Fault Codes Meanings
Yarsir Aug 26, 2011
  1. Yarsir
    Yarsir New Member
    14
    Hello
    people
    Car, 2006 A4 Avant Tdi 170, 94k FASH
    Symptoms none. Problems yellow flashing glow plug lightly randomly coming on.
    Yesterday - yellow flashing glow plug light again with check engine light permanently
    on.
    Only had the car a few weeks, maybe normal but noticed lumpy idle and just
    today strong smell of fuel
    Any help advice would be appreciated. Thanks
    Chassis Type: 8E - Audi A4 B6/B7
    Scan: 01 02 03 08 09 0F 11 15 16 17 18 36 37 45 46 55 56 57 65 67
    69 75 76 77
    VIN: WAUZZZ8E27A054421 Mileage: 151910km/94392miles
    Address 01: Engine Labels: Redir Fail!
    Part No SW: 03G 906 018 AQ HW: 03G 906 018 AQ
    Component: R4 2.0l PPD1.3 9971
    Revision: --H23--- Serial number:
    Coding: 0000072
    Shop #: WSC 00414 210 83158
    VCID: 74EC0ED56E2B
    2 Faults Found:
    005214 - Mass Air Flow during Regeneration too Low
    P145E - 006 - Short to Plus - Intermittent - MIL ON
    Freeze Frame:
    Fault Status: 10100001
    Fault Priority: 5
    Fault Frequency: 7
    Reset counter: 40
    Mileage: 0 km
    Time Indication: 0
    Freeze Frame:
    RPM: 1568 /min
    Torque: 24.0 Nm
    Speed: 25.0 km/h
    0.00 %
    85.41 %
    Mass Air / Rev.: 321.6 mg/str
    Mass Air / Rev.: 610.4 mg/str
    012546 - Motor for Intake Manifold Flap (V157): No Signal
    P3102 - 006 - Short to Plus - Intermittent
    Freeze Frame:
    Fault Status: 00000001
    Fault Priority: 5
    Fault Frequency: 7
    Reset counter: 40
    Mileage: 0 km
    Time Indication: 0
    Freeze Frame:
    RPM: 0 /min
    Torque: 144.0 Nm
    Speed: 0.0 km/h
    0.00 %
  2. gary3306
    gary3306 Active Member
    989
    41
    Yea, you need a new MAF sensor and a new Motorized intake Manifold Flap. Both around £150 ish from the dealer (MAF sensor may be a bit more)
  3. Yarsir
    Yarsir New Member
    14
    Thanks for the reply. That's expensive news I didn't want to hear :sadlike:
    Only recently had the car serviced, all filters and oil, couple of days later the problem started but probably just bad timing?
    Was typing first post while in the car, cleared the faults, drove 10 feet then the glow plug light came straight back on!
    This!
    VCDS Version: Release 10.6.4 (x64)
    Data version: 20110418
    Saturday,27,August,2011,21:49:29:26576
    69 75 76 77
    Coding: 0000072
    VCID: 74EC0ED56E2B
    1 Fault Found:
    Freeze Frame:
    Fault Status: 11000001
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 40
    Mileage: 0 km
    Time Indication: 0
    Freeze Frame:
    RPM: 1600 /min
    Torque: 64.0 Nm
    Speed: 53.0 km/h
    0.00 %
    85.41 %
    Mass Air / Rev.: 392.4 mg/str
    Mass Air / Rev.: 648.6 mg/str
    Readiness: N/A
  4. Yarsir
    Yarsir New Member
    14
    Can anyone concur :yes:
    After a quick search seems to be a common issue on these....
  5. chrisa4quat
    chrisa4quat Active Member
    970
    29
    both are on this, air mass meter and intake manifold flap (throttle body). check fuse for engine. see if fuse has blown. fuse will be side of dash. You can also get these parts from euro car parts a bit cheaper, poss gsf?
  6. Yarsir
    Yarsir New Member
    14
    Hello, thanks for the reply.
    Well decided to remove the MAF and clean it with electrical circuit cleaner.
    Refitted the MAF and all was fine for 1 day, nice idle, no smoke or warning lights.
    Went out today and after around 3 miles same yellow glow plug light started to flash :blownose:
    Turned of and started again a couple of hours later on way home, light had gone out but strong smell of fuel and smoking on cold.
    Just cleared the fault the same fault again -
    Tuesday,30,August,2011,17:38:53:26576
    Control Module Part Number: 03G 906 018 AQ HW: 03G 906 018 AQ
    Component and/or Version: R4 2.0l PPD1.3 9971
    Software Coding: 0000072
    Work Shop Code: WSC 00414 210 83158
    VCID: 74EC0ED56E2B
    1 Fault Found:
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 40
    Mileage: 0 km
    Time Indication: 0
    Freeze Frame:
    RPM: 1472 /min
    Torque: 32.0 Nm
    Speed: 49.0 km/h
    0.00 %
    85.41 %
    Mass Air / Rev.: 735.8 mg/st
    Readiness: N/A
    Will have to order replacement MAF from dealers tomorrow. As far as the manifold flap issues goes, sprayed a little WD40 on it and has been fine since, but I'm guessing the messed up readings from the MAF with over fueling may have triggered that fault??
  7. *Adam
    *Adam Member
    55
    Unplug your MAF and see if it runs without the glow plug light flickering but it does seem to want a new MAF. Just got one myself for £133 with a £52 surcharge :(
  8. Yarsir
    Yarsir New Member
    14
    Fitted a new MAF a couple of days ago. No issues since, car seems to idle/drive smoother
    Just waiting for the injectors to pack up now :redrs4:
  9. Yarsir
    Yarsir New Member
    14
    Well all started again now. Same symptoms, strong smell of fuel, 2 yellow lights and same faults codes as above.
    Going to order a new intake manifold flap and have it fitted. I'm guessing the manifold flap issue is leading to the MAF fault? As i've already changed that. Could it be anything else?
