Fault Codes from my Car
tonybolony Sep 1, 2013
  1. tonybolony
    tonybolony Member
    134
    As discussing an earlier thread these are the log readout for my car.
    The engine has been out, due to blown turbos which i replaced
    as i said the units are firing up but not past 0.5 bar and the boost doesnt always hold, naturally the faults standing out are the boost pressure control valve and the purge valve, have i done something wrong :-(
    11 Faults Found:
    17833 - EVAP Purge Valve (N80): Short to Ground
    P1425 - 35-00 - -
    17938 - Cant Find
    P1530 - 35-00 - Please Register/Activate
    17955 - 17955/P1547/005447 - Boost Pressure Controle Valve (N75): Short to Ground
    17697 - Boost Pressure Control Valve (N249): Short to Ground
    P1289 - 35-00 - -
    16486 - 16486/P0102/000258 - Mass Air Flow Sensor (MAF/G70): Signal too Low
    17861 - Cant Find This
    17865 - Exhaust Gas Temp Sensor 2 (G236): Open or Short to Plus
    P1457 - 35-00 - -
    17523 - Cant Find This
    P1115 - 35-00 - Please Register/Activate
    17527 Cant find this
    P1119 - 35-00 - Please Register/Activate
    16518 - Oxygen (Lambda) Sensor B1 S1: No Activity
    P0134 - 35-00 - -
    16538 - 16538/P0154/000340 - Oxygen (Lambda) Sensor B2 S1: No Activity
  2. tonybolony
    tonybolony Member
    134
    I have listed the codes i can find, go i am so depressed, if anybody can help me as to the possible reason for the limp mode, or if one thing is related to all others etc?
  3. @udi A3
    @udi A3 Site Sponsor Site Sponsor VCDS Map User
    1,789
    186
    Id like to see a vcds scan, where abouts are you?
    checked all wiring and connections ?
  4. jcb
    jcb Active Member VCDS Map User
    4,132
    13
    are you absolutely sure you replaced all the connectors and earth straps
  5. Blue_Thunder
    Blue_Thunder Well-Known Member
    1,767
    31
    I'd be checking the earth strap behind the coolant bottle.
    You did clear all the codes when you first got the car started after your engine pull didn't you? You always end up with a shedload at first.
  6. aragorn
    17,872
    686
    Given so many faults then i'd imgine its either a missing/broken earth, or perhaps some loom has chafed thru or similar, or a blown fuse even.
    The codes arent shown as "intermittent" which means they are still present, rather than historic.
  7. tonybolony
    tonybolony Member
    134
    yes i cleared all the codes, and then i went for a drive and got them all back again :-/ , really depressing me, i will check the fuses in a bit, i am guessing there the Engine Timing Fuses
  8. tonybolony
    tonybolony Member
    134
    I am in leeds mate
  9. tonybolony
    tonybolony Member
    134
    <br><br>I am in leeds mate
  10. tonybolony
    tonybolony Member
    134
    well a pesky fuse has me out of limp mode, so will rescan in a bit to see what faults have now, but were boosting like a mother!!!
  11. @udi A3
    1,789
    186
    im only 40 mins down the A1, if you need a scan or second pair of eyes, give me a shout.
