Fault codes on New K Module ..Help ?
J.R. May 17, 2011
  1. J.R.
    J.R. "Started From The Bottom" VCDS Map User
    1,405
    68
    I've just changed my Module from an A to a K. I'm getting faults on Rear Fog Light & Rear Reverse Light. My Interior lights don't work also...
    I'm getting these fault codes on VCDS:
    Saturday,14,March,2009,19:51:55:26365
    VCDS Version: Beta 812.4
    Address 09: Cent. Elect.
    Control Module Part Number: 8P0 907 279 K
    Component and/or Version: Bordnetz-SG H54 2501
    Software Coding: 078C5F060014100040000000000000000000FE075C060000000000000000
    Work Shop Code: WSC 00000
    Additional Info: 8P2955119 Wischer WWS Audi350 0130
    Fault Codes have been Erased
    2 Faults Found
    01259 - Fuel Pump Relay (J17)
    009 - Open or Short to Ground
    Freeze Frame
    Fault Status: 01101001
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 243
    Mileage: 165375 km
    Time Indication: 0
    Date: 2011.04.23
    Time: 13:07:00
    Freeze Frame
    ON
    Voltage: 12.00 V
    ON
    OFF
    OFF
    OFF
    OFF
    00059 - Terminal 30 for Interior Lighting
    012 - Electrical Fault in Circuit
    Freeze Frame
    Fault Status: 01101100
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 243
    Mileage: 165375 km
    Time Indication: 0
    Date: 2011.04.23
    Time: 13:07:00
    Freeze Frame
    ON
    Voltage: 12.00 V
    ON
    OFF
    OFF
    OFF
    OFF
  2. Khufu
    Khufu Well-Known Member
    5,704
    31
    I know some of the relays have move position between the two revision, could be that?
  3. ~RS~
    ~RS~ Active Member
    1,466
    22
    Hmmm, that fuel pump relay one I had before moving the relays/fuses about on the module. May well be that as Khufu says although with my new one I just put the relays into the same position my old ones were and all is working now after figuring out which ones position the washer relays went into.
    Did you check what the ross wiki for the 2nd fault? The terminal 30 one?
  4. J.R.
    1,405
    68
    Yep....
    Possible Symptoms
    Interior Light nor working
    Possible Causes
    Fuse(s) faulty
    Possible Solutions
    Check Fuse(s)
    Special Notes
    When found in VW Golf (1K) or similar:
    Check Fuse(s) in Dash Board and Electronic Box (Engine Compartment)
    Check bolted Power Connections in Electronic Box (Engine Compartment)
    Check Wiring/Connectors from/to Central Electronics Control Module
    Check Power Supply Relais for Terminal 30 (J317)
  5. ~RS~
    ~RS~ Active Member
    1,466
    22
    00059 - Terminal 30 for Interior Lighting: Electrical Fault in Circuit
    Possible Symptoms
    Possible Causes
    Fuse(s) faulty
    Possible Solutions
    Check Fuse(s)
    Special Notes
  6. J.R.
    1,405
    68
    This is a picture of the current layout of the relays on the module :
    My Fogs don't work and Rear reverse light don't work.....& my Interior lights.
  7. ~RS~
    ~RS~ Active Member
    1,466
    22
    Going by the pic A8Tech posted on the other relay thread we chatted on as seeen below:
    1 - Terminal 15 voltage supply relay J681- q Plug position B1
    2 - Vacant q Plug position B2
    3 - Heated rear window relay -J9- q Plug position B5
    4 - Horn relay -J413- q Plug position B6
    5 - X-contact relief relay -J59- q Plug position B9
    6 - Double washer pump relay 1 -J729- q Plug position B8
    7 - Double washer pump relay 2 -J730- q Plug position B7
    8 - Vacant q Plug position B3
    9 - Terminal 30 voltage supply relay 2 -J689- q Plug position B4
    Terminal 30 relay doesn't seem to be present on your CE in the position that it displayed as supposedly being in the pic above.
    I don't remember that relay being on your old CE either so kinda weird as all plugs can only go back into same place removed from... and relays went back into same place they came off your old CE, like I did with mine and all is well....
  8. Khufu
    5,704
    31
    I take it you have gone through the long coding for the CE module to make sure everything is ticked correctly? (sorry if im insulting you LOL)
  9. J.R.
    1,405
    68
    Yep.....Spent a couple of min...ticking and un-ticking ..to see what happens....but nothing changed.
  10. ~RS~
    ~RS~ Active Member
    1,466
    22
    I was wondering the same Khufu :) lol...
    Digzz did you check your old coding (old module) vs new coding from K module?
  11. J.R.
    1,405
    68
    This is the old coding :
    Address 09: Cent. Elect. Labels: 8P0-907-279-23-H.lbl
    Part No SW: 8P0 907 279 A HW: 8P0 907 279 A*
    Component: Bordnetz-SG 1.0 H27 0401
    Revision: 00000000 Serial number: 00000000074294
    Coding: A5885F00A2141000000000000000000000
    Shop #: WSC 00000 000 00000
    Part No: 8P2 955 119
    Component: Wischer WWS Audi350 0130
    Coding: 16711696
    Shop #: WSC 00000
  12. Khufu
    5,704
    31
    RS, what version did you update from?
  13. J.R.
    1,405
    68
    I also did a screen shoot of this :
    I don't know what relay 15 installed is thou or whats it for .....
  14. ~RS~
    ~RS~ Active Member
    1,466
    22
    I upgraded from a C Khufu
  15. a8 tech back
    a8 tech back Member
    198
    here is a long code from revision k
    halogen lights fitted to this but may offer some insight to long code
    Address 09: Cent. Elect. Labels: 8P0-907-279-30-H.lbl
    Part No SW: 8P0 907 279 K HW: 8P0 907 279 K
    Component: Bordnetz-SG H54 2501
    Revision: 00H54000 Serial number: 00000008015625
    Coding: E1881F01B01410004F1600001600000000085E175C010000000000000000
    Shop #: WSC 06314 000 08192
    VCID: 458AC1EA7761
    I will dig a pin out for 2008 and 2004 central electrics
    2004
    Pin assignment, onboard power supply control unit -J519
    Connector A (11-pin)
    Pin 1: Terminal 30 right
    Pin 2: Dipped beam right
    Pin 3: Main beam right
    Pin 4: Fog light right
    Pin 5: Vacant
    Pin 6: Flasher front right
    Pin 7: Side light front left
    Pin 8: Flasher side left
    Pin 9: Terminal 31 left
    Pin 10: Electric fuel pump relay
    Pin 11: Terminal 50 relay
    Connector B (12-pin)
    Pin 1: Reversing light right
    Pin 2: Vacant
    Pin 3: Light sensor supply
    Pin 4: Fog tail light, left
    Pin 5: Brake light right
    Pin 6: Vacant
    Pin 7: Footwell light
    Pin 8: Vacant
    Pin 9: Side light rear right
    Pin 10: Rear right turn signal
    Pin 11: Interior lighting
    Pin 12: Terminal 58s
    Connector C (12-pin)
    Pin 1: Seat heating shut-off
    Pin 2: Brake light left
    Pin 3: Vacant
    Pin 4: Coming Home LED
    Pin 5: Vacant
    Pin 6: Vacant
    Pin 7: Vacant
    Pin 8: Number plate light
    Pin 9: Brake light centre
    Pin 10: Side light rear left
    Pin 11: Rear left turn signal
    Pin 12: Vacant
    Connector D (11-pin)
    Pin 1: Terminal 30 left
    Pin 2: Fog light left
    Pin 3: Main beam left
    Pin 4: Dipped beam left
    Pin 5: Terminal 31 right
    Pin 6: Vacant
    Pin 7: Terminal 15 engine relay
    Pin 8: Headlight washer relay
    Pin 9: Flasher side right
    Pin 10: Side light front right
    Pin 11: Flasher front left
    Connector E (16-pin)
    Pin 1: Side lights switch
    Pin 2: Brake light switch
    Pin 3: Vacant
    Pin 4: Vacant
    Pin 5: Garage door opener input
    Pin 6: Fog tail light switch
    Pin 7: P/N without interlock switch
    Pin 8: Dipped beam switch
    Pin 9: Vacant
    Pin 10: Vacant
    Pin 11: Light sensor input
    Pin 12: Coming Home potentiometer tap
    Pin 13: Fog tail light switch
    Pin 14: Assistance driving lights switch
    Pin 15: EC mirror non-dipping
    Pin 16: Light switch 0 setting
    Connector F (8-pin)
    Pin 1: Terminal 50 diagnosis
    Pin 2: Terminal 15 engine diagnosis
    Pin 3: LIN bus
    Pin 4: Terminal L-alternator
    Pin 5: Bonnet contact
    Pin 6: Reversing light switch
    Pin 7: Terminal 30 reference
    Pin 8: Terminal 31 reference
    Connector G (12-pin)
    Pin 1: Terminal 50 switch
    Pin 2: Hazard warning lights LED
    Pin 3: Rear window heater LED
    Pin 4: Terminal 58s potentiometer ground
    Pin 5: Vacant
    Pin 6: Rear window heater button
    Pin 7: Convenience CAN Low
    Pin 8: Convenience CAN High
    Pin 9: Hazard warning lights button
    Pin 10: Terminal 58s potentiometer supply
    Pin 11: Terminal 15 switch
    Pin 12: Terminal 58s potentiometer tap
    Connector H (12-pin)
    Pin 1: Vacant
    Pin 2: Vacant
    Pin 3: Vacant
    Pin 4: Vacant
    Pin 5: Vacant
    Pin 6: Vacant
    Pin 7: Vacant
    Pin 8: Vacant
    Pin 9: Vacant
    Pin 10: Vacant
    Pin 11: Vacant
    Pin 12: Vacant
  16. a8 tech back
    a8 tech back Member
    198
    2008 >
    Pin 5: Vacant
    Pin 2: Vacant
    Pin 6: Vacant
    Pin 8: Vacant
    Pin 3: Vacant
    Pin 5: Vacant
    Pin 6: Vacant
    Pin 7: Vacant
    Pin 12: Vacant
    Pin 6: Vacant
    Pin 3: Vacant
    Pin 4: Vacant
    Pin 9: Vacant
    Pin 10: Vacant
    Connector F (8-pin)
    Pin 3: LIN bus
    Pin 5: Vacant
    Pin 1: Vacant
    Pin 2: Vacant
    Pin 3: Vacant
    Pin 4: Vacant
    Pin 5: Vacant
    Pin 6: Vacant
    Pin 7: Vacant
    Pin 8: Vacant
    Pin 9: Vacant
    Pin 10: Vacant
    Pin 11: Vacant
    Pin 12: Vacant
  17. a8 tech back
    a8 tech back Member
    198
    ok check the wiring and run a output test in address 09 to check there is a feed from the pins when the test runs for interior light etc
  18. J.R.
    1,405
    68
    Comparing both of these ...there the same....But I seem to have a Problem with this connector B
    Weather it's a coding thing ..or not...I ain't got a clue....I also checked to see if this connector was in properly...and it was...
    Pin 1: Reversing light right ---Not working
    Pin 2: Vacant
    Pin 4: Fog tail light, left -----Not working
    Pin 6: Vacant
    Pin 8: Vacant
    Pin 11: Interior lighting ---------Not working
  19. J.R.
    1,405
    68
    How do you run a output test ?
  20. a8 tech back
    a8 tech back Member
    198
    I used to have a long code simulator which helped calculate the code byte changes when not connected to the vehicle
    Compare the long code from the log above byte for byte and find the interior light, see if it differs
    so what isn't working now
  21. J.R.
    1,405
    68
    Are you saying compare these 2 codes together ?
    New Code : 078C5F060014100040000000000000000000FE075C06000000 0000000000
    Old Code : A5885F00A2141000000000000000000000
  22. a8 tech back
    a8 tech back Member
    198
    compare with this
    5 door a3 without xenon
    Coding: E1881F01B01410004F1600001600000000085E175C01000000 0000000000
    your cod078C5F060014100040000000000000000000FE075C06000000 0000000000
    I will look at the wiring diags in the morning as there not matching the pin outs for j519
  23. J.R.
    1,405
    68
    I've counted 15 changes ......would I just change each digit and press Do it...to see if they start to work?
  24. a8 tech back
    a8 tech back Member
    198
    Rear right reverse should now be t12c/4 as it was t12c/1 for 5 door
    Left fog was t12c/4 now t12c/1
    So see if the fog comes on when you reverse or reverse if you put the fog on lol
    If that works out I will look at the interior light after
    Sent from my iPhone using
    My fat fingers
  25. Khufu
    5,704
    31
    LOL
  26. J.R.
    1,405
    68
    I'll check it out in a few min's and get back to you on that.
  27. J.R.
    1,405
    68
    I've just checked it out and nothing else comes on when I engage the Reverse gear :shrug:
  28. a8 tech back
    a8 tech back Member
    198
    well its time to look at the general coding of the control unit
    then look at the outputs from the control unit
    output test can be done by either switching on the componant or via vcds
    when you go into address 09 you will see the output test
    click on and you can test individual items like reverse or interior lights etc
    so either way connect a voltmeter or led test light to the pin you think should feed out the signal for reverse etc
    if there is a feed coming out but no operation at the light then the wiring needs looking at
    start with the reverse switch and when you sort that out you can move onto the fog and interior light
    its may help if you do a dump screen of long code helper with the info for each byte so it can be seen what's coded or not coded
    i cant tell you from here which byte does what without seeing them
    the interior light pin out is the same for pre 2008 so that's telling you the wiring is fine
    we will get there, just a bit of messing around first
    i will post a wiring diagram of the reverse circuit
  29. a8 tech back
    a8 tech back Member
    198
    my elsa differs as it s showing left hand drive on one pc and right on me other argggggggggggh but this should be correct
    this looks better
    from 2004 upto 2009 the plugs on j519 are the same 2010 changes so these plugs and pin numbers should be correct
    elsa 3.81 shows left hand drive but i have the earlier version which is right hand drive
    my head hurts
    giving up tonight due to man flew
    ScreenShot001 by a8 tech, on Flickr
  30. a8 tech back
    a8 tech back Member
    198
    change byte 3 from 06 to 01 and see what happens
    this is from a k revision 5 door
    Coding: E4 88 1F 01 B0 14 10 00 4F 16 00 00 16 00 00 00 00 08 5A 17 5C 01 00 00 00 00 00 00 00 00
  31. J.R.
    1,405
    68
    Ok I'll give that a try in a few mins.....
  32. J.R.
    1,405
    68
    I've just tried it and still nothing changed. But I'm getting a few different fault codes for the reverse light and rear fog light.
    Wednesday,18,February,2009,21:36:53:26365
    Software Coding: B78C5F060014100000000000000000000010FE075C060200000000000000
    5 Faults Found
    00061 - Footwell Lights
    Freeze Frame
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 248
    Mileage: 165429 km
    Time Indication: 0
    Date: 2011.05.18
    Time: 20:34:00
    Freeze Frame
    ON
    Voltage: 11.60 V
    ON
    OFF
    OFF
    OFF
    OFF
    01502 - Bulb for Rear Fog; Left (L46)
    Freeze Frame
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 248
    Mileage: 165429 km
    Time Indication: 0
    Date: 2011.05.18
    Time: 20:34:00
    Freeze Frame
    ON
    Voltage: 11.60 V
    ON
    OFF
    OFF
    OFF
    OFF
    01519 - Bulb for Back-Up Lights; Right (M17)
    Freeze Frame
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 248
    Mileage: 165429 km
    Time Indication: 0
    Date: 2011.05.18
    Time: 20:34:00
    Freeze Frame
    ON
    Voltage: 11.60 V
    ON
    OFF
    OFF
    OFF
    OFF
    Freeze Frame
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 248
    Mileage: 165429 km
    Time Indication: 0
    Date: 2011.05.18
    Time: 20:33:00
    Freeze Frame
    ON
    Voltage: 11.70 V
    ON
    OFF
    OFF
    OFF
    OFF
    Freeze Frame
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 248
    Mileage: 165429 km
    Time Indication: 0
    Date: 2011.05.18
    Time: 20:34:00
    Freeze Frame
    ON
    Voltage: 11.70 V
    ON
    OFF
    OFF
    OFF
    OFF
  33. a8 tech back
    a8 tech back Member
    198
    do you have dual fogs or just the one
    11.60 volts would indicate the signal voltage is open circuit so the voltage is coming out of j519 but not getting to the lights so returned voltage read is the same as whats going out
    in other words no consumer to consume the current/voltage = open circuit
  34. J.R.
    1,405
    68
    I have 1 rear Fog.....
  35. a8 tech back
    a8 tech back Member
    198
    change byte 3 so its just one fog light
    clear the codes
    turn ignition off then on
    turn the fog light on
    rescan
    if you just have the fault code for one fog then check the feed out of j519 for the fog light
    double check the fog light bulb is ok as well if there is a feed out
    lets see what happens and if this original pin is still designated for fog light
  36. J.R.
    1,405
    68
    Would I just change the byte 3 06 to 16 ?
  37. a8 tech back
    a8 tech back Member
    198
    sorry just swapped lap tops for wire position
    try 16
    sorry to confuse but I have 2 laptops running here and for the life of me keep mixing up fogs and reverse 5 door and 3 door as well as left and right hand drive because elsa 3.81 is wrong
    I will look proper in the morning, hopefully man flu free
  38. J.R.
    1,405
    68
    I've just released something sufficient ....these errors below are very weird ... because the bulb for the rear Fog light is on the Right not the Left. And the Back-Up Light is on the Left ....Not Right....as below states...
    I also did a Test for the rear Fog in Vag-com .....And the light worked.....
    Would you know what all this means?
    Freeze Frame
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 248
    Mileage: 165429 km
    Time Indication: 0
    Date: 2011.05.18
    Time: 20:34:00
    Freeze Frame
    ON
    Voltage: 11.60 V
    ON
    OFF
    OFF
    OFF
    OFF
    Freeze Frame
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 248
    Mileage: 165429 km
    Time Indication: 0
    Date: 2011.05.18
    Time: 20:34:00
  39. J.R.
    1,405
    68
    I've just compared some rear lights from ebay.de.....And My Previous old lights... The Back up lights & Fog lights are in a different place.
    These are my lights:
    These are the ones from ebay.de
  40. a8 tech back
    a8 tech back Member
    198
    fog light will be osr
    reverse will be nsr
    so if the output test puts the osr fog on then the wiring is correct from the output of j519
    so is the j519 getting the signal from the headlight switch to activate the fog
    rear fog light switch input is found Connector E (16-pin j519) pin 13
    you should be able to check with vcds via measured value blocks if the switch is working
    open the label files and this will tell you which measured value block osr fog light is in
    fog light pin input pin 13 is the same for both control units so is the switch ok
    L46 is in deed REAR LEFT FOG FOR 3 DOOR MODELS but not used as this is used as a reverse light M16 rear left reverse
    so the back lights are not coded correctly as m17 is right reverse and your reverse should be rear left
