Fault Codes
Daniel97 Dec 3, 2011
  1. Daniel97
    Daniel97 Member
    137
    Hi Guys & Girls,
    Could anyone tell me what any of these fault codes are and mean and how i can fix them?
    Thanks!
    00526 - Brake Light Switch-F
    36-10 - Open Circuit - Intermittent
    01370 - Alarm triggered by Interior Monitoring
    35-00 - -
    00962 - Alarm via. Tilt Sensor
    35-00 - -
    01371 - Alarm triggered by Door Contact Switch; Driver's Side
    35-00 - -
    01572 - Alarm triggered by Door Contact Switch; Passenger Side
    35-00 - -
    00956 - Key 2
    35-10 - - - Intermittent
    01333 - Door Control Module; Rear Left (J388)
    80-10 - Single-Wire Operation - Intermittent
    01317 - Control Module in Instrument Cluster (J285)
    49-10 - No Communications - Intermittent
  2. Turkster
    Turkster Bro.Paul 2.5TDI Quattro Sport
    2,797
    47
    sounds like the break light switch has had it, under the steering wheel driver side, you will find the peddles that push on switches.follow the cables,
    35-00 - -
    35-00 - -
    35-00 - -
    35-00 - -
    00956 - Key 2
    caused by the comfort control mudule is stuffed, under the front passenger side carpet foot well,
    maybe your speedo pod is failing
  3. Daniel97
    Daniel97 Member
    137
    What does that mean? What will be broken as a result?
  4. Turkster
    2,797
    47
    hope my edit helps.
  5. Daniel97
    Daniel97 Member
    137
    Sorry i still don't understand ..
    If i leave this faults .. what would happen (worst case)
    What wouldn't work if they fail completely?
