Mannie
- Joined
- Oct 24, 2014
- Messages
- 27
- Reaction score
- 0
- Points
- 1
Hey folks,
I have a 2007 A3 2.0 TFSI Sportsback. 80,000.
I have just recently had my ESP fault warning come up, so I bought a cheap fault code reader. I have found the following readings. Can somebody please tell me what the 04642 code means, I can't find it anywhere.
Also if I refit the ABS wheel sensor, do I have to erase the error or does it clear its self from the system on its own. As I also have the ABS controller error too and had a full VAG device history, I don't want to mess anything up for any future work that Audi might offer for free or discount.
ABS
00290
04642
A/T
18255
00290 - ABS Wheel Speed Sensor Rear Left (G46)
00290 - ABS Wheel Speed Sensor Rear Left (G46): Signal Outside Specifications
00290 - ABS Wheel Speed Sensor Rear Left (G46): Electrical Fault in Circuit
Possible Causes
00285 - ABS Wheel Speed Sensor Rear Left (G46): Mechanical Malfunction
Possible Causes
18255/P1847/006215 - Please check DTC Memory of ABS Controller
Possible Symptoms
ABS
00290
04642
A/T
18255
Possible Causes
- Open Circuit in Wiring from/to ABS Wheel Speed Sensor Rear Left (G46)
- ABS Wheel Speed Sensor Rear Left (G46) faulty
- Check Wiring from/to ABS Wheel Speed Sensor Rear Left (G46)
- Check ABS Wheel Speed Sensor Rear Left (G46)
Possible Causes
- Excessive Air Gap between ABS Wheel Speed Sensor Rear Left (G46) and Rotor
- Short Circuit in Wiring from/to ABS Wheel Speed Sensor Rear Left (G46)
- Check ABS Wheel Speed Sensor Rear Left (G46) Installation
Possible Symptoms
- Malfunction Indicator Light (MIL) ON
- Fault Code / Diagnostic Trouble Code (DTC) stored in Brake Electronics Control Module (J104)
- Check Brake Electronics Control Module (J104) for Fault Codes
- VCDS > Select > 03 - Brake Electronics > Fault Codes - 02
- A Fault Code stored in one Module may influence other Modules as well, if a Control Module requires certain Information/Signals and the sending Module/Component is faulty it may store this Code.
