Fault Diagnosis time.... (We all love this)
Welly Jul 21, 2011
  1. Welly
    Welly VX220 SC Driver :)
    10,696
    127
    OK, so let me give you the basics...
    Loud humming, grindy sound which gets worse with speed. Definitely a rotational noise.
    Minorly affected by turning whilst driving. Not affected at all by dipping clutch, coming out of gear etc etc. If the wheels are doing over X speed, then she's humming.
    Naturally, you would think wheel bearing, as I did. But it's not. Just changed the bearing yesterday and refitted to find the noise worse than before....
    I know what I think it is, well, one of three possibilities. I just wanted other opinions....
    Discuss.
  2. DaveA3
    DaveA3 Audi A-Trizzle!
    2,370
    15
    CV joint perhaps? Driveshaft?
  3. Welly
    10,696
    127
    Interesting... Based on symptoms, which CV would you think, inner or outer?
  4. Westy
    Westy Well-Known Member
    17,440
    1,097
    Have you checked the brake discs/pads for strang wear patterns?
  5. Dane
    Dane Had an 8L S3, a B5 RS4 now I have a B8 S4
    4,083
    181
  6. Welly
    10,696
    127
    Yeah, but nothing unusual there. Brakes are old, and do need replacing however they shouldn't be causing the sort of din I can hear.
    Hmmmm, 50% chance = no chance. It's more likely to be the inner I think...
    If it is the inner CV though, I suspect it will fall apart upon removal, judging by the noise it's making.
    Failing that, it could be an out of shape tyre, or the box.
  7. Dane
    4,083
    181
    Anything obvious on the propshaft? downpipe rubbing or anything?
  8. Welly
    10,696
    127
    Not that I could see, that is however, a good point.
    I must admit it doesn't feel like it's coming from that area, but I shall have a look none the less...
    It would be sooooo easy to find on a ramp me thinks. All you would have to do is knock it into gear and drive it to like 40 mph in the air.
  9. Westy
    17,440
    1,097
    Diff/haldex?
  10. Dane
    4,083
    181
    Nah that would be obviously coming from the back
  11. ScottD3
    ScottD3 I want your faulty electronics Supporter Team V6 quattro Audi A8 Team Akoya TDi saloon Audi S8
    15,161
    1,121
    get under it and wiggle some of that TT drive shaft, see if there is play.
    I'd go for CV joint and i'd opt for outer as well, since its happening when turning.
    Whats the 3 possibilities?
  12. Welly
    10,696
    127
    Nope, deffo front.
    Messing about with the driveshaft to remove and refit the hub has made it worse which makes me think a CV joint is a possibility (as it's been disturbed).
  13. Westy
    17,440
    1,097
    No visible splits in the CVs? grease caked everywhere?
  14. Welly
    10,696
    127
    It's not just happening when turning dude, it's happening all the time. Turning, straight, simply all the time.
    I mean this noise/vibration is enough to make the dash rattle at 50 mph...
  15. Welly
    10,696
    127
    Over looked good. Inner did have a small amount of grease when I put my hand down there, but I didn't inspect as I was sure it was the bearing!! lol
  16. Welly
    10,696
    127
    I reckon that (in order of likelihood):
    1) Inner CV joint
    2) Gearbox
    3) Out of shape tyre
  17. ScottD3
    15,161
    1,121
    Sounds a bit like a tyre fault.
    jack one side up and check the tyre.
    when you're at it check for any other play or movement.
    I had a bad tyre on my A4 and it caused vibrations enough to make the satnav unreadable.
  18. Welly
    10,696
    127
    OK, that's useful to know. I guess the easy test is to swap wheel front to back on the driver's side.
    Ten min test.
  19. Westy
    17,440
    1,097
    Try your S3 wheels on the TT mate. Might be wheel balancing issue?
  20. Welly
    10,696
    127
    I don't think so mate, not with the level of noise it produces. Yes, vibration, but wheel balancing producing noise??
    Out of shape tyres make a right din though.
  21. ScottD3
    15,161
    1,121
    I hate out of shape tyres.
    Bought a set for the pug just before the MOT, nasty little rumble/whine, MOT guy advised me of a out of shape tyre, went back to tyre place and 2 new tyres fitted and balance. car drove and sounded so much nice.
    and like you said, its only a 10min job and you can check other possible faults at the same time.
  22. Welly
    10,696
    127
    Whilst I agree, and out of shape tyres are a pain, the volume of the noise being created is mad. I would expect the tyre to be square.
    It is VERY loud.
  23. Lee172
    Lee172 GT3071
    430
    Can you get a video of it?
  24. Welly
    10,696
    127
    Yup, I think I will later on just so that everyone can hear it. It's easier than trying to describe it.
  25. DaveA3
    2,370
    15
    outer (wheel side) if its on steering slightly. Any splits or anything on inner or outer?
  26. Lee172
    Lee172 GT3071
    430
    I always thought outer cv's tend to make clicking noises when they're on the way out.
  27. Welly
    10,696
    127
    I guess I didn't explain very well. It's ALL the time, but the sound is altered very slightly by steering wheel adjustment. Only a slight change in the pitch.
  28. Welly
    10,696
    127
    Yeah, outers are easy to diagnose. Reverse in a tight circle and listen.
  29. ScottD3
    15,161
    1,121
    Welly, I found a solution to your clunk and rumble
    I'll got back to the pub.
  30. Welly
    10,696
    127
    lol, the amount of time I said that about the S3....
  31. Sandip
    2,438
    90
    I reckon it could be 2 things
    1. Dodgy tyre as mentioned
    2. Power steering fluid ok?? Possible that the steering rack is leaking on the seals??? (you won't have any visible sign of fluid on the floor ;) )
  32. DaveA3
    2,370
    15
    now i see why it could be inner.
    Also following the tyre thing sandip said above are the balancing plates still on there? Ive had some come off in the past that completely ****ed up everything
  33. Welly
    10,696
    127
    I didn't really look at much else to be fair as I thought it was the wheel bearing.... D'oh.
  34. Westy
    17,440
    1,097
    Well, I think you should come back once you've checked the car properly :p
  35. Welly
    10,696
    127
    Guilty as charged.... lol.
  36. s3dave
    s3dave TFSI Hybrid Supporter
    10,110
    736
    As the bearing gone in squarley, may be you damaged it putting it in?
  37. Welly
    10,696
    127
    I didn't press it mate, I got my local VW Audi specialist (well, my mate who works there) to do it for me and bring it back.
    He said it all went in fine with no problems.
  38. antwan
    antwan Member
    85
    Could it be the bearing on the opposite side ? I've been caught out before, sometimes noise carries across axles.
  39. S3 Nattie
    S3 Nattie Quattro ist für sissies
    1,599
    I have a really annoying squeaking noise from my passenger side wheel so be interested to see what cures your noise.
  40. aragorn
    17,890
    689
    I'd be checking this. Its usually fairly obvious when its that far gone though simply by spinning each wheel and seeing which sounds rough.
