Faulty coil packs?
deana4 Aug 4, 2012
  1. deana4
    deana4 New Member
    29
    Just wondering if I have a faulty coil pack on my a3. Could a faulty coil pack just make it run bad but not on 3 pots.
  2. kite
    kite Member VCDS Map User
    677
    Faulty coils are a recall.
    Contact your dealer to see if your car is affected.
  3. <tuffty/>
    21,689
    4,119
    Faulty coil packs cause missfires... if you aren't having missfires then chances are coil packs are fine...
    Define running bad?
  4. deana4
    deana4 New Member
    29
    Lack of power on lower revs seems to be worse when car gets warm. Sat at idle and rev it hard it seems to die and then pick up if you just rev it a little bit it's fine. So basically under more throttle it lacks power. I have had a check for split pipes but can't seem to find any. 2002 auq
  5. <tuffty/>
    21,689
    4,119
    Ideally you need to get the car scanned for fault codes as a start... this could give clues or even the answer to your issues... I would then double check the pipes under the inlet manifold as splits are always easily spotted... get a smoke test if you can as this will show up any splits etc easily..
    Is the idle a bit rough?
  6. deana4
    deana4 New Member
    29
    I had a scan done and get pressure drop between turbo and throttle which I would say was a leak. Tried 3 Dv,s so I know it's not that. Thermostat also needs doing.
    I had a problem with it running rough on idle but it's not done that now for months.
    Im currently running with a forge split-r dv as it runs a lot better with this on, when it has the standard one on it runs really bad.
