faulty fuel gauge
martyn brooks Sep 6, 2009
  1. martyn brooks
    martyn brooks New Member
    22
    hi have a 2004 tdi c5 4b model a6 ..my problem is fuel gauge shows half full when ignition is on/ engine running. when i put diesel in it rises . but when it returns to just below half yellow petrol warning symbel flashes to indicate empy .and when i turn ignition off fuel gauge goes to zero with all other gauges ,,is this a faulty gauge or fuel sender in tank??? has anybody had simular problems or can any body help with some advice or how to fix ?? all advice and help would much appreciated
  2. adamss24
    adamss24 Well-Known Member
    4,578
    402
    Is that a quattro model ? The quattros have a split chaimber tank(due to the way the go over the propshaft) and as such they rely on a lift tank to supply the main pump with diesel. Chances are that the lift pump does not work and as such the main chaimber gets empty and it flash the warning light even if the other half a tank is full. It will cost you a few quid though: £250 + for the pump, dealer only !
  3. martyn brooks
    22
    thanks for your reply .. my car is not quattro just single fuel tank? hope you can help again
  4. Cockney Boy
    Cockney Boy Member
    483
    Sounds like a faulty sender unit.
  5. martyn brooks
    22
    had mechanic look at sender unit and he said it looks fine and that i have infact got half at of diesel .so took car for a run and sure enough yellow petrol light lit up and bleeped when it went down to bang on half full on gauge ??? could this still be the sender unit or as mechanic thinks that the gauge is working but the petrol light coming on may be something to do with the ecu which may need reseting with vagcom or simular??? all help and replys will greatly apreciated
  6. Cockney Boy
    Cockney Boy Member
    483
    It's either going to be the sender unit, or the gauge, The sender unit is the easier of the two to change, so thats where i would start.
