FAULT:- Coolant Fan Control Circuit 1: Electrical Malfunction
EvolutionV Jan 18, 2010
  1. EvolutionV
    EvolutionV Member
    203
    Can't seem to fix this fault that i have on my car (2006 A3 2.0TFSI Quattro) , i've looked on the ross tech wiki and its says to check the fuses. i can't find the fuse for the coolant fan and after searching on here it seem there isn't one. is this right
    Has anyone had any similar problems like this or have any idea how to fix it. I was thinking i might need a new radiator fan?
    Here's a scan i did with vag com:-
    Address 01: Engine Labels: 06F-907-115-AXX.lbl
    Part No SW: 8P0 907 115 K HW: 8P0 907 115 E
    Component: 2.0l R4/4V TFSI 0040
    Revision: --H14--- Serial number: AUX7Z0F0FNH0CP
    Coding: 01030003180F0160
    Shop #: WSC 00468 210 91757
    1 Fault Found:
    001152 - Coolant Fan Control Circuit 1: Electrical Malfunction
    P0480 - 008 - Implausible Signal
    Freeze Frame:
    Fault Status: 01101000
    Fault Priority: 0
    Fault Frequency: 1
    Mileage: 52993 km
    Time Indication: 0
    Date: 2010.01.18
    Time: 13:07:46
    Freeze Frame:
    RPM: 759 /min
    Load: 19.2 %
    Speed: 0.0 km/h
    Temperature: 90.0°C
    Temperature: 27.0°C
    Absolute Pres.: 1000.0 mbar
    Voltage: 13.970 V
    Readiness: 0110 0101
    Ross tech wiki:-
