fault codes help needed
Sham101 May 8, 2013
  1. Sham101
    Sham101 Member
    286
    20
    first one p1426
    second one p0103
    any help please
  2. Lewis583
    956
    91
    Always check here first >>>>Link
    Check continuity of the EVAP solenoid, if that's okay then you need to check that there is a feed to the solenoid. Also check whether there are any breaks in the wiring to the solenoid.
    The MAF code will require a logging session to asses how much air the engine is ingesting/thinks it's ingesting.
  3. gen.heinz guderian
    gen.heinz guderian Well-Known Member
    1,346
    126
  4. Sham101
    Sham101 Member
    286
    20
    but i have replaced the maf for a new bosch one
  5. gen.heinz guderian
    1,346
    126
    did you delete the previous codes? and re scan again?
  6. Lewis583
    956
    91
    That doesn't mean it's any good though. New parts can be faulty too. Logging/diagnosing is required as just replacing parts willy nilly can get expensive.
    If you are adamant the new MAF is good, then you need to start tracing back wiring checking for breaks, high resistance at plugs etc
  7. s3dave
    s3dave TFSI Hybrid Supporter
    10,110
    736
    Agreed with Lewis, heard a lot of people taking MAFs back because they are faulty..
  8. Sham101
    Sham101 Member
    286
    20
    will get it exchanged tommorow and fault codes were deleted last time
