Faulty ABS wiring loom
vangoo
four wheels on the ground
scotland
Hi all had my car in to Glasgow Audi on monday to replace break pads as the warning light came on about a month ago
They had the car for about half an hour and came back to say the pads were fine and the problem was a faulty ABS wiring loom
Just wondering if any one has heard or experienced this problem. Just before i go and spend the £170 they quoted me
Cheers Gary.
mostly likely the wires are damaged going to the brake pad sensor, it's a common fault and a simple enough DIY job if you don't mind getting your hands dirty. You could either repair the broken wire, or buy a new harness. I would think the harness is around £60 as I sure they will have an hours labor rate for the repair.
Depends where you repair it, audi do a crap job sometimes, ask Marcrostheblack user on here, I repaired his, that was passenger front, it took couple of hours as its right down in below battery, because doing a repair in the arch liner is just asking for water ingress, so I did in the bay, its limited space & bit fiddly, but been fine ever since, the audi repair just was terrible.
Cheers guy will maybe get a chance to have a look this weekend
