Faulty sensor maybe in less than a month!
wesley Nov 16, 2009
  1. wesley
    wesley Giac Extreme+!! Lovin it
    350
    23
    Hi all, i recently got an error code on vag com saying that the G62 sensor was faulty, basically the top error of these 2. I changed what i thought was the sensor which is just behind the throttle body. The car is an A3 03 plate 2.0 tdi. Can anyone confirm if the sensor i changed sounds like the correct one? Thanks in advance.
    Address 01: Engine Labels: 03G-906-016-BKD.lbl
    Part No SW: 03G 906 016 G HW: 028 101 136 4
    Component: R4 2,0L EDC 0000SG 7641
    Revision: 12345678 Serial number: AUX7Z0C7FN50KD
    Coding: 0000072
    Shop #: WSC 06435 000 00000
    2 Faults Found:
    16502 - Engine Coolant Temp. Sensor (G62): Signal too High
    P0118 - 000 - - - Intermittent
    Freeze Frame:
    RPM: 798 /min
    Torque: 26.0 Nm
    Speed: 0.0 km/h
    Load: 0.0 %
    Voltage: 14.29 V
    Bin. Bits: 11000100
    Temperature: 37.8°C
    Temperature: 27.9°C
    18359 - Radiator Fan 2 (V177): Movement Restricted / Jammed
    P1951 - 000 - - - Intermittent
    Freeze Frame:
    RPM: 1176 /min
    Torque: 196.0 Nm
    Speed: 29.0 km/h
    Load: 54.5 %
    Voltage: 14.21 V
    Bin. Bits: 11000000
    Temperature: 54.0°C
    Duty Cycle: 9.6 %
  2. wesley
    350
    23
    also ive checked the fans and they both work and spin very freely, anyone had this or know of anything else i can check, thanks in advance?
