faulty temp gage
S3_Pricey Nov 21, 2006
  1. S3_Pricey
    S3_Pricey Member
    302
    hey all, i have a 2000 A3 1.8T and the temperature gage only works intermitantly. When it is working it isnt above normal operating temperature but then it just stops and registers cold. If anybody could shed any light on the problem it would be great? also is it something i should be worried about?:sos:
  2. jesters3
    jesters3 Active Member VCDS Map User
    1,516
    Could be a dodgy temp sensor. I have the same prob at the mo. Fluctuates from 70 to 90 but never goes above. Mate has got VAG.COM so will hook up to that to check. Only a £10.00 part and time to fix.
  3. S3_Pricey
    S3_Pricey Member
    302
    cheers, that puts my mind at rest abit, will get it checked out
  4. dultanur
    dultanur all promises, no action :)
    407
    checking air con. no:49 will tell you if its the sensor or the gauge.
