FAULT:- Coolant Fan Control Circuit 1: Electrical Malfunction
EvolutionV Jan 19, 2010
  1. EvolutionV
    EvolutionV Member
    203
    Can't seem to fix this fault that i have on my car (2006 A3 2.0TFSI Quattro) , Car over heats and my rad fans don't turn on. I've checked all the wiring and they all seem okay. i've looked on the ross tech wiki and its says to check the fuses. i can't find the fuse for the coolant fan and after searching on here it seem there isn't one. Is this right??? Checked all engine bay and interior fuses and none are blown. Has anyone had any similar problems like this or have any idea how to fix it. Please help:keule:
    Here's the fault that came up when i did a scan with vag com:-
    Address 01: Engine Labels: 06F-907-115-AXX.lbl
    Part No SW: 8P0 907 115 K HW: 8P0 907 115 E
    Component: 2.0l R4/4V TFSI 0040
    Revision: --H14--- Serial number: AUX7Z0F0FNH0CP
    Coding: 01030003180F0160
    Shop #: WSC 00468 210 91757
    1 Fault Found:
    001152 - Coolant Fan Control Circuit 1: Electrical Malfunction
    P0480 - 008 - Implausible Signal
    Freeze Frame:
    Fault Status: 01101000
    Fault Priority: 0
    Fault Frequency: 1
    Mileage: 52993 km
    Time Indication: 0
    Date: 2010.01.18
    Time: 13:07:46
    Freeze Frame:
    RPM: 759 /min
    Load: 19.2 %
    Speed: 0.0 km/h
    Temperature: 90.0°C
    Temperature: 27.0°C
    Absolute Pres.: 1000.0 mbar
    Voltage: 13.970 V
    Readiness: 0110 0101
    Ross tech wiki:-
  2. NHN
    29,284
    1,695
    There's definitely a fuse for the fans as some people have changed there's when the climate econ light is on permanently after it blowing, assumming you stuck a meter on the fan wires to check for any voltage?
    Could very well be a fan unit, you can pick one of ebay fairly cheap tbh mate, saw one other day for small poundage.
    I'll see when it stops terrentialy raining & trying to snow, if I can dig out the fuse number/location.
  3. EvolutionV
    EvolutionV Member
    203
    Okay mate, i'll have another look in the user manual to see where the fuse is. Also i'll get a volt meter on the fan wires. thanks for your reply
  4. burnsy_b
    burnsy_b New Member
    i had this exact fault on a golf GTI at work yesturday, i know its a golf but its the same engine and fans ect. after exstensive searching i found the fuse. if you open your bonnet and look for the fuse box situated to the right hand side of the battery. take off the lid and you should see all the fuses, now if you look at the very front theres multiple RED live wires going to the fuse box. there fastened on with 2 8mm nuts. iirc the one you want is the 2nd or 3rd red wire counting from the LEFT it has a 50amp flat fuse between the 8mm nuts. u'll find that has blown.
  5. EvolutionV
    EvolutionV Member
    203
    My car is now sorted but thanks for your reply...
  6. willz17
    willz17 Member
    271
    22
    Glad you got it sorted mate :)
    What was the problem/fix?
  7. amit91987
    amit91987 Member VCDS Map User
    119
    I am getting the same fault on my Audi TTS. How did you resolve this issue?
