faulty fuel pump symptoms
nazS3 Oct 31, 2012
  1. nazS3
    nazS3 Member
    339
    Hi guys
    my s3 amk 2001 has problem starting from cold currently, turns over fine just wont fire
    i can hear the pump priming when ign is switched on
    got it started for few mins then it cut off again, & wont restart
    no fault codes at all, have fuel, have checked/replaced pump relay made no difference
    so could it actually be the pump in tank, as car has done 129k now
    thanks in advance
  2. <tuffty/>
    21,679
    4,106
    Does it do this on a full tank? this normally happens when the tank is half way or less full... pressure drop occurs and takes a turn or two to get it back up enough to fire..
    Fuel pump can be tested with a fuel pressure gauge and a dyno... you can also log what fuelling is doing using VCDS to see if the pump is struggling under load/boost as the revs rise...
  3. karl210
    karl210 Member
    324
    Ive got a feeling my fuel pump is running out of puff at high rpm, what blocks would need to be logged? thanks
  4. nazS3
    nazS3 Member
    339
    to be honest, car has approx tenners worth of fuel in it from empty tank
    & is parked on a slight incline driveway, car is currently off rd
    so cant fill up
    do you think low fuel is the cause, as i have no fault codes & can hear pump priming
    could the cts also be a posssibilty ? even though normally if the cts is faulty i would def get a code
    & only have problems starting from operating temp
