Fault codes diags after remap - Star Performance
prel2000
Can fault codes be read from the diagnostics port following a remap of the ECU?
I have a OBDII diagnostics reader and everytime I try and connect and attempt to read any errors it come back as "Error". It makes me wonder if the remap on the ECU has altered codes and that they are unreadble and even more so if the fault codes will even display anymore in dash or on a reader?
Its a star remap done via the dual port systems (Very pleased with remap). I have had it for around 3 weeks and just wanted to know if the car has logged any fault as a result.
Hi there sould be no problem with fault codes from the ECU most companies doing remaps only alter the calibration areas of the ecu and should not alter the Fault Code side of life.
A
