem unfold.
  8. yargnat
    yargnat A3 3.2 DSG
    37
    Hah - My waterpump failed while I was taking the S4 to have the gearbox looked over.
    They have just fitted a new gear DSG gearbox, to cure the problem (pullaway very jerky when in stop-start traffic for a long time), and I was also informed they changed the thermostat. Starting to regret this...............................
  9. Necroscope
    Necroscope Member
    254
    German engineering doesnt seem to be what it once was........
    This the most expensive car i have brought, its also already had more serious problems than any other car i have owned. I wonder whats next :(
  10. Trev241
    Trev241 Member
    245
    My thoughts exactly.
