fault code
hades- Jan 14, 2012
  1. hades-
    9,480
    646
    17606 - Oxygen (Lambda) Sensor Heater Circuit: B1 S2
    P1198 - 35-00 - Electrical
    from vcds wiki
    17606/P1198 - Oxygen (Lambda) Sensor Heater Circuit: B1 S2: Electrical Malfunction [h=4]Possible Causes[/h]
    • Failed O2 sensor heater circuit
    • Wiring Harness issue
    • Failing ECM
    [h=4]Possible Solutions[/h]
    • Inspect and test O2 sensor heater circuit as per repair manual
    • Inspect and test wiring harness as per wiring diagram
    • Replace ECM if O2 sensor and wiring harness are to factory design
    whats the ECM ?
  2. murran
    murran Well-Known Member
    1,545
    39
    engine control modual. ecu basically.
    you need a new lambda sensor most likely. check the resistance thru the heater circuit on the sensor itself.
  3. hades-
    9,480
    646
    cheers murran
    would that be the pre cat lambe or the 1 after the cat ?
  4. murran
    1,545
    39
    b1 s2 it says.... s2 = sensor 2 = post cat sensor.
    s1 being the pre cat sensor.
