Fault codes on New K Module ..Help ?
J.R. May 17, 2011
  1. Khufu
    Khufu Well-Known Member
    5,704
    31
    Yes, O/S rear is correct side for fog light in UK, a German version off ebay.de will be on the N/S as they drive on the right hand side of the road. Is the CE module coded for UK? Isnt there an option for that? Will check when laptop is charged enough LOL
  2. a8 tech back
    a8 tech back Member
    198
  3. Khufu
    5,704
    31
  4. a8 tech back
    a8 tech back Member
    198
    show a dump of byte 4
    Byte 04 Bit 4 Activation of both Rear Fog Lights
    Byte 04 Bit 5 Model (0 = Right Hand Drive / 1 = Left Hand Drive)
    Byte 04 Bit 6 Rear Fog Lights deactivated
    byte 4 looks correct from the earlier long code but just check it and recheck byte 03 as well and change for one fog one reverse
  5. J.R.
    J.R. "Started From The Bottom" VCDS Map User
    1,405
    68
    Here is the list of the label files :
    ; VCDS Label File
    ; Copyright © 2006-2009 Ross-Tech, LLC
    ; Audi A3 (8P) / Audi R8 (42) / Audi TT (8J)
    ; Component: J519 - Central Electronics I (#09) - HIGHEND (30 Byte)
    ; P/N: 8P0-907-279-???
    ; includes measuring blocks, adaptation, selective output test and long coding
    ; This file is part of a redirection package,
    ; make sure you have all of the following files.
    ; 8P-09.LBL
    ; 8P0-907-279-23-H.LBL
    ; 8P0-907-279-30-H.LBL
    ; created on 18/Jul/2006 by Sebastian Stange (Sebastian@Ross-Tech.com)
    ; last modificationon on 24/Jan/2009
    ; requires VCDS 805.0 / LCode 804.0 or newer
    ; measuring blocks
    001,0,Parking Lights
    001,1,Left Front,Parking Light,Range: 0.0...100.0 %
    001,2,Right Front,Parking Light,Range: 0.0...100.0 %
    001,3,Left Rear,Parking Light,Range: 0.0...100.0 %
    001,4,Right Rear,Parking Light,Range: 0.0...100.0 %
    002,0,Fog Lights/Low Beams
    002,1,Left Low Beam,Headlight,Range: 0.0...100.0 %
    002,2,Right Low Beam,Headlight,Range: 0.0...100.0 %
    002,3,Left Fog Light,,Range: 0.0...100.0 %
    002,4,Right Fog Light,,Range: 0.0...100.0 %
    003,0,Turn Signals
    003,1,Left Front,Turn Signal,Range: 0.0...100.0 %
    003,2,Right Front,Turn Signal,Range: 0.0...100.0 %
    003,3,Left Rear,Turn Signal,Range: 0.0...100.0 %
    003,4,Right Rear,Turn Signal,Range: 0.0...100.0 %
    004,1,Left Side,Turn Signal,Range: 0.0...100.0 %
    004,2,Right Side,Turn Signal,Range: 0.0...100.0 %
    004,3,Left/Right,High Beam,Range: 0.0...100.0 %
    004,4,Xenon-Shutter,,Range: ON/OFF
    005,0,Brake Lights
    005,1,Left,Brake Light,Range: 0.0...100.0 %
    005,2,Right,Brake Light,Range: 0.0...100.0 %
    005,3,Center,Brake Light,Range: 0.0...100.0 %
    005,4,License Plate,Illumination,Range: 0.0...100.0 %
    006,0,Back-Up Lights
    006,1,Instrument,Illumination,Terminal 58d (Range: 0.0...100.0 %)
    006,2,Left,Back-Up Light,Range: 0.0...100.0 %
    006,3,Right,Back-Up Light,Range: 0.0...100.0 %
    006,4,Left Rear,Fog Light,Range: 0.0...100.0 %
    007,1,Activation Relay,Terminal 50,Range: ON/OFF
    007,2,Activation Relay,Terminal 15,cockpit/engine (Range: ON/OFF)
    007,3,Activation Relay,Terminal 75,Range: ON/OFF
    007,4,Enabling SAD,,Range: active/inactive
    008,1,Brightness,,Range: 0...7
    008,2,Rain Quantity,,Range: 0...7
    008,3,Right Rear,Fog Light,Range: 0.0...100.0 %
    008,4,Footwell,Lighting,Range: 0.0...100.0 %
    009,1,Terminal 30g,Relay,Range: ON/OFF
    009,2,Dual Washer,Pump +,Range: ON/OFF
    009,3,Dual Washer,Pump -,Range: ON/OFF
    009,4,Heated Rear,Windshield,Range: ON/OFF
    010,1,Horn,,Range: Operated/Not Oper.
    010,2,Enabling of,Seat Heating,Range: Active/Inactive
    010,3,Electric Fuel,Pump (FP) Relay,Range: ON/OFF
    010,4,Headlight Washer,System Relay,Range: ON/OFF
    011,1,LED Heated Rear,Windshield,Range: ON/OFF
    011,2,LED Emergency,Flasher Button,Range: 0.0...100.0 %
    011,3,LED Heated,Outside Mirror,Range: ON/OFF
    011,4,Interior,Light Dimmed,Range: 0.0...100.0 %
    012,1,Coming Home,LED,Range: ON/OFF
    012,2,Heated Outside,Mirror,Range: ON/OFF
    013,0,Terminals
    013,1,Terminal 30,(left),Range: 0.00...17.75 V\nSpecification: 5.0...17.75 V
    013,2,Terminal 30,(right),Range: 0.00...17.75 V\nSpecification: 5.0...17.75 V
    013,3,Terminal 30,(ref.),Range: 0.00...17.75 V\nSpecification: 5.0...17.75 V
    013,4,Terminal 31,(ref.),Range: 0.00...12.75 V\nSpecification: 0.0...1.00 V
    014,1,Dimming,Potentiometer,Range: 0.0...100.0 %
    014,2,Coming Home,,Range: 0.0...100.0 %/ON/OFF
    014,4,HomeLink,,Range: Operated/Not Oper.
    015,0,Terminals
    015,1,Terminal 15,(Input),Range: ON/OFF
    015,2,Terminal 50,(Input),Range: ON/OFF
    015,3,Enabling P/N,,Range: ON/OFF
    015,4,Terminal L,(Input),Range: ON/OFF
    016,1,Brightness,,OFF = Bright\nON = Dark
    016,2,Lights on (RLS),,Range: ON/OFF
    016,3,Front Wiper,Status,Range: ON/OFF
    016,4,Wiper turn-around,Position Signal,Range: Reached/Not Active
    017,1,Light Switch,(Light off),Range: ON/OFF
    017,2,Parking Light,Switch,Range: ON/OFF
    017,3,Low Beam,Headlight Switch,Range: ON/OFF
    017,4,AFL Light Switch,,Range: ON/OFF
    018,1,Fog Light Switch,,Range: ON/OFF
    018,2,Light Switch,Rear Fog Light,Range: ON/OFF
    018,3,Brake Light Switch,,Range: ON/OFF
    018,4,Back-Up,Light Switch,Range: ON/OFF
    019,1,Emergency,Flasher Button,Range: Operated/Not Oper.
    019,2,Engine Hood,,Range: Open/Closed
    019,3,Heated Rear,Windshield Button,Range: Operated/Not Oper.
    019,4,Heated Outside,Mirror,Range: Operated/Not Oper.
    020,0,Backrest Recognition
    020,3,Backrest,Left,Range: ON/OFF
    020,4,Backrest,Right,Range: ON/OFF
    021,0,Rotary Traps
    021,1,Rotary Trap LF,,Range: ON/OFF
    021,2,Rotary Trap RF,,Range: ON/OFF
    021,3,Rotary Trap LR,,Range: ON/OFF
    021,4,Rotary Trap RR,,Range: ON/OFF
    022,1,Rear Lid,Main Catch,Range: ON/OFF
    022,2,Heated Front,Windshield,Range: operated/n. oprated
    022,3,Heated Front,Windshield Relay,Range: ON/OFF
    022,4,Heated Front,Windshield LED,Range: ON/OFF
    023,1,Rotary Light Switch,Position
    023,2,Coming Home,Condition
    023,3,Leaving Home,Condition
    023,4,AFL Condition
    024,1,Steering Column,Switch Information,via LIN-Databus
    024,2,Terminal 15,(via LIN),Range: ON/OFF
    024,3,Terminal 50,(via LIN),Range: ON/OFF
    024,4,Wiper Cycle,Number (via LIN)
    030,1,Load Management,,Range: Active/Inactive
    030,2,Short-Distance,Operations
    030,3,Critical,Time Fraction
    080,0,Advanced Control Module Identification I
    081,0,Advanced Control Module Identification II
    082,0,Advanced Control Module Identification III
    ; adaptation
    A000,0,Reset Adaptation Channels
    A000,5,Reset Adaptation Channels
    A000,6,Reset all adaptation channels back
    A000,7,to the original factory values.
    A001,0,Coming-Home Time
    A001,5,Coming-Home Time
    A001,6,Time which the Coming-Home function will be active.
    A001,7,Range: 10...60 Seconds
    A001,8,Resolution: 10 Seconds
    A001,9,Note: Only active if Byte 00 Bit 7 of Long Coding active.
    A002,0,Leaving-Home Time
    A002,5,Leaving-Home Time
    A002,6,Time which the Leaving-Home function will be active.
    A002,7,Range: 10...60 Seconds
    A002,8,Resolution: 10 Seconds
    A002,9,Note: Only active if Byte 00 Bit 5 of Long Coding active.
    A003,0,Rear Window & Outside Mirror Heater Activation Time
    A003,5,Rear Window & Outside Mirror Heater Activation Time
    A003,6,Time which the Rear Window and Outside Mirror Heater will be active.
    A003,7,Range: 1...254 Minutes
    A003,8,Resolution: 1 Minute
    A004,0,Headlight Washer Activation Time
    A004,5,Headlight Washer Activation Time
    A004,6,Range: 50...10000 ms
    A004,7,Resolution: 50 ms (Adaptation Value * Resolution = Actual Value)
    A004,8,Note: Only active if Byte 01 Bit 1 of Long Coding active.
    A005,0,Footwell Lighting Dimming
    A005,5,Footwell Lighting Dimming
    A005,6,Range: 20...100 %
    A005,7,Resolution: 1 %
    A005,8,Note: Only active if Byte 00 Bit 1 of Long Coding active.
    A006,0,Load Management
    A006,5,Load Management
    A006,6,Range: 0...3
    A006,7,Note: Only active if Byte 02 Bit 3 of Long Coding active.
    A007,0,Highbeam with Assistance Driving Light
    A007,5,Highbeam with Assistance Driving Light
    A007,6,0 = inactive
    A007,7,1 = active
    A008,0,Assistance Driving Light Activation/Deactivation Delay
    A008,5,Assistance Driving Light Activation/Deactivation Delay
    A008,6,Range: 0...10200 ms
    A008,7,Resolution: 40 ms
    ; selective output test
    T59,Interior Lighting
    T60,Foglight Lamps
    T156,Front Windshield Washer Pump
    T901,Back-Up Lamps
    T906,Horn (H1)
    T909,Windshield Wiper Motor (V)
    T967,Left Turn Signals
    T968,Right Turn Signals
    T975,Heated Rear Window (Z1)
    T977,Low Beam (Left & Right)
    T2486,High Beam (Left & Right)
    T1064,Interior Dimming (Terminal 58d)
    T1259,Fuel Pump Relay (J17)
    T1504,License-Plate Light (X)
    T1701,Dimmer for Interior Lighting
    T1755,Parking Lights (E1)
    T1758,Brake Lamps
    T1830,Rear Fog Light(s)
    T2377,Wiper: Upper Reverse Point
    T2398,Rear Windshield Washer Pump
    ; long coding
    LC,00,0,Front Fog Lights installed
    LC,00,1,Xenon Headlights with Shutter installed
    LC,00,2,Footwell Lights installed
    LC,00,3,Daytime Running Lights (Scandinavia) active
    LC,00,4,Daytime Running Lights (North America)
    LC,00,5,Assistance Driving Light & Leaving Home active
    LC,00,6,Rain-/Light sensor installed
    LC,00,7,Coming-Home active
    LC,01,0,Rear Seat Recognition installed
    LC,01,1,Headlight Washer installed
    LC,01,2,Electronic Fuelpump Relay installed (Gasoline only)
    LC,01,3,Rear Wiper installed
    LC,01,7,Rear Wiper with Front Wiper continiously active
    LC,02,0,Rear Wiper with Front Wiper intermittent active
    LC,02,1,Comfort Turn Signals
    LC,02,2,Cold Lamp Diagnosis active
    LC,02,3,Load Management active
    LC,02,4,Coming-Home Mode via (0 = Personalisation / 1 = Lightsensor)
    LC,02,6,Side Turn Signal Lights installed
    LC,02,7,Seat Heating installed
    LC,03,0,Relay Terminal 15 installed
    LC,03,1,Rear Fog Lights (0 = 2 Rear Fog Lights / 1 = 1 Rear Fog Light)
    LC,03,2,Reverse Driving Lights (0 = 2 Reverse Driving Lights / 1 = 1 Reverse Driving Light)
    LC,03,3,Reverse Driving Light off when Rear Lid open
    LC,03,4,Xenon-Shutter without Shutter installed (Bi-Xenon)
    LC,03,5,Teardrop Wiping for Rear Window active
    LC,03,7,Rear Lights (1 = Back Light/Brake Light dimmed / 0 = Back Light dimmed)
    LC,04,0,Auxiliary Heater installed
    LC,04,1,Auxiliary Heating installed
    LC,04,2,Trailer/Towing Device installed
    LC,04,3,Memory Seats installed
    LC,04,4,Activation of both Rear Fog Lights
    LC,04,5,Model (0 = Left-Hand-Drive / 1 = Right-Hand-Drive)
    LC,04,6,Rear Fog Lights deactivated
    LC,04,7,Climatronic installed
    LC,05,0-7,50,Headlight Washer Delay
    LC,05,0-7,50,Decimal Value (Resolution 50 ms) (Example: 20 is 20 x 50 = 1000 ms)
    LC,06,0-7,50,Headlight Washer Activation Time
    LC,06,0-7,50,Decimal Value (Resolution 50 ms) (Example: 16 is 16 x 50 = 800 ms)
    LC,07,0-7,1,Turn Signal Front left/right as Parking Light Front left/right (USA and Canada)
    LC,07,0-7,1,Decimal Value (Resolution: 1%)
    LC,08,0,Seat Heating Deactivation with Transport Mode active
    LC,08,1,Daytime Running Light (DRL) Deactivation with Transport Mode active
    LC,08,2,Footwell Lighting Deactivation with Transport Mode active
    LC,08,3,Interlock Display via CAN-Instruments active
    LC,08,4,Interior Light via Rear Lid Notch active
    LC,08,6,Rear Fog Light Deactivation with Trailer active
    LC,08,7,Daytime Running Light (DRL) Deactivation while Blinking active
    LC,09,0-7,1,Rear Brake Light as Parking Light
    LC,09,0-7,1,Decimal Value (Resolution: 1%)
    LC,10,0-7,1,Rear Fog Light as Parking Light
    LC,10,0-7,1,Decimal Value (Resolution: 1%)
    LC,11,0-7,1,Front Parking Light Dimming
    LC,11,0-7,1,Decimal Value (Resolution: 1%)
    LC,12,0-7,1,Rear Parking Light Dimming
    LC,12,0-7,1,Decimal Value (Resolution: 1%)
    LC,13,0-7,1,Backup Function: Rear Side Turn Signal as Parking/Brake Light
    LC,13,0-7,1,Decimal Value (Resolution: 1%)
    LC,14,0-7,1,Backup Function: Front Parking Light as Side Turn Signals
    LC,14,0-7,1,Decimal Value (Resolution: 1%)
    LC,15,0-7,1,Backup Function: Rear Parking Light as Side Turn Signals
    LC,15,0-7,1,Decimal Value (Resolution: 1%)
    LC,16,0-7,1,Backup Function: Front Fog Lights as Low Beam Headlight
    LC,16,0-7,1,Decimal Value (Resolution: 1%)
    LC,17,0,Emergency Brake Flash Light active
    LC,17,1,Deactivation of Additional High Beam with Bi-Xenon
    LC,17,2,Heated Front Window installed
    LC,17,3,Diagnosis Terminal 50 active
    LC,17,4,Daytime Running Light via Fog Lights
    LC,17,5,Front Fog Lights deactivated with High Beam
    LC,17,6,Parking Light Function inactive (USA/Canada)
    LC,18,0,Cold Diagnosis License Plate Lights active
    LC,18,1,Cold Diagnosis Brake Lights active
    LC,18,2,Cold Diagnosis Front Fog Lights active
    LC,18,3,Cold Diagnosis Rear Fog Lights active
    LC,18,4,Cold Diagnosis High Beam active
    LC,18,5,Cold Diagnosis Turn Signals active
    LC,18,6,Cold Diagnosis Back-Up Light active
    LC,18,7,Cold Diagnosis Side Turn Signals active
    LC,19,0,Cold Diagnosis Low Beam active
    LC,19,1,Cold Diagnosis Front Parking Lights active
    LC,19,2,Cold Diagnosis Rear Parking Lights active
    LC,19,3,Diagnosis Rear Parking Lights active
    LC,20,0-7,1,Front Fog Light Dimming (Standard 5C)
    LC,20,0-7,1,Decimal Value (Resolution: 1%)
    LC,21,0~2,01,Halogen Front Light
    LC,21,0~2,02,Xenon Front Light with Halogen High Beam
    LC,21,0~2,03,Bi-Xenon Front Light with additional High Beam
    LC,21,0~2,04,Bi-Xenon Front Light without additional High Beam
    LC,21,0~2,05,Bi-Xenon Front Light with separate Daytime Running Lights (DRL)
    LC,21,0~2,06,Bi-Xenon Front Light with LED Daytime Running Lights (DRL)
    LC,21,0~2,07,LED Front Light
    LC,21,4,Rear Fog Light as Brake Light
    LC,22,1,Daytime Running Lights (DRL) switchable via Menu
    LC,22,4,Speed dependant Trunk Locking active
    LC,22,6,Rear Parking Lights as Blinker active (North America)
    LC,22,7,Diagnosis Rear Brake Lights inactive (North America)
    LC,23,1,Advanced Comfort Menu active
    LC,23,7,Engine Compartment Light via Right Side Blinker Output active
  6. J.R.
    1,405
    68
    This is the switch turned on with rear fog....as you can see the switch works...
    I don't understand what you mean by doing a dump on byte 4:uhm:
    also I've done a screen shot of the bytes it's currently on at the moment.
    Me and RS also found out what was wrong with the interior light......as it was due to a relay in the wrong position. So one solved and 2 more to go....:thumbsup:
  7. a8 tech back
    a8 tech back Member
    198
    change byte 3 for one reverse and one fog
    you may have to alter the bits instead of the check box
    so bit 1 and bit 2 need changing to activate one rear fog and one rear reverse
    remember every time you change and save with vcds you must turn the ignition off and back on the turn the fig on and see if it works
    screen dump mark 5 golf
    golf 09 by a8 tech, on Flickr
    osr fog nsr reverse
    SO SET BIT CODE 00000110
    did you move the relay position 8 to the 30 supply position 9
    you are missing a 15 supply relay from position 1
    if you do not need the 15 relay uncheck the box in byte 3 and try that
    looking back at your old relay positions
    http://www.audi-sport.net/vb/new-a3...380-central-electrics-module-relays-help.html
    move the relay 460 to position 1 of the new relay carrier but I would think you need both relays
    anyway try some of this lot
    found the long code helper/simulator
    go to c drive find ross tech and open it
    scroll down till you find Lcode exe
    open it and all your long code files will be there
    you can now simulate code changes without being connected to the car
  8. J.R.
    1,405
    68
    I've Just coded it to exactly what you stated below..and unchecked relay 15...Still no change..:banghead:
    My bit code is now : 00000110
    Yes... I moved the relay position 8 to the 30 supply position 9 ....And the interior lights started to work..
    I tried to move relay 460 to position 1 of the new relay carrier but it was too hard to take out so I left it in there.....But I was looking at the back position of where the 460 relay slots into on the left..side of the module..and there is no current connector with wires going out in place...but on the right side where the other 460 relay is there is a connector with wires going out.
    I was wondering if there would be a point of getting another 460 relay and slotting it in as there is no connectors going out the back of it.:think:
  9. a8 tech back
    a8 tech back Member
    198
    God knows whats going on with this.All I can say if your mate has done the same upgrade and the cars are the same year and spec then compare the coding and the check if the relay 460 is fitted.
    Its hard to work out what should be doing what without having the car in front of me to check the wiring.
    Iam sure if I had the car I would sort it out.
    Stick a new scan of the faults up and post your exact vehicle details ie 8p 3 door low line none auto lights engine code etc
    I have fitted a k before without any problems for xenon upgrade but cant find the vcds log
    We need to see address 09 long code for other 3 door vehicles with K fitted and nsr reverse osr fog
    Just wondering if there is some difference with the rear light units or light switch as output test with vcds shows the osr fog works but does it out the nsr reverse on as well
    It something simple that's causing it
    So presently if you select reverse or turn on the rear fogs nothing happens.
    I would stick a multimeter in the pins and select output test for fog light and see which pin becomes active when it works and then post it up so we can trace the wiring back to j519
    When you checked measured value blocks it shows the fog light on
    Other things to mess with, try coding for both rear fogs or select the BACK TO STANDARD BUTTON in long coding and see what happens
  10. J.R.
    1,405
    68
    The Relay 460 is fitted in RS's Module.....on both sides. I'm going to order another 460 relay tomorrow.
    Here is a full vag-com scan.
    VCDS Version: Beta 812.4
    Data version: 20090214
    Thursday,19,February,2009,18:58:38:26365
    Chassis Type: 1K0
    Scan: 01 03 08 09 15 16 17 19 25 42 44 46 47 52 56 7D
    VIN: WAUZZZ8P64A039000 Mileage: 165450km/102805miles
    00-Steering Angle Sensor -- Status: OK 0000
    01-Engine -- Status: Malfunction 0010
    03-ABS Brakes -- Status: OK 0000
    08-Auto HVAC -- Status: Malfunction 0010
    09-Cent. Elect. -- Status: Malfunction 0010
    15-Airbags -- Status: Malfunction 0010
    16-Steering wheel -- Status: OK 0000
    17-Instruments -- Status: Malfunction 0010
    19-CAN Gateway -- Status: OK 0000
    25-Immobilizer -- Status: OK 0000
    42-Door Elect, Driver -- Status: OK 0000
    44-Steering Assist -- Status: OK 0000
    46-Central Conv. -- Status: Malfunction 0010
    47-Sound System -- Status: OK 0000
    52-Door Elect, Pass. -- Status: Malfunction 0010
    56-Radio -- Status: Malfunction 0010
    7D-Aux. Heat -- Status: OK 0000
    Address 01: Engine Labels: 03G-906-016-BKD.lbl
    Part No SW: 03G 906 016 G HW: 028 101 136 4
    Component: R4 2,0L EDC 0000SG 5334
    Revision: 12345678 Serial number: AUX7Z0C6FN301U
    Coding: 0000072
    Shop #: WSC 06435 000 00000
    2 Faults Found
    18354 - Control Module 1 for Coolant Fan: Defective
    P1946 - 000 - -
    Freeze Frame:
    RPM: 840 /min
    Torque: 28.0 Nm
    Speed: 0.0 km/h
    Load: 0.0 %
    Voltage: 14.14 V
    Bin. Bits: 00000000
    Temperature: 35.1°C
    Duty Cycle: 9.6 %
    16502 - Engine Coolant Temp. Sensor (G62): Signal too High
    P0118 - 000 - -
    Freeze Frame:
    RPM: 840 /min
    Torque: 26.0 Nm
    Speed: 0.0 km/h
    Load: 0.0 %
    Voltage: 14.14 V
    Bin. Bits: 00000000
    Temperature: 39.6°C
    Temperature: 32.4°C
    Readiness: 0 0 0 0 0
    Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
    Part No: 1K0 907 379 D
    Component: ESP FRONT MK60 0102
    Coding: 0055942
    Shop #: WSC 00012 000 00000
    No fault code found.
    Address 08: Auto HVAC Labels: 8P0-820-043.lbl
    Part No SW: 8P0 820 043 HW: 8P0 820 043
    Component: KlimavollautomatH11 0130
    2 Faults Found
    01177 - Engine Control Unit
    013 - Check DTC Memory
    Freeze Frame:
    Fault Status: 01101101
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 249
    Mileage: 165459 km
    Time Indication: 0
    Date: 2011.05.19
    Time: 18:55:30
    Freeze Frame:
    ON
    01317 - Control Module in Instrument Cluster (J285)
    Freeze Frame:
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 235
    Mileage: 165202 km
    Time Indication: 0
    Date: 2011.04.19
    Time: 00:40:16
    Freeze Frame:
    ON
    Address 09: Cent. Elect. Labels: 8P0-907-279-30-H.lbl
    Part No SW: 8P0 907 279 K HW: 8P0 907 279 K
    Component: Bordnetz-SG H54 2501
    Revision: 00H54000 Serial number: 00000008302459
    Coding: B78C5F060014100000000000000000000010FF075C060200000000000000
    Shop #: WSC 00000 000 00000
    Part No: 8P2 955 119
    Component: Wischer WWS Audi350 0130
    Coding: 16711696
    Shop #: WSC 00000
    4 Faults Found
    00061 - Footwell Lights
    012 - Electrical Fault in Circuit
    Freeze Frame:
    Fault Status: 01101100
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 249
    Mileage: 165429 km
    Time Indication: 0
    Date: 2011.05.19
    Time: 11:49:00
    Freeze Frame:
    OFF
    Voltage: 11.50 V
    OFF
    ON
    OFF
    OFF
    OFF
    01502 - Bulb for Rear Fog; Left (L46)
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 249
    Mileage: 165429 km
    Time Indication: 0
    Date: 2011.05.19
    Time: 11:49:00
    Freeze Frame:
    ON
    Voltage: 10.95 V
    ON
    ON
    OFF
    OFF
    OFF
    01519 - Bulb for Back-Up Lights; Right (M17)
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 249
    Mileage: 165429 km
    Time Indication: 0
    Date: 2011.05.19
    Time: 11:49:00
    Freeze Frame:
    ON
    Voltage: 10.85 V
    ON
    ON
    OFF
    OFF
    OFF
    01259 - Fuel Pump Relay (J17)
    009 - Open or Short to Ground
    Freeze Frame:
    Fault Status: 01101001
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 249
    Mileage: 165429 km
    Time Indication: 0
    Date: 2011.05.19
    Time: 11:49:00
    Freeze Frame:
    ON
    Voltage: 10.95 V
    ON
    ON
    OFF
    OFF
    OFF
    Address 15: Airbags Labels: 8P0-959-655-84.lbl
    Part No SW: 8P0 959 655 F HW: 8P0 959 655 F
    Component: Airbag 8.4ED H01 0130
    Coding: 0011602
    1 Fault Found
    00588 - Airbag Igniter; Driver Side (N95)
    001 - Upper Limit Exceeded - Intermittent - MIL ON
    Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
    Part No SW: 1K0 953 549 A HW: 1K0 953 549 A
    Component: Lenksäulenmodul 008 0030
    Coding: 0000012
    Address 17: Instruments Labels: 8P0-920-xxx-17-MY7.lbl
    Part No SW: 8P0 920 980 HX HW: 8P0 920 980 HX
    Component: KOMBIINSTR. VDO H25 0180
    Revision: D15 Serial number: 2246ID15100011
    Coding: 0004403
    Shop #: WSC 00654 210 91808
    1 Fault Found
    00779 - Outside Air Temp Sensor (G17)
    010 - Open or Short to Plus
    Freeze Frame:
    Fault Status: 00000011
    Fault Priority: 7
    Fault Frequency: 2
    Reset counter: 249
    Mileage: 165429 km
    Time Indication: 0
    Date: 2011.05.18
    Time: 20:51:10
    Address 19: CAN Gateway Labels: 1K0-907-530.lbl
    Part No SW: 1K0 907 530 B HW: 1K0 907 951
    Component: Gateway H08 0070
    Revision: 08 Serial number: 170010351735E7
    Coding: 3D0F0B42070101
    Address 25: Immobilizer Labels: 1K0-920-xxx-25.lbl
    Revision: D15 Serial number: AUX7Z0C6FN301U
    Address 42: Door Elect, Driver Labels: 8P0-959-801-MIN.lbl
    Part No: 8P0 959 801 A
    Component: Tuersteuerger. H09 0010
    Coding: 0000120
    Address 44: Steering Assist Labels: 1Kx-909-14x.lbl
    Part No: 1K1 909 143 L
    Component: EPS_ZFLS Kl.7 0402
    Address 46: Central Conv. Labels: 8P0-959-433.lbl
    Part No: 8P0 959 433
    Component: KSG H02 0030
    Coding: 008800186D288505485AC63000
    Part No: 1K0 951 605 A
    Component: LIN BACKUP HORN H01 1201
    Part No: 1K0 907 719
    Component: Neigungssensor 002 0002
    Component: IRUE No Answer
    1 Fault Found
    01135 - Interior Monitoring Sensors
    004 - No Signal/Communication
    Address 47: Sound System Labels: 8Px-035-382.lbl
    Part No SW: 8P3 035 382 HW: 8P3 035 382
    Component: AB2 SUBWOOFERBOXH23 0100
    Revision: 00001 Serial number: 10000001032935
    Address 52: Door Elect, Pass. Labels: 8P0-959-802-MIN.lbl
    Part No: 8P0 959 802 A
    Coding: 0000120
    1 Fault Found
    00933 - Electric Window Motor; Passenger Side (V148)
    005 - No or Incorrect Basic Setting / Adaptation - Intermittent
    Address 56: Radio Labels: 8P0-035-1xx-56.lbl
    Part No SW: 8P0 035 186 HW: 8P0 035 186
    Component: concert II EU H52 0060
    Revision: 05S Serial number: AUZ2Z3C1257618
    Coding: 0001001
    1 Fault Found
    00858 - Connection; Radio ZF Output to Antenna Amplifier
    011 - Open Circuit
    Freeze Frame:
    Fault Status: 01101011
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 249
    Mileage: 165442 km
    Time Indication: 0
    Date: 2011.05.19
    Time: 17:03:24
    Address 7D: Aux. Heat Labels: 1K0-963-235.lbl
    Part No SW: 1K0 963 235 A HW: 1K0 963 235 A
    Component: PTC-Element 0303
    Revision: 00400000 Serial number:
    End ---------------------------------------------------------------------
    The strange thing now is the reverse light works when I put it into reverse....since we moved that 449 relay. But errors are still coming up on the DIS. Also rear Fog don't work when switched on with light switch.
    I'll try the coding for both rear fogs or select the BACK TO STANDARD BUTTON in long coding and see what happens......
  11. a8 tech back
    a8 tech back Member
    198
    relay 460 missing seems to be the simple solution
    you could bridge across the contacts for the primary to secondary side as if there was a relay fitted to test the fog or just get the relay lol
  12. J.R.
    1,405
    68
    I'll get the relay ...on Tuesday..And I'll keep you informed ....
    Thanks for your help....:salute:
  13. ~RS~
    ~RS~ Active Member
    1,466
    22
    The joys of amateur retrofits ay digzz, lol :p
  14. J.R.
    1,405
    68
    Ok Sorted out a couple of things .:happy:..bit still having some small issues.
    I installed the relay 460 yesterday....and the Reverse Light bulb fault hasn't come up since...:o.k:
    I'm still getting issues with this Left Fog light thing coming up in Vag-com and the DIS. But now it acts very different then before.
    When I pull the switch out to turn on the rear fogs on...it comes up with the same error and the fog light do not work. Then the error keeps on coming up on the DIS & Vag-com , It's not until I clear the error.... it don't come up when I turn the ignition any more or Vag-com. But soon as I turn the Rear fog light switch on again ....it starts all over with the error.
    Auto-Lights & Mirror Dimmer - Don't work at all.
    I'm also trying to get this to work but I'm having a few issues. Comes up with the Below Error:
    02071 - Local Databus
    Freeze Frame
    Fault Status: 01100100
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 4
    Mileage: 165594 km
    Time Indication: 0
    Date: 2011.05.24
    Time: 18:43:00
    Freeze Frame
    ON
    Voltage: 12.30 V
    ON
    ON
    OFF
    OFF
    OFF
    01520 - Rain and Light Recognition Sensor (G397)
    Freeze Frame
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 4
    Mileage: 165594 km
    Time Indication: 0
    Date: 2011.05.24
    Time: 18:43:00
    Freeze Frame
    ON
    Voltage: 12.30 V
    ON
    ON
    OFF
    OFF
    OFF
    This is the Menu I tick in Vag-COM .....even thou I don't have the rain sensors do you still think I should still tick this box ?
  15. Khufu
    5,704
    31
    what headlight switch you using? I take it you have a later version that supports DRLs? If I try my switch with DRL onto my older non rev CE module my fog lights dont work.
  16. J.R.
    1,405
    68
    8J2941531E comes up for the TT but can use in are cars ...as NHN Stated in a Thread. Also same as RS.
  17. a8 tech back
    a8 tech back Member
    198
    Do you mean anti dazzle interior mirror, and have you retro fitted this mirror, check the fuse
    Check the fogs work with out put test and are the rear lights the correct lights or retro fits
    Your lin bus fault is because you do not have rain and light sensor so have you retro fitted auto lights and modified the wiring
  18. a8 tech back
    a8 tech back Member
    198
    found the log from my xenon retro fit
    Revision: 00H54000 Serial number: 00000007500978
    Coding: 87880F27A01410004D0000000000000000185E175C030000000000000000
  19. a8 tech back
    a8 tech back Member
    198
    ok now I have my log for 2007 3 door a3 retro xenon change byte 3 to 00100111
    so
    bit 0 tick
    bit 1 tick
    bit 2 tick
    bit 5 tick
    try that
  20. J.R.
    1,405
    68
    Yes...I'm talking about the dazzle interior mirror not working. no this is not a retro fit...as this was already installed when I bought the car. Yes the rear lights are correct ...Just upgraded to the new rear lights on the 3 door ....and I know they don't need coding...as everybody on here ain't had a problem.. The 1 fog rear does work as I've done a out put test before.
  21. J.R.
    1,405
    68
    I've Just used the above code and the problems have been solved...:arco::yahoo:
    Thank you very much "a8 tech"
    Now I just need to sort out the Auto Lights and the dazzle interior mirror. :uhm:
  22. Khufu
    5,704
    31
    wooo, at last :)
    so ultimately was it swapping over a relay & a coding issue?
  23. J.R.
    1,405
    68
    It was Mainly a coding issue. :sm4:
  24. a8 tech back
    a8 tech back Member
    198
    auto lights and dazzle mirror are on the same circuit so
    auto light switch can be checked in measured value block 17 in address 09
    2004 wiring auto light sensor anti dazzle mirror
    j519 t16a/11 to pin 3 of the light sensor
    j519 t12/c3 to light sensor pin 1 (this also picks up the light switch)
    light sensor pin 2 to earth
    pins 4 and 5 of the light sensor go to the door control units for anti dazzle wing mirrors
    2007
    pin1 of the light sensor goes to fuse sc4 ignition 15 supply
    pin 2 of the sensor goes to earth
    pin 3 goes to j519 t12c/1
    pins 4&5 goes to the doors again
    so pin 1 needs a 15 supply
    and pin 3 needs picking up at t16a/11 (i suspect this is a signal)
    so in theory just give pin 1 a live to test it works
    if it does then find a 15 supply and tap into it via a 5amp in line fuse as you are using 2004 wiring and fuse allocations with the newer central electrics so sc4 fuse will not be valid for your wiring
    or tap into the original headlight switch t6/4 for pin 1 of the interior mirror/light sensor
  25. J.R.
    1,405
    68
    So is the wiring different because of my module ?
  26. a8 tech back
    a8 tech back Member
    198
    yes and because of the vehicle build date
    I'm basing the wiring from a 2004 and 2007 as K is around 2007 ish
    the mirror and sensor really only need 3 things to work.Earth live (ignition live) and signal input
    2004 interior mirror was powered from the light switch and 2007 powered via a fused 15 supply
    as its a retro fit with added parts then you have to mess around a bit to get things to work as they should, this makes it hard to refer to vehicle specific wiring
    you could re wire to the mirror pins at j519 for correct designation if you wish
    now all the main stuff is working this should be easy lol
  27. Khufu
    5,704
    31
    Finally upgraded my A rev to a K rev CE module today having fitted bi-xenons a while back. Having never had xenons originally and K not being a direct replacement for A, I wasnt sure what else apart from coding would need to be done. Turns out on an A, the main beam wires go to where the DRLs and vice versa to that of the K. A bit of rewiring & coding and one more part of the upgrade done. Weekend will see the DRLs wired too :)
    This will leave the job of getting the chrome facelift light with DRL switch working too.
    just leave 2 questions:
    byte 8, bit 2 - interlock display via CAN-instrments active
    and
    byte 23, bit 2 - internal turn light control algorithm active
    anybody know what they are for?
